Viewing Data in the Browse VT Classification Data Window
Use this window to view:
verbatim terms (VTAs and VTIs).
Unclassified verbatim terms (omissions).
All occurrences of verbatim terms that have been collected at the local instance, if any.
External system information associated with verbatim terms, if any.
Query in the lower block. If you have selected an external system from the list at the top of the screen, you can query on any of the external system fields. TMS displays all terms that fit the query in the top block, and in the lower block any occurrences of the top term that have been collected locally. To see local occurrences of another term, highlight it in the top block.
Fields in the upper block are:
Vt Upper. A term retrieved by the query entered in the lower block.
Classified. If selected, this verbatim term has been mapped to a dictionary term.
Domain. The domain with which this verbatim term is associated.
Fields in the lower block are:
Verbatim Term. Occurrences of the verbatim term highlighted in the upper block that were collected at the local instance.
Classified If selected, this verbatim term has been mapped to a dictionary term.
Source Id. Unique identification for this verbatim term.
Occur Id. Unique identification for this occurrence of this verbatim term.
Integration Key. Unique identification for the external system within TMS.
Additional Fields. If an external system is available and selected from the list at the top of the window, up to eight additional fields with external system information associated with this occurrence appear here.
Alt Key. Optional user-defined unique identification for this term.
Parent topic: Browsing the Repository in TMS
