3.5 Increase JVM Memory
Oracle recommends a minimum Java Virtual Machine (JVM) setting of 2048M instead of the default size of 512M.
You must make this change through Oracle Applications Manager. If you do it manually, your changes will be lost when you run AutoConfig.
To increase this setting, do the following:
