Suppress Conditions
Suppress hierarchical condition categories.
You can remove conditions from the coding gap list that you believe are included in error or that have been resolved. Once removed, the suppressed conditions are displayed below the active conditions, and can be moved back the active condition list.
To suppress a condition from the coding gap list:
To move a suppressed condition to the list of active conditions:
- Select the ellipses button (...) next to the condition you want to move.
- Select Undo Disagree with suspected. The suppressed condition is moved back to the active conditions list.
Parent topic: Population AI Assistant
