3.2.1 Install Patches Using Autopatch
Install the following patches using Autopatch to upgrade from R12.1.1 to R12.1.3:
  • 9239089 Oracle Applications DBA 12.1.3 Product Release Update Pack
  • 9239090 Oracle E-Business Suite 12.1.3 Release Update Pack
  • 10222869 Oracle Applications Framework patch
  • 12661509 for compatibility with Internet Explorer 8.
  • 11781531, NOT ABLE TO ADD HTTPS URL TO FAVORITES LINK IN 12.1.2. HTTP IS PRE-PENDED TO URL
  • 11832737, which is a forward port of patch 9908921 to Oracle Applications 12.1.3 fixing the intermittent FND_NO_DATABASE_CONNECTION error observed in the new home page.
  • 19357286 - API TO PREVALIDATE EBS USERS for Oracle LSH (This patch is only required if you perform a full install of Oracle LSH 3.0 [not an upgrade to 3.0 from a previous version].)
  • 16263414 - FND PRODUCT INSTALLATION IS NOT EXECUTING FOR GHR, OTL, IREC PRODUCTS (This patch is only required if you perform a full install of Oracle LSH 3.0 [not an upgrade to 3.0 from a previous version].)
