- Installation Guide
- Installing and Patching Oracle Applications and Oracle Database
- Upgrade to Oracle Database 19c (19.8)
- Perform Oracle Database 19c Post-Upgrade Tasks
- Set Parameter Values
3.8.1.6 Set Parameter Values
- Log in to Oracle Database 19c.
- Set the following values:
- CLOB Changes = ALTER SYSTEM SET EVENT='44951 TRACE NAME
CONTEXT FOREVER, LEVEL 1024' scope=spfile;
Take a backup of earlier events and then append this event (if not already set) in the existing list of events, if any. - DB CACHE SIZE = 48 GB (at the CDB and PDB levels)
- JAVA_POOL_SIZE = at least 2 GB
DMW 3.0 and later uses Java DB memory with job/install engine architecture. - SGA MAX SIZE = 100 GB
- USE_LARGE_PAGES = ONLY
- audit_trial: Check that this parameter uses the same value you used for Oracle Database 11g
- Set container_data as CURRENT_DICTIONARY
- db_16k_cache_size = 16 GB
- db_keep_cache_size = 12 GB
- open_cursors = 1000 (at the CDB and PDB levels)
- open_links = 50
- open_links_per_instance = 500
- _optimizer_dsdir_usage_control = 0
- _optimizer_gather_stats_on_conventional_dml = FALSE
- _optimizer_use_stats_on_conventional_dml = FALSE
- pga_aggregate_target = 30 GB (at the CDB and PDB levels)
- parallel_max_servers = 64
- pga_aggregate_limit = 60 GB
- processes = 5000
- _column_tracking_level = 1
- _sql_plan_directive_mgmt_control = 0
- shared_pool_size = 12 GB (at the CDB and PDB levels)
- Add SQLNET.ALLOWED_LOGON_VERSION_SERVER=10: and SQLNET.ALLOWED_LOGON_VERSION_CLIENT=10 in SQLNET.ORA of grid home in all RAC Nodes
- Add SQLNET.INBOUND_CONNECTION_TIMEOUT=300 in SQLNET.ORA of grid home and PDB $TNS_ADMIN in all RAC Nodes (source the PDB environment file from ORACLE_HOME)
- Remove the encryption parameter. For details, see Use of Oracle Database Native Network Encryption with DMW (Document ID 2783451.1) on My Oracle Support.
Parent topic: Perform Oracle Database 19c Post-Upgrade Tasks
