Known Issues
Oracle has identified the known issues below in Oracle Health Clinical Intelligence. The list is updated when issues are identified or resolved in a new release.
You can view known issues for this solution in eService. In Step 4 below, select Clinical Intelligence from the Solution list.
Complete the following steps to view known issues:
- Access eService.
- Select View Solution Change Records under Solution Changes.
- On the Solution list, select the check box next to the solution or solutions for which you want to view known issues.
- You can filter the list of known issues further using the following filters:
- Enter a date range in the Published Between box to see only issues published in a certain time span, for example, if you want to view new known issues since the date you last ran the query.
- Optionally, you can enter a client number, solution change number, solution change type, severity, or status to further narrow results.
- Select Apply. The list of known issues matching the entered criteria is displayed.
- To save the search criteria for future use, select Save and enter a name for the saved search. When you return to eService, saved searches are available to select from a list at the top of the search criteria box.
- To export the results to Excel, select Export to Excel above the search results.
- To clear the selected search criteria, select Clear.
The list of known issues changes over time and you should review it regularly.
Parent topic: Oracle Health Quality Management Release Notes
