Modifying Terms
To modify a term:
- Go to the Terms subtab in the Classifications tab.
- Navigate to the hierarchy that contains the term you want to modify.
- Click the pencil icon in the Maintain Terms column of the parent of the term you want to update.
- You can modify term attributes as follows:
- You can change a term's Approved setting from No to Yes at any time.
- You can change the Approved setting from Yes to No only if the term has not been used either as a default classification for an object subtype or to classify an object and no approved child terms are associated with the approved term.
You can remove a term only if it has not been used in any way and does not have any child values.
Parent topic: Modifying Hierarchies and Terms
