mlflow
Provider: Databricks
Component(s): mlflow
Copyright 2018 Databricks, Inc. All rights reserved.
Apache License
Version 2.0, January 2004
http://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
(a) You must give any other recipients of the Work or
Derivative Works a copy of this License; and
(b) You must cause any modified files to carry prominent notices
stating that You changed the files; and
(c) You must retain, in the Source form of any Derivative Works
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
excluding those notices that do not pertain to any part of
the Derivative Works; and
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
include a readable copy of the attribution notices contained
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
of the following places: within a NOTICE text file distributed
as part of the Derivative Works; within the Source form or
documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and
wherever such third-party notices normally appear. The contents
of the NOTICE file are for informational purposes only and
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
or as an addendum to the NOTICE text from the Work, provided
that such additional attribution notices cannot be construed
as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!) The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
Files: numpy/linalg/lapack_lite/*
License: BSD-3-Clause
Copyright (c) 1992-2013 The University of Tennessee and The University
of Tennessee Research Foundation. All rights
reserved.
Copyright (c) 2000-2013 The University of California Berkeley. All
rights reserved.
Copyright (c) 2006-2013 The University of Colorado Denver. All rights
reserved.
$COPYRIGHT$
Additional copyrights may follow
$HEADER$
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are
met:
- Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer listed
in this license in the documentation and/or other materials
provided with the distribution.
- Neither the name of the copyright holders nor the names of its
contributors may be used to endorse or promote products derived from
this software without specific prior written permission.
The copyright holders provide no reassurances that the source code
provided does not infringe any patent, copyright, or any other
intellectual property rights of third parties. The copyright holders
disclaim any liability to any recipient for claims brought against
recipient by any third party for infringement of that parties
intellectual property rights.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Files: numpy/_core/src/multiarray/dragon4.c
License: MIT
* Copyright (c) 2014 Ryan Juckett
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to
* deal in the Software without restriction, including without limitation the
* rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
* sell copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
* IN THE SOFTWARE.
* This file contains a modified version of Ryan Juckett's Dragon4
* implementation, obtained from https://www.ryanjuckett.com,
* which has been ported from C++ to C and which has
* modifications specific to printing floats in numpy.
* Ryan Juckett's original code was under the Zlib license; he gave numpy
* permission to include it under the MIT license instead.
Files: numpy/_core/include/numpy/libdivide/*
License: Zlib
zlib License
Copyright (C) 2010 - 2019 ridiculous_fish, <libdivide@ridiculousfish.com>
Copyright (C) 2016 - 2019 Kim Walisch, <kim.walisch@gmail.com>
This software is provided 'as-is', without any express or implied
warranty. In no event will the authors be held liable for any damages
arising from the use of this software.
Permission is granted to anyone to use this software for any purpose,
including commercial applications, and to alter it and redistribute it
freely, subject to the following restrictions:
1. The origin of this software must not be misrepresented; you must not
claim that you wrote the original software. If you use this software
in a product, an acknowledgment in the product documentation would be
appreciated but is not required.
2. Altered source versions must be plainly marked as such, and must not be
misrepresented as being the original software.
3. This notice may not be removed or altered from any source distribution.
Files: vendored-meson/meson/*
License: Apache 2.0
Apache License
1. Definitions.
Files: .spin/cmds.py
License: BSD-3
BSD 3-Clause License
Copyright (c) 2021--2022, Scientific Python project
modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
From Numpy/random
**This software is dual-licensed under the The University of Illinois/NCSA
Open Source License (NCSA) and The 3-Clause BSD License**
# NCSA Open Source License
**Copyright (c) 2019 Kevin Sheppard. All rights reserved.**
Developed by: Kevin Sheppard (<kevin.sheppard@economics.ox.ac.uk>,
<kevin.k.sheppard@gmail.com>)
[http://www.kevinsheppard.com](http://www.kevinsheppard.com)
Permission is hereby granted, free of charge, to any person obtaining a copy of
this software and associated documentation files (the "Software"), to deal with
the Software without restriction, including without limitation the rights to
use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
of the Software, and to permit persons to whom the Software is furnished to do
list of conditions and the following disclaimers.
Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimers in the documentation and/or
Neither the names of Kevin Sheppard, nor the names of any contributors may be
used to endorse or promote products derived from this Software without specific
**THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
CONTRIBUTORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS WITH
THE SOFTWARE.**
# 3-Clause BSD License
3. Neither the name of the copyright holder nor the names of its contributors
may be used to endorse or promote products derived from this software
**THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE POSSIBILITY OF SUCH DAMAGE.**
# Components
Many parts of this module have been derived from original sources,
often the algorithm's designer. Component licenses are located with
the component code.
OpenBLAS License
Copyright (c) 2011-2014, The OpenBLAS Project
met:
notice, this list of conditions and the following disclaimer in
the documentation and/or other materials provided with the
distribution.
3. Neither the name of the OpenBLAS project nor the names of
its contributors may be used to endorse or promote products
derived from this software without specific prior written
permission.
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
---------------------------- Fourth-party information ----------------------
== alembic
== MIT License
Copyright 2009-2023 Michael Bayer.
this software and associated documentation files (the "Software"), to deal in
The above copyright notice and this permission notice shall be included in all
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
--------------------------------(separator)---------------------------------
== blinker
== MIT License
Copyright 2010 Jason Kirtland
copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
in all copies or substantial portions of the Software.
OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
== certifi
== MPL-2.0
This package contains a modified version of ca-bundle.crt:
ca-bundle.crt -- Bundle of CA Root Certificates
This is a bundle of X.509 certificates of public Certificate Authorities
(CA). These were automatically extracted from Mozilla's root certificates
file (certdata.txt). This file can be found in the mozilla source tree:
https://hg.mozilla.org/mozilla-central/file/tip/security/nss/lib/ckfw/builtins/certdata.txt
It contains the certificates in PEM format and therefore
can be directly used with curl / libcurl / php_curl, or with
an Apache+mod_ssl webserver for SSL client authentication.
Just configure this file as the SSLCACertificateFile.#
***** BEGIN LICENSE BLOCK *****
This Source Code Form is subject to the terms of the Mozilla Public License,
v. 2.0. If a copy of the MPL was not distributed with this file, You can obtain
one at http://mozilla.org/MPL/2.0/.
***** END LICENSE BLOCK *****
@(#) $RCSfile: certdata.txt,v $ $Revision: 1.80 $ $Date: 2011/11/03 15:11:58 $
.Mozilla Public License
Version 2.0
1. Definitions
1.1. “Contributor”
means each individual or legal entity that creates, contributes to the creation of, or owns Covered Software.
1.2. “Contributor Version”
means the combination of the Contributions of others (if any) used by a Contributor and that particular Contributor’s Contribution.
1.3. “Contribution”
means Covered Software of a particular Contributor.
1.4. “Covered Software”
means Source Code Form to which the initial Contributor has attached the notice in Exhibit A, the Executable Form of such Source Code Form, and Modifications of such Source Code Form, in each case including portions thereof.
1.5. “Incompatible With Secondary Licenses”
means
that the initial Contributor has attached the notice described in Exhibit B to the Covered Software; or
that the Covered Software was made available under the terms of version 1.1 or earlier of the License, but not also under the terms of a Secondary License.
1.6. “Executable Form”
means any form of the work other than Source Code Form.
1.7. “Larger Work”
means a work that combines Covered Software with other material, in a separate file or files, that is not Covered Software.
1.8. “License”
means this document.
1.9. “Licensable”
means having the right to grant, to the maximum extent possible, whether at the time of the initial grant or subsequently, any and all of the rights conveyed by this License.
1.10. “Modifications”
means any of the following:
any file in Source Code Form that results from an addition to, deletion from, or modification of the contents of Covered Software; or
any new file in Source Code Form that contains any Covered Software.
1.11. “Patent Claims” of a Contributor
means any patent claim(s), including without limitation, method, process, and apparatus claims, in any patent Licensable by such Contributor that would be infringed, but for the grant of the License, by the making, using, selling, offering for sale, having made, import, or transfer of either its Contributions or its Contributor Version.
1.12. “Secondary License”
means either the GNU General Public License, Version 2.0, the GNU Lesser General Public License, Version 2.1, the GNU Affero General Public License, Version 3.0, or any later versions of those licenses.
1.13. “Source Code Form”
means the form of the work preferred for making modifications.
1.14. “You” (or “Your”)
means an individual or a legal entity exercising rights under this License. For legal entities, “You” includes any entity that controls, is controlled by, or is under common control with You. For purposes of this definition, “control” means (a) the power, direct or indirect, to cause the direction or management of such entity, whether by contract or otherwise, or (b) ownership of more than fifty percent (50%) of the outstanding shares or beneficial ownership of such entity.
2. License Grants and Conditions
2.1. Grants
Each Contributor hereby grants You a world-wide, royalty-free, non-exclusive license:
under intellectual property rights (other than patent or trademark) Licensable by such Contributor to use, reproduce, make available, modify, display, perform, distribute, and otherwise exploit its Contributions, either on an unmodified basis, with Modifications, or as part of a Larger Work; and
under Patent Claims of such Contributor to make, use, sell, offer for sale, have made, import, and otherwise transfer either its Contributions or its Contributor Version.
2.2. Effective Date
The licenses granted in Section 2.1 with respect to any Contribution become effective for each Contribution on the date the Contributor first distributes such Contribution.
2.3. Limitations on Grant Scope
The licenses granted in this Section 2 are the only rights granted under this License. No additional rights or licenses will be implied from the distribution or licensing of Covered Software under this License. Notwithstanding Section 2.1(b) above, no patent license is granted by a Contributor:
for any code that a Contributor has removed from Covered Software; or
for infringements caused by: (i) Your and any other third party’s modifications of Covered Software, or (ii) the combination of its Contributions with other software (except as part of its Contributor Version); or
under Patent Claims infringed by Covered Software in the absence of its Contributions.
This License does not grant any rights in the trademarks, service marks, or logos of any Contributor (except as may be necessary to comply with the notice requirements in Section 3.4).
2.4. Subsequent Licenses
No Contributor makes additional grants as a result of Your choice to distribute the Covered Software under a subsequent version of this License (see Section 10.2) or under the terms of a Secondary License (if permitted under the terms of Section 3.3).
2.5. Representation
Each Contributor represents that the Contributor believes its Contributions are its original creation(s) or it has sufficient rights to grant the rights to its Contributions conveyed by this License.
2.6. Fair Use
This License is not intended to limit any rights You have under applicable copyright doctrines of fair use, fair dealing, or other equivalents.
2.7. Conditions
Sections 3.1, 3.2, 3.3, and 3.4 are conditions of the licenses granted in Section 2.1.
3. Responsibilities
3.1. Distribution of Source Form
All distribution of Covered Software in Source Code Form, including any Modifications that You create or to which You contribute, must be under the terms of this License. You must inform recipients that the Source Code Form of the Covered Software is governed by the terms of this License, and how they can obtain a copy of this License. You may not attempt to alter or restrict the recipients’ rights in the Source Code Form.
3.2. Distribution of Executable Form
If You distribute Covered Software in Executable Form then:
such Covered Software must also be made available in Source Code Form, as described in Section 3.1, and You must inform recipients of the Executable Form how they can obtain a copy of such Source Code Form by reasonable means in a timely manner, at a charge no more than the cost of distribution to the recipient; and
You may distribute such Executable Form under the terms of this License, or sublicense it under different terms, provided that the license for the Executable Form does not attempt to limit or alter the recipients’ rights in the Source Code Form under this License.
3.3. Distribution of a Larger Work
You may create and distribute a Larger Work under terms of Your choice, provided that You also comply with the requirements of this License for the Covered Software. If the Larger Work is a combination of Covered Software with a work governed by one or more Secondary Licenses, and the Covered Software is not Incompatible With Secondary Licenses, this License permits You to additionally distribute such Covered Software under the terms of such Secondary License(s), so that the recipient of the Larger Work may, at their option, further distribute the Covered Software under the terms of either this License or such Secondary License(s).
3.4. Notices
You may not remove or alter the substance of any license notices (including copyright notices, patent notices, disclaimers of warranty, or limitations of liability) contained within the Source Code Form of the Covered Software, except that You may alter any license notices to the extent required to remedy known factual inaccuracies.
3.5. Application of Additional Terms
You may choose to offer, and to charge a fee for, warranty, support, indemnity or liability obligations to one or more recipients of Covered Software. However, You may do so only on Your own behalf, and not on behalf of any Contributor. You must make it absolutely clear that any such warranty, support, indemnity, or liability obligation is offered by You alone, and You hereby agree to indemnify every Contributor for any liability incurred by such Contributor as a result of warranty, support, indemnity or liability terms You offer. You may include additional disclaimers of warranty and limitations of liability specific to any jurisdiction.
4. Inability to Comply Due to Statute or Regulation
If it is impossible for You to comply with any of the terms of this License with respect to some or all of the Covered Software due to statute, judicial order, or regulation then You must: (a) comply with the terms of this License to the maximum extent possible; and (b) describe the limitations and the code they affect. Such description must be placed in a text file included with all distributions of the Covered Software under this License. Except to the extent prohibited by statute or regulation, such description must be sufficiently detailed for a recipient of ordinary skill to be able to understand it.
5. Termination
5.1. The rights granted under this License will terminate automatically if You fail to comply with any of its terms. However, if You become compliant, then the rights granted under this License from a particular Contributor are reinstated (a) provisionally, unless and until such Contributor explicitly and finally terminates Your grants, and (b) on an ongoing basis, if such Contributor fails to notify You of the non-compliance by some reasonable means prior to 60 days after You have come back into compliance. Moreover, Your grants from a particular Contributor are reinstated on an ongoing basis if such Contributor notifies You of the non-compliance by some reasonable means, this is the first time You have received notice of non-compliance with this License from such Contributor, and You become compliant prior to 30 days after Your receipt of the notice.
5.2. If You initiate litigation against any entity by asserting a patent infringement claim (excluding declaratory judgment actions, counter-claims, and cross-claims) alleging that a Contributor Version directly or indirectly infringes any patent, then the rights granted to You by any and all Contributors for the Covered Software under Section 2.1 of this License shall terminate.
5.3. In the event of termination under Sections 5.1 or 5.2 above, all end user license agreements (excluding distributors and resellers) which have been validly granted by You or Your distributors under this License prior to termination shall survive termination.
6. Disclaimer of Warranty
Covered Software is provided under this License on an “as is” basis, without warranty of any kind, either expressed, implied, or statutory, including, without limitation, warranties that the Covered Software is free of defects, merchantable, fit for a particular purpose or non-infringing. The entire risk as to the quality and performance of the Covered Software is with You. Should any Covered Software prove defective in any respect, You (not any Contributor) assume the cost of any necessary servicing, repair, or correction. This disclaimer of warranty constitutes an essential part of this License. No use of any Covered Software is authorized under this License except under this disclaimer.
7. Limitation of Liability
Under no circumstances and under no legal theory, whether tort (including negligence), contract, or otherwise, shall any Contributor, or anyone who distributes Covered Software as permitted above, be liable to You for any direct, indirect, special, incidental, or consequential damages of any character including, without limitation, damages for lost profits, loss of goodwill, work stoppage, computer failure or malfunction, or any and all other commercial damages or losses, even if such party shall have been informed of the possibility of such damages. This limitation of liability shall not apply to liability for death or personal injury resulting from such party’s negligence to the extent applicable law prohibits such limitation. Some jurisdictions do not allow the exclusion or limitation of incidental or consequential damages, so this exclusion and limitation may not apply to You.
8. Litigation
Any litigation relating to this License may be brought only in the courts of a jurisdiction where the defendant maintains its principal place of business and such litigation shall be governed by laws of that jurisdiction, without reference to its conflict-of-law provisions. Nothing in this Section shall prevent a party’s ability to bring cross-claims or counter-claims.
9. Miscellaneous
This License represents the complete agreement concerning the subject matter hereof. If any provision of this License is held to be unenforceable, such provision shall be reformed only to the extent necessary to make it enforceable. Any law or regulation which provides that the language of a contract shall be construed against the drafter shall not be used to construe this License against a Contributor.
10. Versions of the License
10.1. New Versions
Mozilla Foundation is the license steward. Except as provided in Section 10.3, no one other than the license steward has the right to modify or publish new versions of this License. Each version will be given a distinguishing version number.
10.2. Effect of New Versions
You may distribute the Covered Software under the terms of the version of the License under which You originally received the Covered Software, or under the terms of any subsequent version published by the license steward.
10.3. Modified Versions
If you create software not governed by this License, and you want to create a new license for such software, you may create and use a modified version of this License if you rename the license and remove any references to the name of the license steward (except to note that such modified license differs from this License).
10.4. Distributing Source Code Form that is Incompatible With Secondary Licenses
If You choose to distribute Source Code Form that is Incompatible With Secondary Licenses under the terms of this version of the License, the notice described in Exhibit B of this License must be attached.
Exhibit A - Source Code Form License Notice
This Source Code Form is subject to the terms of the Mozilla Public License, v. 2.0. If a copy of the MPL was not distributed with this file, You can obtain one at https://mozilla.org/MPL/2.0/.
If it is not possible or desirable to put the notice in a particular file, then You may include the notice in a location (such as a LICENSE file in a relevant directory) where a recipient would be likely to look for such a notice.
You may add additional accurate notices of copyright ownership.
Exhibit B - “Incompatible With Secondary Licenses” Notice
This Source Code Form is “Incompatible With Secondary Licenses”, as defined by the Mozilla Public License, v. 2.0.
== charset-normalizer
== MIT
MIT License
Copyright (c) 2019 TAHRI Ahmed R.
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
SOFTWARE.
== click
== BSD-3-Clause
Copyright 2014 Pallets
met:
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
== cloudpickle
== BSD 3-Clause License
This module was extracted from the `cloud` package, developed by
PiCloud, Inc.
Copyright (c) 2015, Cloudpickle contributors.
Copyright (c) 2012, Regents of the University of California.
Copyright (c) 2009 PiCloud, Inc. http://www.picloud.com.
are met:
* Redistributions of source code must retain the above copyright
* Redistributions in binary form must reproduce the above copyright
* Neither the name of the University of California, Berkeley nor the
names of its contributors may be used to endorse or promote
products derived from this software without specific prior written
permission.
== cycler
== BSD
Copyright (c) 2015, matplotlib project
* Redistributions of source code must retain the above copyright notice, this
* Redistributions in binary form must reproduce the above copyright notice,
* Neither the name of the matplotlib project nor the names of its
== databricks-cli
== Apache License 2.0
Databricks CLI (the "Software")
The Software consists of a Work (as defined below) subject to the Apache License Version 2, but in order to use certain application programming interfaces (each, an "API") within the Software, the user of the Software ("Licensee")must obtain a license for the use of the API from Databricks, Inc. ("Databricks"), by creating an account at www.databricks.com and agreeing to either (a) the Community Edition Terms of Service, (b) the Databricks Terms of Service, or (c) another written agreement between Licensee and Databricks for the use of the Software.
Apache License
httpwww.apache.orglicenses
1. Definitions.
License shall mean the terms and conditions for use, reproduction,
Licensor shall mean the copyright owner or entity authorized by
Legal Entity shall mean the union of the acting entity and all
control means (i) the power, direct or indirect, to cause the
You (or Your) shall mean an individual or Legal Entity
Source form shall mean the preferred form for making modifications,
Object form shall mean any form resulting from mechanical
Work shall mean the work of authorship, whether in Source or
Derivative Works shall mean any work, whether in Source or Object
Contribution shall mean any work of authorship, including
the copyright owner. For the purposes of this definition, submitted
designated in writing by the copyright owner as Not a Contribution.
Contributor shall mean Licensor and any individual or Legal Entity
(d) If the Work includes a NOTICE text file as part of its
of the following places within a NOTICE text file distributed
Contributor provides its Contributions) on an AS IS BASIS,
or other liability obligations andor rights consistent with this
Copyright 2017 Databricks, Inc.
Licensed under the Apache License, Version 2.0 (the License);
distributed under the License is distributed on an AS IS BASIS,
== fonttools
== MIT
MIT License
Copyright (c) 2017 Just van Rossum
SOFTWARE.
== greenlet
== MIT License
The following files are derived from Stackless Python and are subject to the
same license as Stackless Python:
src/greenlet/slp_platformselect.h
files in src/greenlet/platform/ directory
See LICENSE.PSF and http://www.stackless.com/ for details.
Unless otherwise noted, the files in greenlet have been released under the
following MIT license:
Copyright (c) Armin Rigo, Christian Tismer and contributors
THE SOFTWARE.
== gunicorn
== MIT
2009-2023 (c) Benoît Chesneau <benoitc@gunicorn.org>
2009-2015 (c) Paul J. Davis <paul.joseph.davis@gmail.com>
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
Software is furnished to do so, subject to the following
conditions:
included in all copies or substantial portions of the Software.
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
== joblib
== BSD 3-Clause
Copyright (c) 2008-2021, The joblib developers.
* Neither the name of the copyright holder nor the names of its
== mako
== MIT
Copyright 2006-2023 the Mako authors and contributors <see AUTHORS file>.
SOFTWARE.
== pyarrow
== Apache License, Version 2.0
Apache License
1. Definitions.
src/arrow/util (some portions): Apache 2.0, and 3-clause BSD
Some portions of this module are derived from code in the Chromium project,
copyright (c) Google inc and (c) The Chromium Authors and licensed under the
Apache 2.0 License or the under the 3-clause BSD license:
Copyright (c) 2013 The Chromium Authors. All rights reserved.
met:
copyright notice, this list of conditions and the following disclaimer
in the documentation and/or other materials provided with the
distribution.
* Neither the name of Google Inc. nor the names of its
This project includes code from Daniel Lemire's FrameOfReference project.
https://github.com/lemire/FrameOfReference/blob/6ccaf9e97160f9a3b299e23a8ef739e711ef0c71/src/bpacking.cpp
https://github.com/lemire/FrameOfReference/blob/146948b6058a976bc7767262ad3a2ce201486b93/scripts/turbopacking64.py
Copyright: 2013 Daniel Lemire
Home page: http://lemire.me/en/
Project page: https://github.com/lemire/FrameOfReference
License: Apache License Version 2.0 http://www.apache.org/licenses/LICENSE-2.0
This project includes code from the TensorFlow project
Copyright 2015 The TensorFlow Authors. All Rights Reserved.
This project includes code from the NumPy project.
https://github.com/numpy/numpy/blob/e1f191c46f2eebd6cb892a4bfe14d9dd43a06c4e/numpy/core/src/multiarray/multiarraymodule.c#L2910
https://github.com/numpy/numpy/blob/68fd82271b9ea5a9e50d4e761061dfcca851382a/numpy/core/src/multiarray/datetime.c
Copyright (c) 2005-2017, NumPy Developers.
met:
disclaimer in the documentation and/or other materials provided
* Neither the name of the NumPy Developers nor the names of any
from this software without specific prior written permission.
This project includes code from the Boost project
Boost Software License - Version 1.0 - August 17th, 2003
Permission is hereby granted, free of charge, to any person or organization
obtaining a copy of the software and accompanying documentation covered by
this license (the "Software") to use, reproduce, display, distribute,
execute, and transmit the Software, and to prepare derivative works of the
Software, and to permit third-parties to whom the Software is furnished to
do so, all subject to the following:
The copyright notices in the Software and this entire statement, including
the above license grant, this restriction and the following disclaimer,
must be included in all copies of the Software, in whole or in part, and
all derivative works of the Software, unless such copies or derivative
works are solely in the form of machine-executable object code generated by
a source language processor.
FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT
SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE
FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE,
ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
This project includes code from the FlatBuffers project
Copyright 2014 Google Inc.
This project includes code from the tslib project
Copyright 2015 Microsoft Corporation. All rights reserved.
This project includes code from the jemalloc project
https://github.com/jemalloc/jemalloc
Copyright (C) 2002-2017 Jason Evans <jasone@canonware.com>.
Copyright (C) 2007-2012 Mozilla Foundation. All rights reserved.
Copyright (C) 2009-2017 Facebook, Inc. All rights reserved.
1. Redistributions of source code must retain the above copyright notice(s),
2. Redistributions in binary form must reproduce the above copyright notice(s),
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER(S) ``AS IS'' AND ANY EXPRESS
OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
EVENT SHALL THE COPYRIGHT HOLDER(S) BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
This project includes code from the Go project, BSD 3-clause license + PATENTS
weak patent termination clause
(https://github.com/golang/go/blob/master/PATENTS).
Copyright (c) 2009 The Go Authors. All rights reserved.
met:
distribution.
This project includes code from the hs2client
https://github.com/cloudera/hs2client
Copyright 2016 Cloudera Inc.
The script ci/scripts/util_wait_for_it.sh has the following license
Copyright (c) 2016 Giles Hall
SOFTWARE.
The script r/configure has the following license (MIT)
Copyright (c) 2017, Jeroen Ooms and Jim Hester
SOFTWARE.
cpp/src/arrow/util/logging.cc, cpp/src/arrow/util/logging.h and
cpp/src/arrow/util/logging-test.cc are adapted from
Ray Project (https://github.com/ray-project/ray) (Apache 2.0).
Copyright (c) 2016 Ray Project (https://github.com/ray-project/ray)
The files cpp/src/arrow/vendored/datetime/date.h, cpp/src/arrow/vendored/datetime/tz.h,
cpp/src/arrow/vendored/datetime/tz_private.h, cpp/src/arrow/vendored/datetime/ios.h,
cpp/src/arrow/vendored/datetime/ios.mm,
cpp/src/arrow/vendored/datetime/tz.cpp are adapted from
Howard Hinnant's date library (https://github.com/HowardHinnant/date)
It is licensed under MIT license.
The MIT License (MIT)
Copyright (c) 2015, 2016, 2017 Howard Hinnant
Copyright (c) 2016 Adrian Colomitchi
Copyright (c) 2017 Florian Dang
Copyright (c) 2017 Paul Thompson
Copyright (c) 2018 Tomasz Kamiński
SOFTWARE.
The file cpp/src/arrow/util/utf8.h includes code adapted from the page
https://bjoern.hoehrmann.de/utf-8/decoder/dfa/
with the following license (MIT)
Copyright (c) 2008-2009 Bjoern Hoehrmann <bjoern@hoehrmann.de>
SOFTWARE.
The files in cpp/src/arrow/vendored/xxhash/ have the following license
(BSD 2-Clause License)
xxHash Library
Copyright (c) 2012-2014, Yann Collet
Redistribution and use in source and binary forms, with or without modification,
* Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
You can contact the author at :
- xxHash homepage: http://www.xxhash.com
- xxHash source repository : https://github.com/Cyan4973/xxHash
The files in cpp/src/arrow/vendored/double-conversion/ have the following license
(BSD 3-Clause License)
Copyright 2006-2011, the V8 project authors. All rights reserved.
met:
The files in cpp/src/arrow/vendored/uriparser/ have the following license
uriparser - RFC 3986 URI parsing library
Copyright (C) 2007, Weijia Song <songweijia@gmail.com>
Copyright (C) 2007, Sebastian Pipping <sebastian@pipping.org>
are met:
disclaimer.
* Neither the name of the <ORGANIZATION> nor the names of its
permission.
FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
The files under dev/tasks/conda-recipes have the following license
Copyright (c) 2015-2018, conda-forge
may be used to endorse or promote products derived from this software without
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
The files in cpp/src/arrow/vendored/utfcpp/ have the following license
Copyright 2006-2018 Nemanja Trifunovic
This project includes code from Apache Kudu.
* cpp/cmake_modules/CompilerInfo.cmake is based on Kudu's cmake_modules/CompilerInfo.cmake
Copyright: 2016 The Apache Software Foundation.
Home page: https://kudu.apache.org/
License: http://www.apache.org/licenses/LICENSE-2.0
This project includes code from Apache Impala (incubating), formerly
Impala. The Impala code and rights were donated to the ASF as part of the
Incubator process after the initial code imports into Apache Parquet.
Copyright: 2012 Cloudera, Inc.
Home page: http://impala.apache.org/
This project includes code from Apache Aurora.
* dev/release/{release,changelog,release-candidate} are based on the scripts from
Apache Aurora
Home page: https://aurora.apache.org/
This project includes code from the Google styleguide.
* cpp/build-support/cpplint.py is based on the scripts from the Google styleguide.
Copyright: 2009 Google Inc. All rights reserved.
Homepage: https://github.com/google/styleguide
License: 3-clause BSD
This project includes code from Snappy.
* cpp/cmake_modules/{SnappyCMakeLists.txt,SnappyConfig.h} are based on code
from Google's Snappy project.
Homepage: https://github.com/google/snappy
This project includes code from the manylinux project.
* python/manylinux1/scripts/{build_python.sh,python-tag-abi-tag.py,
requirements.txt} are based on code from the manylinux project.
Copyright: 2016 manylinux
Homepage: https://github.com/pypa/manylinux
License: The MIT License (MIT)
This project includes code from the cymove project:
* python/pyarrow/includes/common.pxd includes code from the cymove project
Copyright (c) 2019 Omer Ozarslan
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE
The projects includes code from the Ursabot project under the dev/archery
directory.
License: BSD 2-Clause
Copyright 2019 RStudio, Inc.
This project include code from mingw-w64.
* cpp/src/arrow/util/cpu-info.cc has a polyfill for mingw-w64 < 5
Copyright (c) 2009 - 2013 by the mingw-w64 project
Homepage: https://mingw-w64.org
License: Zope Public License (ZPL) Version 2.1.
This project include code from Google's Asylo project.
* cpp/src/arrow/result.h is based on status_or.h
Copyright (c) Copyright 2017 Asylo authors
Homepage: https://asylo.dev/
License: Apache 2.0
This project includes code from Google's protobuf project
* cpp/src/arrow/result.h ARROW_ASSIGN_OR_RAISE is based off ASSIGN_OR_RETURN
* cpp/src/arrow/util/bit_stream_utils.h contains code from wire_format_lite.h
Copyright 2008 Google Inc. All rights reserved.
Homepage: https://developers.google.com/protocol-buffers/
License:
met:
distribution.
Code generated by the Protocol Buffer compiler is owned by the owner
of the input file used when generating it. This code is not
standalone and requires a support library to be linked with it. This
support library is itself covered by the above license.
3rdparty dependency LLVM is statically linked in certain binary distributions.
Additionally some sections of source code have been derived from sources in LLVM
and have been clearly labeled as such. LLVM has the following license:
The LLVM Project is under the Apache License v2.0 with LLVM Exceptions:
Apache License
1. Definitions.
---- LLVM Exceptions to the Apache 2.0 License ----
As an exception, if, as a result of your compiling your source code, portions
of this Software are embedded into an Object form of such source code, you
may redistribute such embedded portions in such Object form without complying
with the conditions of Sections 4(a), 4(b) and 4(d) of the License.
In addition, if you combine or link compiled forms of this Software with
software that is licensed under the GPLv2 ("Combined Software") and if a
court of competent jurisdiction determines that the patent provision (Section
3), the indemnity provision (Section 9) or other Section of the License
conflicts with the conditions of the GPLv2, you may retroactively and
prospectively choose to deem waived or otherwise exclude such Section(s) of
the License, but only in their entirety and only with respect to the Combined
Software.
Software from third parties included in the LLVM Project:
The LLVM Project contains third party software which is under different license
terms. All such code will be identified clearly using at least one of two
mechanisms:
1) It will be in a separate directory tree with its own `LICENSE.txt` or
`LICENSE` file at the top containing the specific license and restrictions
which apply to that software, or
2) It will contain specific license and restriction terms at the top of every
file.
3rdparty dependency gRPC is statically linked in certain binary
distributions, like the python wheels. gRPC has the following license:
Copyright 2014 gRPC authors.
3rdparty dependency Apache Thrift is statically linked in certain binary
distributions, like the python wheels. Apache Thrift has the following license:
Apache Thrift
Copyright (C) 2006 - 2019, The Apache Software Foundation
This product includes software developed at
The Apache Software Foundation (http://www.apache.org/).
3rdparty dependency Apache ORC is statically linked in certain binary
distributions, like the python wheels. Apache ORC has the following license:
Apache ORC
Copyright 2013-2019 The Apache Software Foundation
This product includes software developed by The Apache Software
This product includes software developed by Hewlett-Packard:
(c) Copyright [2014-2015] Hewlett-Packard Development Company, L.P
3rdparty dependency zstd is statically linked in certain binary
distributions, like the python wheels. ZSTD has the following license:
BSD License
For Zstandard software
Copyright (c) 2016-present, Facebook, Inc. All rights reserved.
* Neither the name Facebook nor the names of its contributors may be used to
endorse or promote products derived from this software without specific
3rdparty dependency lz4 is statically linked in certain binary
distributions, like the python wheels. lz4 has the following license:
LZ4 Library
Copyright (c) 2011-2016, Yann Collet
3rdparty dependency Brotli is statically linked in certain binary
distributions, like the python wheels. Brotli has the following license:
Copyright (c) 2009, 2010, 2013-2016 by the Brotli Authors.
THE SOFTWARE.
3rdparty dependency rapidjson is statically linked in certain binary
distributions, like the python wheels. rapidjson and its dependencies have the
following licenses:
Tencent is pleased to support the open source community by making RapidJSON
available.
Copyright (C) 2015 THL A29 Limited, a Tencent company, and Milo Yip.
If you have downloaded a copy of the RapidJSON binary from Tencent, please note
that the RapidJSON binary is licensed under the MIT License.
If you have downloaded a copy of the RapidJSON source code from Tencent, please
note that RapidJSON source code is licensed under the MIT License, except for
the third-party components listed below which are subject to different license
terms. Your integration of RapidJSON into your own projects may require
compliance with the MIT License, as well as the other licenses applicable to
the third-party components included within RapidJSON. To avoid the problematic
JSON license in your own projects, it's sufficient to exclude the
bin/jsonchecker/ directory, as it's the only code under the JSON license.
A copy of the MIT License is included in this file.
Other dependencies and licenses:
Open Source Software Licensed Under the BSD License:
The msinttypes r29
Copyright (c) 2006-2013 Alexander Chemeris
* Neither the name of copyright holder nor the names of its contributors
THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND ANY
DISCLAIMED. IN NO EVENT SHALL THE REGENTS AND CONTRIBUTORS BE LIABLE FOR
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
DAMAGE.
Terms of the MIT License:
copy of this software and associated documentation files (the "Software"),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
3rdparty dependency snappy is statically linked in certain binary
distributions, like the python wheels. snappy has the following license:
Copyright 2011, Google Inc.
met:
* Neither the name of Google Inc. nor the names of its contributors may be
Some of the benchmark data in testdata/ is licensed differently:
- fireworks.jpeg is Copyright 2013 Steinar H. Gunderson, and
is licensed under the Creative Commons Attribution 3.0 license
(CC-BY-3.0). See https://creativecommons.org/licenses/by/3.0/
for more information.
- kppkn.gtb is taken from the Gaviota chess tablebase set, and
is licensed under the MIT License. See
https://sites.google.com/site/gaviotachessengine/Home/endgame-tablebases-1
- paper-100k.pdf is an excerpt (bytes 92160 to 194560) from the paper
“Combinatorial Modeling of Chromatin Features Quantitatively Predicts DNA
Replication Timing in _Drosophila_” by Federico Comoglio and Renato Paro,
which is licensed under the CC-BY license. See
http://www.ploscompbiol.org/static/license for more ifnormation.
- alice29.txt, asyoulik.txt, plrabn12.txt and lcet10.txt are from Project
Gutenberg. The first three have expired copyrights and are in the public
domain; the latter does not have expired copyright, but is still in the
public domain according to the license information
(http://www.gutenberg.org/ebooks/53).
3rdparty dependency gflags is statically linked in certain binary
distributions, like the python wheels. gflags has the following license:
Copyright (c) 2006, Google Inc.
met:
distribution.
3rdparty dependency glog is statically linked in certain binary
distributions, like the python wheels. glog has the following license:
Copyright (c) 2008, Google Inc.
met:
distribution.
A function gettimeofday in utilities.cc is based on
http://www.google.com/codesearch/p?hl=en#dR3YEbitojA/COPYING&q=GetSystemTimeAsFileTime%20license:bsd
The license of this code is:
Copyright (c) 2003-2008, Jouni Malinen <j@w1.fi> and contributors
met:
3. Neither the name(s) of the above-listed copyright holder(s) nor the
names of its contributors may be used to endorse or promote products
derived from this software without specific prior written permission.
3rdparty dependency re2 is statically linked in certain binary
distributions, like the python wheels. re2 has the following license:
Copyright (c) 2009 The RE2 Authors. All rights reserved.
met:
3rdparty dependency c-ares is statically linked in certain binary
distributions, like the python wheels. c-ares has the following license:
# c-ares license
Copyright (c) 2007 - 2018, Daniel Stenberg with many contributors, see AUTHORS
file.
Copyright 1998 by the Massachusetts Institute of Technology.
Permission to use, copy, modify, and distribute this software and its
documentation for any purpose and without fee is hereby granted, provided that
the above copyright notice appear in all copies and that both that copyright
notice and this permission notice appear in supporting documentation, and that
the name of M.I.T. not be used in advertising or publicity pertaining to
distribution of the software without specific, written prior permission.
M.I.T. makes no representations about the suitability of this software for any
purpose. It is provided "as is" without express or implied warranty.
3rdparty dependency zlib is redistributed as a dynamically linked shared
library in certain binary distributions, like the python wheels. In the future
this will likely change to static linkage. zlib has the following license:
zlib.h -- interface of the 'zlib' general purpose compression library
version 1.2.11, January 15th, 2017
Copyright (C) 1995-2017 Jean-loup Gailly and Mark Adler
Jean-loup Gailly Mark Adler
jloup@gzip.org madler@alumni.caltech.edu
3rdparty dependency openssl is redistributed as a dynamically linked shared
library in certain binary distributions, like the python wheels. openssl
preceding version 3 has the following license:
LICENSE ISSUES
The OpenSSL toolkit stays under a double license, i.e. both the conditions of
the OpenSSL License and the original SSLeay license apply to the toolkit.
See below for the actual license texts.
OpenSSL License
* Copyright (c) 1998-2019 The OpenSSL Project. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. All advertising materials mentioning features or use of this
* software must display the following acknowledgment:
* "This product includes software developed by the OpenSSL Project
* for use in the OpenSSL Toolkit. (http://www.openssl.org/)"
* 4. The names "OpenSSL Toolkit" and "OpenSSL Project" must not be used to
* endorse or promote products derived from this software without
* prior written permission. For written permission, please contact
* openssl-core@openssl.org.
* 5. Products derived from this software may not be called "OpenSSL"
* nor may "OpenSSL" appear in their names without prior written
* permission of the OpenSSL Project.
* 6. Redistributions of any form whatsoever must retain the following
* acknowledgment:
* for use in the OpenSSL Toolkit (http://www.openssl.org/)"
* THIS SOFTWARE IS PROVIDED BY THE OpenSSL PROJECT ``AS IS'' AND ANY
* EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE OpenSSL PROJECT OR
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
* This product includes cryptographic software written by Eric Young
* (eay@cryptsoft.com). This product includes software written by Tim
* Hudson (tjh@cryptsoft.com).
Original SSLeay License
/* Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com)
* All rights reserved.
* This package is an SSL implementation written
* by Eric Young (eay@cryptsoft.com).
* The implementation was written so as to conform with Netscapes SSL.
* This library is free for commercial and non-commercial use as long as
* the following conditions are aheared to. The following conditions
* apply to all code found in this distribution, be it the RC4, RSA,
* lhash, DES, etc., code; not just the SSL code. The SSL documentation
* included with this distribution is covered by the same copyright terms
* except that the holder is Tim Hudson (tjh@cryptsoft.com).
* Copyright remains Eric Young's, and as such any Copyright notices in
* the code are not to be removed.
* If this package is used in a product, Eric Young should be given attribution
* as the author of the parts of the library used.
* This can be in the form of a textual message at program startup or
* in documentation (online or textual) provided with the package.
* are met:
* 1. Redistributions of source code must retain the copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* 3. All advertising materials mentioning features or use of this software
* must display the following acknowledgement:
* "This product includes cryptographic software written by
* Eric Young (eay@cryptsoft.com)"
* The word 'cryptographic' can be left out if the rouines from the library
* being used are not cryptographic related :-).
* 4. If you include any Windows specific code (or a derivative thereof) from
* the apps directory (application code) you must include an acknowledgement:
* "This product includes software written by Tim Hudson (tjh@cryptsoft.com)"
* THIS SOFTWARE IS PROVIDED BY ERIC YOUNG ``AS IS'' AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
* SUCH DAMAGE.
* The licence and distribution terms for any publically available version or
* derivative of this code cannot be changed. i.e. this code cannot simply be
* copied and put under another distribution licence
* [including the GNU Public Licence.]
This project includes code from the rtools-backports project.
* ci/scripts/PKGBUILD and ci/scripts/r_windows_build.sh are based on code
Copyright: Copyright (c) 2013 - 2019, Алексей and Jeroen Ooms.
Homepage: https://github.com/r-windows/rtools-backports
Some code from pandas has been adapted for the pyarrow codebase. pandas is
available under the 3-clause BSD license, which follows:
pandas license
Copyright (c) 2011-2012, Lambda Foundry, Inc. and PyData Development Team
Copyright (c) 2008-2011 AQR Capital Management, LLC
met:
* Neither the name of the copyright holder nor the names of any
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER AND CONTRIBUTORS
Some bits from DyND, in particular aspects of the build system, have been
adapted from libdynd and dynd-python under the terms of the BSD 2-clause
license
The BSD 2-Clause License
Copyright (C) 2011-12, Dynamic NDArray Developers
met:
Dynamic NDArray Developers list:
* Mark Wiebe
* Continuum Analytics
Some source code from Ibis (https://github.com/cloudera/ibis) has been adapted
for PyArrow. Ibis is released under the Apache License, Version 2.0.
dev/tasks/homebrew-formulae/apache-arrow.rb has the following license:
Copyright (c) 2009-present, Homebrew contributors
cpp/src/arrow/vendored/base64.cpp has the following license
ZLIB License
Copyright (C) 2004-2017 René Nyffenegger
This source code is provided 'as-is', without any express or implied
warranty. In no event will the author be held liable for any damages arising
Permission is granted to anyone to use this software for any purpose, including
commercial applications, and to alter it and redistribute it freely, subject to
1. The origin of this source code must not be misrepresented; you must not
claim that you wrote the original source code. If you use this source code
misrepresented as being the original source code.
René Nyffenegger rene.nyffenegger@adp-gmbh.ch
This project includes code from Folly.
* cpp/src/arrow/vendored/ProducerConsumerQueue.h
is based on Folly's
* folly/Portability.h
* folly/lang/Align.h
* folly/ProducerConsumerQueue.h
Copyright: Copyright (c) Facebook, Inc. and its affiliates.
Home page: https://github.com/facebook/folly
The file cpp/src/arrow/vendored/musl/strptime.c has the following license
Copyright © 2005-2020 Rich Felker, et al.
a copy of this software and associated documentation files (the
The file cpp/cmake_modules/BuildUtils.cmake contains code from
https://gist.github.com/cristianadam/ef920342939a89fae3e8a85ca9459b49
which is made available under the MIT license
Copyright (c) 2019 Cristian Adam
SOFTWARE.
The files in cpp/src/arrow/vendored/portable-snippets/ contain code from
https://github.com/nemequ/portable-snippets
and have the following copyright notice:
Each source file contains a preamble explaining the license situation
for that file, which takes priority over this file. With the
exception of some code pulled in from other repositories (such as
µnit, an MIT-licensed project which is used for testing), the code is
public domain, released using the CC0 1.0 Universal dedication (*).
(*) https://creativecommons.org/publicdomain/zero/1.0/legalcode
The files in cpp/src/arrow/vendored/fast_float/ contain code from
https://github.com/lemire/fast_float
which is made available under the Apache License 2.0.
The file python/pyarrow/vendored/docscrape.py contains code from
https://github.com/numpy/numpydoc/
which is made available under the BSD 2-clause license.
The file python/pyarrow/vendored/version.py contains code from
https://github.com/pypa/packaging/
which is made available under both the Apache license v2.0 and the
The files in cpp/src/arrow/vendored/pcg contain code from
https://github.com/imneme/pcg-cpp
Copyright 2014-2019 Melissa O'Neill <oneill@pcg-random.org>,
and the PCG Project contributors.
SPDX-License-Identifier: (Apache-2.0 OR MIT)
Licensed under the Apache License, Version 2.0 (provided in
LICENSE-APACHE.txt and at http://www.apache.org/licenses/LICENSE-2.0)
or under the MIT license (provided in LICENSE-MIT.txt and at
http://opensource.org/licenses/MIT), at your option. This file may not
be copied, modified, or distributed except according to those terms.
Distributed on an "AS IS" BASIS, WITHOUT WARRANTY OF ANY KIND, either
express or implied. See your chosen license for details.
r/R/dplyr-count-tally.R (some portions)
Some portions of this file are derived from code from
https://github.com/tidyverse/dplyr/
Copyright (c) 2013-2019 RStudio and others.
this software and associated documentation files (the “Software”), to deal
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
SOFTWARE.
The file src/arrow/util/io_util.cc contains code from the CPython project
which is made available under the Python Software Foundation License Version 2.
3rdparty dependency opentelemetry-cpp is statically linked in certain binary
distributions. opentelemetry-cpp is made available under the Apache License 2.0.
Copyright The OpenTelemetry Authors
SPDX-License-Identifier: Apache-2.0
ci/conan/ is based on code from Conan Package and Dependency Manager.
Copyright (c) 2019 Conan.io
SOFTWARE.
3rdparty dependency UCX is redistributed as a dynamically linked shared
library in certain binary distributions. UCX has the following license:
Copyright (c) 2014-2015 UT-Battelle, LLC. All rights reserved.
Copyright (C) 2014-2020 Mellanox Technologies Ltd. All rights reserved.
Copyright (C) 2014-2015 The University of Houston System. All rights reserved.
Copyright (C) 2015 The University of Tennessee and The University
of Tennessee Research Foundation. All rights reserved.
Copyright (C) 2016-2020 ARM Ltd. All rights reserved.
Copyright (c) 2016 Los Alamos National Security, LLC. All rights reserved.
Copyright (C) 2016-2020 Advanced Micro Devices, Inc. All rights reserved.
Copyright (C) 2019 UChicago Argonne, LLC. All rights reserved.
Copyright (c) 2018-2020 NVIDIA CORPORATION. All rights reserved.
Copyright (C) 2020 Huawei Technologies Co., Ltd. All rights reserved.
Copyright (C) 2016-2020 Stony Brook University. All rights reserved.
are met:
contributors may be used to endorse or promote products derived from
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
The file dev/tasks/r/github.packages.yml contains code from
https://github.com/ursa-labs/arrow-r-nightly
.github/actions/sync-nightlies/action.yml (some portions)
https://github.com/JoshPiper/rsync-docker
Copyright (c) 2020 Joshua Piper
copies of the Software, and to permit persons to whom the Software is
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
SOFTWARE.
https://github.com/burnett01/rsync-deployments
Copyright (c) 2019-2022 Contention
Copyright (c) 2019-2022 Burnett01
SOFTWARE.
== sqlalchemy
== MIT
Copyright 2005-2024 SQLAlchemy authors and contributors <see AUTHORS file>.
SOFTWARE.
== tabulate
== MIT
Copyright (c) 2011-2020 Sergey Astanin and contributors
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
markupsafe
Copyright 2010 Pallets
met:
mako
Copyright 2006-2025 the Mako authors and contributors <see AUTHORS file>.
SOFTWARE.
tomli
MIT License
Copyright (c) 2021 Taneli Hukkinen
SOFTWARE.
fastapi
Copyright (c) 2018 Sebastián Ramírez
THE SOFTWARE.
starlette
Copyright © 2018, Encode OSS Ltd. All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
Neither the name of the copyright holder nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
anyio
Copyright (c) 2018 Alex Grönholm
Permission is hereby granted, free of charge, to any person obtaining a copy of
use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
the Software, and to permit persons to whom the Software is furnished to do so,
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
exceptiongroup
Copyright (c) 2022 Alex Grönholm
the Software without restriction, including without limitation the rights to
This project contains code copied from the Python standard library.
The following is the required license notice for those parts.
PYTHON SOFTWARE FOUNDATION LICENSE VERSION 2
1. This LICENSE AGREEMENT is between the Python Software Foundation
("PSF"), and the Individual or Organization ("Licensee") accessing and
otherwise using this software ("Python") in source or binary form and
its associated documentation.
2. Subject to the terms and conditions of this License Agreement, PSF hereby
grants Licensee a nonexclusive, royalty-free, world-wide license to reproduce,
analyze, test, perform and/or display publicly, prepare derivative works,
distribute, and otherwise use Python alone or in any derivative version,
provided, however, that PSF's License Agreement and PSF's notice of copyright,
i.e., "Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022 Python Software Foundation;
All Rights Reserved" are retained in Python alone or in any derivative version
prepared by Licensee.
3. In the event Licensee prepares a derivative work that is based on
or incorporates Python or any part thereof, and wants to make
the derivative work available to others as provided herein, then
Licensee hereby agrees to include in any such work a brief summary of
the changes made to Python.
4. PSF is making Python available to Licensee on an "AS IS"
basis. PSF MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR
IMPLIED. BY WAY OF EXAMPLE, BUT NOT LIMITATION, PSF MAKES NO AND
DISCLAIMS ANY REPRESENTATION OR WARRANTY OF MERCHANTABILITY OR FITNESS
FOR ANY PARTICULAR PURPOSE OR THAT THE USE OF PYTHON WILL NOT
INFRINGE ANY THIRD PARTY RIGHTS.
5. PSF SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF PYTHON
FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS AS
A RESULT OF MODIFYING, DISTRIBUTING, OR OTHERWISE USING PYTHON,
OR ANY DERIVATIVE THEREOF, EVEN IF ADVISED OF THE POSSIBILITY THEREOF.
6. This License Agreement will automatically terminate upon a material
breach of its terms and conditions.
7. Nothing in this License Agreement shall be deemed to create any
relationship of agency, partnership, or joint venture between PSF and
Licensee. This License Agreement does not grant permission to use PSF
trademarks or trade name in a trademark sense to endorse or promote
products or services of Licensee, or any third party.
8. By copying, installing or otherwise using Python, Licensee
agrees to be bound by the terms and conditions of this License
Agreement.
sniffio
Apache License
Version 2.0, January 2004
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
(a) You must give any other recipients of the Work or
Derivative Works a copy of this License; and
(b) You must cause any modified files to carry prominent notices
stating that You changed the files; and
(c) You must retain, in the Source form of any Derivative Works
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
excluding those notices that do not pertain to any part of
the Derivative Works; and
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
include a readable copy of the attribution notices contained
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
of the following places: within a NOTICE text file distributed
as part of the Derivative Works; within the Source form or
documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and
wherever such third-party notices normally appear. The contents
of the NOTICE file are for informational purposes only and
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
or as an addendum to the NOTICE text from the Work, provided
that such additional attribution notices cannot be construed
as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!) The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
pydantic
Copyright (c) 2017 to present Pydantic Services Inc. and individual contributors.
The above copyright notice and this permission notice shall be included in all
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
annotated-types
Copyright (c) 2022 the contributors
SOFTWARE.
pydantic_core
Copyright (c) 2022 Samuel Colvin
SOFTWARE.
typing-inspection
MIT License
Copyright (c) Pydantic Services Inc. 2025 to present
SOFTWARE.
