4 Adding and Modifying Lookup Values
This chapter contains the following topics:
- About Lookups
Oracle Life Sciences Data Hub uses predefined lists of values for many items such as drop-down lists in the user interface. - Modifiable Lookups
You can modify the following lookups in Oracle Life Sciences Data Hub: - Logging In
To modify lookup values, do the following: - Querying and Viewing Lookups
To view a lookup, or reference codelist, query for it as follows. Further information is available in the online help. - Adding, Modifying, or Discontinuing a Lookup Value
Depending on the access level assigned to a lookup, you may be able to change its displayed text (the "Meaning") and add, modify, and discontinue existing values.
