Job Statuses
Oracle Life Sciences Data Hub uses the following statuses to track the progress of a job. You must refresh the screen to see updates.
- Pending
The job has not yet started running. - Started
The job has begun pre-processing. - Executing
The Program has connected to database and is running. - Finalizing
The job has begun post-processing. - Success
The job has completed successfully without warnings. - Warnings
The job has completed successfully with warnings. - Failure
The job has completed with a fatal error. - Aborted
The job has been manually aborted. - On Hold
The job is waiting for the Work Area quiesce process to complete. - Expired
The system removed the job from the queue after the timeout interval passed. - Duplicate
The job is a duplicate of another job; the currency of the source data, parameter values, and executable instance version are the same.
Parent topic: Monitoring Jobs
