Execute the cdrretifytable.sql Script
If you are upgrading from Oracle LSH release 2.2.x or 2.4.9.x to release 3.1, you must execute the
cdrretifytable.sql script. However, if you have already
executed this script earlier successfully in release 2.4.9.x, you need not execute this
script again.
For executable objects like programs and data marts, the script validates that the
BLINDING_UPGRADABLE_RC attribute is set correctly for the LSH 2.2.x tables. If the
attribute is set incorrectly, the script updates it to use the correct value. In
addition, if the BLINDING_UPGRADABLE_RC attribute is set incorrectly, the script
re-installs text Load Sets and their target tables.
Parent topic: Upgrade to Oracle Life Sciences Data Hub 3.1
