2 Setting Up Adapters to External Systems
This chapter contains the following topics:
- About Adapters
The Oracle Life Sciences Data Hub (Oracle LSH) includes a set of predefined adapters that handle the interface between Oracle LSH and external systems. - Adapter Structure
Oracle Life Sciences Data Hub adapters are defined objects like other defined objects in Oracle LSH. - Creating Your Own Adapters
You can create adapters to other external systems you want to use with Oracle Life Sciences Data Hub; for example, third party visualization and reporting tools. - Setting Up Security for Adapters
This section contains the following topics: - Clearing Oracle Applications Cache
Every time you assign a user to a user group, clear the Oracle Applications cache so that users logging into Oracle Life Sciences Data Hub do not see unassigned privileges.
