Refreshing the Context Server Index
When you insert new dictionary terms or VTAs into the TMS repository, the Context Server cannot find them in a query until you refresh the Context Server Index. Oracle recommends that you schedule this refresh as a batch job running as often as is appropriate for your TMS installation.
You can refresh the Context Server Index by running the Refresh Context Server Index batch job.
To refresh the Context Server Index:
- From the Definition menu, select Jobs, then Refresh Context Server Index. The Refresh Context Server Index batch job window appears. There are no parameters to enter.
- Use the runner icons in the toolbar to save and retrieve parameter sets as necessary, submit the job, and monitor its progress.
See Reports and Batch Jobs for more information.
Parent topic: Administration
