Oracle Health Quality Management 2026.01
The solution changes below are available with the Oracle Health Quality Management 2026.01 release.
- Preproduction Release Date: Not applicable
- Production Release Date: February 10, 2026
| Solution Change | Component, Description, and UI Impact | Reference Materials | Validation Guidelines | Implementation and Maintenance Impact |
| Care Gap Closure Feature HNVBC-33315 |
Component: Quality Management You now can view and act on targeted care gap closure recommendations that are based on patient history and upcoming appointment information. UI Impact: Workflow Automatic Top opportunities with an Agent Insight badge provide targeted opportunities for patient follow up and care gap closure. |
View Care Gap Closure Opportunities | Verify that you can successfully complete the workflows in the Reference Materials. |
Implementation Impact: None
Maintenance Impact: None |
| New Personnel Group Feature HNVBC-35522 | Component: Quality Management The Population_Intelligence_Allowlist personnel group now can be used to restrict access to Quality Management. UI Impact: Workflow (Implemented) Add users to the Population_Intelligence_Allowlist and log a service record (SR) to enable feature flag that activates the allow list. | Quality Performance Personas | Verify that users who are not included in the Population_Intelligence_Allowlist cannot access Quality Management. | Implementation Impact: Medium Log an SR to turn on the Restrict User Access feature flag. Once the feature flag is enabled, only users in the Population_Intelligence_Allowlist personnel group can access Quality Management. Maintenance Impact: None |
| New Scorability filter for Quality Tab HNVBC-35136 | Component: Quality Performance You now can use the Scorable filter in the Quality Performance tab to view only measures on your scorecard. UI Impact: Workflow (Automatic) Use the Scorable filter to filter measures in the Quality Performance tab. | View the Quality Performance Dashboard | Verify that you can use the Scorable filter to filter measures in the Quality Performance tab. | Implementation Impact: None Maintenance Impact: None |
| Custom Measure Support | Component: Quality Performance External measures now support links in the Quality Performance tab. You can define links in Score Plan Tool. UI Impact: Workflow (Implemented) You can define links to external measures in the Quality Performance tab using Score Plan Tool. | Measures View | Verify that you can define links to external measures using Score Plan Tool. | Implementation Impact: Low Add links to external measures in the Quality Performance tab using the Score Plan tool. Maintenance Impact: None |
| Measure Domains and Domain Groups HNVBC-30171 | Component: Contract Performance You now can organize measures into domains and domain groups. UI Impact: Visual Only | Create Domains | Verify that you can organize measures into domains and domain groups. | Implementation Impact: None Maintenance Impact: None |
Parent topic: Previous Releases
