Select a Reporting Project
Select a reporting project to view measure data based on content, measurement periods, or populations across your organization.
You can select the reporting project for which you want to view details from the Reporting Project menu. (Add screenshot)
You can access all reporting projects that your organization tracks in Quality Management through the Quality view and the Patients view. Quality Performance is the default report, and it includes the set of content your organization enabled in HealtheRegistries.
Reporting projects displayed in the menu are enabled in Console. When you access the Reporting Project menu from the Patients view, additional projects may be displayed related to Value-Based Care contracts if your organization uses Contract Performance.
For information on enabling reporting projects in Quality Performance, see the Oracle Health Quality Management Administrator Guide.
A reporting project consists of the following main properties:
  • Content (Registries and Measures)
  • Measurement Period (Calendar year versus rolling 365 days)
  • Population
The following table contains exampls of different reporting projects:
The reporting projects above apply to the same population. The Clinical Standard reporting project hosts information related to the clinical standard measures while the HEDIS MY2025 includes all HEDIS MY2025 measures. Access to multiple reporting projects allows you to view content from various catalogs in the same workflow and application.
