Make Reporting Projects Available in Oracle Health Quality Management
Update the availability of reporting projects in Quality Management.
Members of the quality_measure_administrators personnel group can update Console to make reporting projects available in Oracle Health Quality Management.
To make a reporting project viewable in Oracle Health Quality Management:
- In Console, access the Value Optimization section, then select Quality Performance.
- From the column on the right, select the ellipsis (…) to update the status of a report. If a report is already viewable, you can select an option to make it the default report that is displayed when you open Quality Performance. In Quality Performance, the reports are available from the Reporting Project menu.
Parent topic: Quality Performance
