Add clovi.gif to the EBS R12.2 File System
  1. Source the PATCH file system environment file from the Oracle LSH application server by using the following command:
    source /<BASE_LOCATION>/EBSapps.env PATCH
  2. Perform the following:
    Ensure that the destination path where you copy the clovi.gif is correct.
    1. Copy clovi.gif from $CDR_TOP/media to $RUN_BASE/FMW_Home/Oracle_EBS-app1/applications/oacore/html/cabo/images/cache.
    2. Copy clovi.gif from $CDR_TOP/media to $PATCH_BASE/FMW_Home/Oracle_EBS-app1/applications/oacore/html/cabo/images/cache.
  3. Re-source the environment file, as required.
