9 What's Next
After you have finished all the installation tasks outlined in this book, you must do the following tasks before you can begin to use the Oracle Life Sciences Data Hub (Oracle LSH):
Oracle Health Sciences Data Management Warehouse customers can skip this section and proceed to the Oracle Health Sciences Data Management Warehouse Installation Guide.
  • Define Oracle LSH Distributed Processing (DP) Server service locations and services to integrate Oracle LSH with its processing engines and IDEs. See "Setting Up Services" in the Oracle Life Sciences Data Hub System Administrator's Guide.
  • Design an object security system, classification system, and organizational structure for your implementation of Oracle LSH. See "Designing a Security System," "Designing a Classification System," and "Designing an Organizational Structure" in the Oracle Life Sciences Data Hub Implementation Guide.
  • Set up the security system, see "Setting Up the Security System" in the Oracle Health Sciences Data Management Workbench and Life Sciences Data Hub Security Guide.
  • Set up the classification system and organizational domains. See "Setting Up the Classification System" in the Oracle Life Sciences Data Hub System Administrator's Guide and "Applications User Interface" in Oracle Life Sciences Data Hub Application Developer's Guide.
  • Define remote locations to integrate Oracle LSH with Oracle-based source data systems. See "Registering Locations and Connections" in the Oracle Life Sciences Data Hub System Administrator's Guide.
  • If you plan to use OBIEE for visualizations or Oracle BIP for reports, do the additional setup required for each system. See the Oracle Life Sciences Data Hub System Administrator's Guide for information.
  • If you plan to integrate with Oracle Identity Cloud Services (IDCS) for the single sign-on solution, follow instructions in Doc ID 2862928.1 on My Oracle Support.
