Create Domains
You can create groups of measures into domains
You can create groups of measures into a domain. A domain is a specific category or dimension of care used to evaluate, track, and improve quality. For example, you may want to create a domain of patient screening measures to track how the contract is performing against different screenings like breast cancer, diabetes, or colorectal cancer.
To create a contract domain:
- From the Contract tab, select Edit Target Plan, next to the contract for which you want to create a domain.
- Select Domains from the right side of the page. The Domains page is displayed.
- Select Add Domain.
- Enter a name for the domain and a description.
- Select Save.
Parent topic: Contract Performance
