Upgrading an Existing Domain
This section describes how to upgrade the existing domain with the import script.
The import script performs the following tasks:
- If any objects are currently checked out in the Domain on the target Oracle Life Sciences Data Hub instance, the script checks them in with the comment "Checked in by IEU".
- Checks out all objects with the comment "Checked out by IEU" and updates the versions of the object definitions and instances if it finds new versions in the export file.
- Checks in object definitions after versioning and applies the comment "Checked in by IEU."
- Creates a log file in the database directory on the target Oracle LSH instance. The log file has the same name as the Domain: domain_name_import.log. See Import Log File Content.
- You must check the log and decide whether or not to
commit
changes to the database on account of the upgrade. You canrollback
the changes if the import log shows problems during upgrading.
Parent topic: Importing Objects
