setuptools
Provider: Jason R. Coombs
Component(s): setuptools
Copyright: Jason R. Coombs
License: MIT
 ./LICENSE
Permission is hereby granted, free of charge, to any person obtaining a copy of
this software and associated documentation files (the "Software"), to deal in
the Software without restriction, including without limitation the rights to
use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
of the Software, and to permit persons to whom the Software is furnished to do
so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
-------------- Separator --------------
 ./setuptools/_vendor/autocommand-2.2.2.dist-info/LICENSE
		   GNU LESSER GENERAL PUBLIC LICENSE
                       Version 3, 29 June 2007
 Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
 Everyone is permitted to copy and distribute verbatim copies
 of this license document, but changing it is not allowed.
  This version of the GNU Lesser General Public License incorporates
the terms and conditions of version 3 of the GNU General Public
License, supplemented by the additional permissions listed below.
  0. Additional Definitions.
  As used herein, "this License" refers to version 3 of the GNU Lesser
General Public License, and the "GNU GPL" refers to version 3 of the GNU
General Public License.
  "The Library" refers to a covered work governed by this License,
other than an Application or a Combined Work as defined below.
  An "Application" is any work that makes use of an interface provided
by the Library, but which is not otherwise based on the Library.
Defining a subclass of a class defined by the Library is deemed a mode
of using an interface provided by the Library.
  A "Combined Work" is a work produced by combining or linking an
Application with the Library.  The particular version of the Library
with which the Combined Work was made is also called the "Linked
Version".
  The "Minimal Corresponding Source" for a Combined Work means the
Corresponding Source for the Combined Work, excluding any source code
for portions of the Combined Work that, considered in isolation, are
based on the Application, and not on the Linked Version.
  The "Corresponding Application Code" for a Combined Work means the
object code and/or source code for the Application, including any data
and utility programs needed for reproducing the Combined Work from the
Application, but excluding the System Libraries of the Combined Work.
  1. Exception to Section 3 of the GNU GPL.
  You may convey a covered work under sections 3 and 4 of this License
without being bound by section 3 of the GNU GPL.
  2. Conveying Modified Versions.
  If you modify a copy of the Library, and, in your modifications, a
facility refers to a function or data to be supplied by an Application
that uses the facility (other than as an argument passed when the
facility is invoked), then you may convey a copy of the modified
version:
   a) under this License, provided that you make a good faith effort to
   ensure that, in the event an Application does not supply the
   function or data, the facility still operates, and performs
   whatever part of its purpose remains meaningful, or
   b) under the GNU GPL, with none of the additional permissions of
   this License applicable to that copy.
  3. Object Code Incorporating Material from Library Header Files.
  The object code form of an Application may incorporate material from
a header file that is part of the Library.  You may convey such object
code under terms of your choice, provided that, if the incorporated
material is not limited to numerical parameters, data structure
layouts and accessors, or small macros, inline functions and templates
(ten or fewer lines in length), you do both of the following:
   a) Give prominent notice with each copy of the object code that the
   Library is used in it and that the Library and its use are
   covered by this License.
   b) Accompany the object code with a copy of the GNU GPL and this license
   document.
  4. Combined Works.
  You may convey a Combined Work under terms of your choice that,
taken together, effectively do not restrict modification of the
portions of the Library contained in the Combined Work and reverse
engineering for debugging such modifications, if you also do each of
the following:
   a) Give prominent notice with each copy of the Combined Work that
   the Library is used in it and that the Library and its use are
   b) Accompany the Combined Work with a copy of the GNU GPL and this license
   document.
   c) For a Combined Work that displays copyright notices during
   execution, include the copyright notice for the Library among
   these notices, as well as a reference directing the user to the
   copies of the GNU GPL and this license document.
   d) Do one of the following:
       0) Convey the Minimal Corresponding Source under the terms of this
       License, and the Corresponding Application Code in a form
       suitable for, and under terms that permit, the user to
       recombine or relink the Application with a modified version of
       the Linked Version to produce a modified Combined Work, in the
       manner specified by section 6 of the GNU GPL for conveying
       Corresponding Source.
       1) Use a suitable shared library mechanism for linking with the
       Library.  A suitable mechanism is one that (a) uses at run time
       a copy of the Library already present on the user's computer
       system, and (b) will operate properly with a modified version
       of the Library that is interface-compatible with the Linked
       Version.
   e) Provide Installation Information, but only if you would otherwise
   be required to provide such information under section 6 of the
   GNU GPL, and only to the extent that such information is
   necessary to install and execute a modified version of the
   Combined Work produced by recombining or relinking the
   Application with a modified version of the Linked Version. (If
   you use option 4d0, the Installation Information must accompany
   the Minimal Corresponding Source and Corresponding Application
   Code. If you use option 4d1, you must provide the Installation
   Information in the manner specified by section 6 of the GNU GPL
   for conveying Corresponding Source.)
  5. Combined Libraries.
  You may place library facilities that are a work based on the
Library side by side in a single library together with other library
facilities that are not Applications and are not covered by this
License, and convey such a combined library under terms of your
choice, if you do both of the following:
   a) Accompany the combined library with a copy of the same work based
   on the Library, uncombined with any other library facilities,
   conveyed under the terms of this License.
   b) Give prominent notice with the combined library that part of it
   is a work based on the Library, and explaining where to find the
   accompanying uncombined form of the same work.
  6. Revised Versions of the GNU Lesser General Public License.
  The Free Software Foundation may publish revised and/or new versions
of the GNU Lesser General Public License from time to time. Such new
versions will be similar in spirit to the present version, but may
differ in detail to address new problems or concerns.
  Each version is given a distinguishing version number. If the
Library as you received it specifies that a certain numbered version
of the GNU Lesser General Public License "or any later version"
applies to it, you have the option of following the terms and
conditions either of that published version or of any later version
published by the Free Software Foundation. If the Library as you
received it does not specify a version number of the GNU Lesser
General Public License, you may choose any version of the GNU Lesser
General Public License ever published by the Free Software Foundation.
  If the Library as you received it specifies that a proxy can decide
whether future versions of the GNU Lesser General Public License shall
apply, that proxy's public statement of acceptance of any version is
permanent authorization for you to choose that version for the
Library.
 ./setuptools/_vendor/backports.tarfile-1.2.0.dist-info/LICENSE
MIT ( same as top-level )
 ./setuptools/_vendor/importlib_metadata-8.0.0.dist-info/LICENSE
                                 Apache License
                           Version 2.0, January 2004
                        https://www.apache.org/licenses/
   TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
   1. Definitions.
      "License" shall mean the terms and conditions for use, reproduction,
      and distribution as defined by Sections 1 through 9 of this document.
      "Licensor" shall mean the copyright owner or entity authorized by
      the copyright owner that is granting the License.
      "Legal Entity" shall mean the union of the acting entity and all
      other entities that control, are controlled by, or are under common
      control with that entity. For the purposes of this definition,
      "control" means (i) the power, direct or indirect, to cause the
      direction or management of such entity, whether by contract or
      otherwise, or (ii) ownership of fifty percent (50%) or more of the
      outstanding shares, or (iii) beneficial ownership of such entity.
      "You" (or "Your") shall mean an individual or Legal Entity
      exercising permissions granted by this License.
      "Source" form shall mean the preferred form for making modifications,
      including but not limited to software source code, documentation
      source, and configuration files.
      "Object" form shall mean any form resulting from mechanical
      transformation or translation of a Source form, including but
      not limited to compiled object code, generated documentation,
      and conversions to other media types.
      "Work" shall mean the work of authorship, whether in Source or
      Object form, made available under the License, as indicated by a
      copyright notice that is included in or attached to the work
      (an example is provided in the Appendix below).
      "Derivative Works" shall mean any work, whether in Source or Object
      form, that is based on (or derived from) the Work and for which the
      editorial revisions, annotations, elaborations, or other modifications
      represent, as a whole, an original work of authorship. For the purposes
      of this License, Derivative Works shall not include works that remain
      separable from, or merely link (or bind by name) to the interfaces of,
      the Work and Derivative Works thereof.
      "Contribution" shall mean any work of authorship, including
      the original version of the Work and any modifications or additions
      to that Work or Derivative Works thereof, that is intentionally
      submitted to Licensor for inclusion in the Work by the copyright owner
      or by an individual or Legal Entity authorized to submit on behalf of
      the copyright owner. For the purposes of this definition, "submitted"
      means any form of electronic, verbal, or written communication sent
      to the Licensor or its representatives, including but not limited to
      communication on electronic mailing lists, source code control systems,
      and issue tracking systems that are managed by, or on behalf of, the
      Licensor for the purpose of discussing and improving the Work, but
      excluding communication that is conspicuously marked or otherwise
      designated in writing by the copyright owner as "Not a Contribution."
      "Contributor" shall mean Licensor and any individual or Legal Entity
      on behalf of whom a Contribution has been received by Licensor and
      subsequently incorporated within the Work.
   2. Grant of Copyright License. Subject to the terms and conditions of
      this License, each Contributor hereby grants to You a perpetual,
      worldwide, non-exclusive, no-charge, royalty-free, irrevocable
      copyright license to reproduce, prepare Derivative Works of,
      publicly display, publicly perform, sublicense, and distribute the
      Work and such Derivative Works in Source or Object form.
   3. Grant of Patent License. Subject to the terms and conditions of
      (except as stated in this section) patent license to make, have made,
      use, offer to sell, sell, import, and otherwise transfer the Work,
      where such license applies only to those patent claims licensable
      by such Contributor that are necessarily infringed by their
      Contribution(s) alone or by combination of their Contribution(s)
      with the Work to which such Contribution(s) was submitted. If You
      institute patent litigation against any entity (including a
      cross-claim or counterclaim in a lawsuit) alleging that the Work
      or a Contribution incorporated within the Work constitutes direct
      or contributory patent infringement, then any patent licenses
      granted to You under this License for that Work shall terminate
      as of the date such litigation is filed.
   4. Redistribution. You may reproduce and distribute copies of the
      Work or Derivative Works thereof in any medium, with or without
      modifications, and in Source or Object form, provided that You
      meet the following conditions:
      (a) You must give any other recipients of the Work or
          Derivative Works a copy of this License; and
      (b) You must cause any modified files to carry prominent notices
          stating that You changed the files; and
      (c) You must retain, in the Source form of any Derivative Works
          that You distribute, all copyright, patent, trademark, and
          attribution notices from the Source form of the Work,
          excluding those notices that do not pertain to any part of
          the Derivative Works; and
      (d) If the Work includes a "NOTICE" text file as part of its
          distribution, then any Derivative Works that You distribute must
          include a readable copy of the attribution notices contained
          within such NOTICE file, excluding those notices that do not
          pertain to any part of the Derivative Works, in at least one
          of the following places: within a NOTICE text file distributed
          as part of the Derivative Works; within the Source form or
          documentation, if provided along with the Derivative Works; or,
          within a display generated by the Derivative Works, if and
          wherever such third-party notices normally appear. The contents
          of the NOTICE file are for informational purposes only and
          do not modify the License. You may add Your own attribution
          notices within Derivative Works that You distribute, alongside
          or as an addendum to the NOTICE text from the Work, provided
          that such additional attribution notices cannot be construed
          as modifying the License.
      You may add Your own copyright statement to Your modifications and
      may provide additional or different license terms and conditions
      for use, reproduction, or distribution of Your modifications, or
      for any such Derivative Works as a whole, provided Your use,
      reproduction, and distribution of the Work otherwise complies with
      the conditions stated in this License.
   5. Submission of Contributions. Unless You explicitly state otherwise,
      any Contribution intentionally submitted for inclusion in the Work
      by You to the Licensor shall be under the terms and conditions of
      this License, without any additional terms or conditions.
      Notwithstanding the above, nothing herein shall supersede or modify
      the terms of any separate license agreement you may have executed
      with Licensor regarding such Contributions.
   6. Trademarks. This License does not grant permission to use the trade
      names, trademarks, service marks, or product names of the Licensor,
      except as required for reasonable and customary use in describing the
      origin of the Work and reproducing the content of the NOTICE file.
   7. Disclaimer of Warranty. Unless required by applicable law or
      agreed to in writing, Licensor provides the Work (and each
      Contributor provides its Contributions) on an "AS IS" BASIS,
      WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
      implied, including, without limitation, any warranties or conditions
      of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
      PARTICULAR PURPOSE. You are solely responsible for determining the
      appropriateness of using or redistributing the Work and assume any
      risks associated with Your exercise of permissions under this License.
   8. Limitation of Liability. In no event and under no legal theory,
      whether in tort (including negligence), contract, or otherwise,
      unless required by applicable law (such as deliberate and grossly
      negligent acts) or agreed to in writing, shall any Contributor be
      liable to You for damages, including any direct, indirect, special,
      incidental, or consequential damages of any character arising as a
      result of this License or out of the use or inability to use the
      Work (including but not limited to damages for loss of goodwill,
      work stoppage, computer failure or malfunction, or any and all
      other commercial damages or losses), even if such Contributor
      has been advised of the possibility of such damages.
   9. Accepting Warranty or Additional Liability. While redistributing
      the Work or Derivative Works thereof, You may choose to offer,
      and charge a fee for, acceptance of support, warranty, indemnity,
      or other liability obligations and/or rights consistent with this
      License. However, in accepting such obligations, You may act only
      on Your own behalf and on Your sole responsibility, not on behalf
      of any other Contributor, and only if You agree to indemnify,
      defend, and hold each Contributor harmless for any liability
      incurred by, or claims asserted against, such Contributor by reason
      of your accepting any such warranty or additional liability.
   END OF TERMS AND CONDITIONS
   APPENDIX: How to apply the Apache License to your work.
      To apply the Apache License to your work, attach the following
      boilerplate notice, with the fields enclosed by brackets "[]"
      replaced with your own identifying information. (Don't include
      the brackets!)  The text should be enclosed in the appropriate
      comment syntax for the file format. We also recommend that a
      file or class name and description of purpose be included on the
      same "printed page" as the copyright notice for easier
      identification within third-party archives.
   Copyright [yyyy] [name of copyright owner]
   Licensed under the Apache License, Version 2.0 (the "License");
   you may not use this file except in compliance with the License.
   You may obtain a copy of the License at
       http://www.apache.org/licenses/LICENSE-2.0
   Unless required by applicable law or agreed to in writing, software
   distributed under the License is distributed on an "AS IS" BASIS,
   WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
   See the License for the specific language governing permissions and
   limitations under the License.
 ./setuptools/_vendor/inflect-7.3.1.dist-info/LICENSE
 ./setuptools/_vendor/jaraco.collections-5.1.0.dist-info/LICENSE
 ./setuptools/_vendor/jaraco.context-5.3.0.dist-info/LICENSE
 ./setuptools/_vendor/jaraco.functools-4.0.1.dist-info/LICENSE
 ./setuptools/_vendor/jaraco.text-3.12.1.dist-info/LICENSE
 ./setuptools/_vendor/more_itertools-10.3.0.dist-info/LICENSE
Copyright (c) 2012 Erik Rose
SOFTWARE.
 ./setuptools/_vendor/packaging-24.2.dist-info/LICENSE
This software is made available under the terms of *either* of the licenses
found in LICENSE.APACHE or LICENSE.BSD. Contributions to this software is made
under the terms of *both* these licenses.
 ./setuptools/_vendor/packaging-24.2.dist-info/LICENSE.APACHE
                                 Apache License
   1. Definitions.
 ./setuptools/_vendor/packaging-24.2.dist-info/LICENSE.BSD
Copyright (c) Donald Stufft and individual contributors.
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright notice,
       this list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright
       notice, this list of conditions and the following disclaimer in the
       documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 ./setuptools/_vendor/platformdirs-4.2.2.dist-info/licenses/LICENSE
MIT License
Copyright (c) 2010-202x The platformdirs developers
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
SOFTWARE.
 ./setuptools/_vendor/tomli-2.0.1.dist-info/LICENSE
MIT License
Copyright (c) 2021 Taneli Hukkinen
SOFTWARE.
 ./setuptools/_vendor/typeguard-4.3.0.dist-info/LICENSE
This is the MIT license: http://www.opensource.org/licenses/mit-license.php
Copyright (c) Alex Grönholm
Permission is hereby granted, free of charge, to any person obtaining a copy of this
software and associated documentation files (the "Software"), to deal in the Software
without restriction, including without limitation the rights to use, copy, modify, merge,
publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons
to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE
FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
 ./setuptools/_vendor/typing_extensions-4.12.2.dist-info/LICENSE
A. HISTORY OF THE SOFTWARE
Python was created in the early 1990s by Guido van Rossum at Stichting
Mathematisch Centrum (CWI, see https://www.cwi.nl) in the Netherlands
as a successor of a language called ABC.  Guido remains Python's
principal author, although it includes many contributions from others.
In 1995, Guido continued his work on Python at the Corporation for
National Research Initiatives (CNRI, see https://www.cnri.reston.va.us)
in Reston, Virginia where he released several versions of the
software.
In May 2000, Guido and the Python core development team moved to
BeOpen.com to form the BeOpen PythonLabs team.  In October of the same
year, the PythonLabs team moved to Digital Creations, which became
Zope Corporation.  In 2001, the Python Software Foundation (PSF, see
https://www.python.org/psf/) was formed, a non-profit organization
created specifically to own Python-related Intellectual Property.
Zope Corporation was a sponsoring member of the PSF.
All Python releases are Open Source (see https://opensource.org for
the Open Source Definition).  Historically, most, but not all, Python
releases have also been GPL-compatible; the table below summarizes
the various releases.
    Release         Derived     Year        Owner       GPL-
                    from                                compatible? (1)
    0.9.0 thru 1.2              1991-1995   CWI         yes
    1.3 thru 1.5.2  1.2         1995-1999   CNRI        yes
    1.6             1.5.2       2000        CNRI        no
    2.0             1.6         2000        BeOpen.com  no
    1.6.1           1.6         2001        CNRI        yes (2)
    2.1             2.0+1.6.1   2001        PSF         no
    2.0.1           2.0+1.6.1   2001        PSF         yes
    2.1.1           2.1+2.0.1   2001        PSF         yes
    2.1.2           2.1.1       2002        PSF         yes
    2.1.3           2.1.2       2002        PSF         yes
    2.2 and above   2.1.1       2001-now    PSF         yes
Footnotes:
(1) GPL-compatible doesn't mean that we're distributing Python under
    the GPL.  All Python licenses, unlike the GPL, let you distribute
    a modified version without making your changes open source.  The
    GPL-compatible licenses make it possible to combine Python with
    other software that is released under the GPL; the others don't.
(2) According to Richard Stallman, 1.6.1 is not GPL-compatible,
    because its license has a choice of law clause.  According to
    CNRI, however, Stallman's lawyer has told CNRI's lawyer that 1.6.1
    is "not incompatible" with the GPL.
Thanks to the many outside volunteers who have worked under Guido's
direction to make these releases possible.
B. TERMS AND CONDITIONS FOR ACCESSING OR OTHERWISE USING PYTHON
Python software and documentation are licensed under the
Python Software Foundation License Version 2.
Starting with Python 3.8.6, examples, recipes, and other code in
the documentation are dual licensed under the PSF License Version 2
and the Zero-Clause BSD license.
Some software incorporated into Python is under different licenses.
The licenses are listed with code falling under that license.
PYTHON SOFTWARE FOUNDATION LICENSE VERSION 2
1. This LICENSE AGREEMENT is between the Python Software Foundation
("PSF"), and the Individual or Organization ("Licensee") accessing and
otherwise using this software ("Python") in source or binary form and
its associated documentation.
2. Subject to the terms and conditions of this License Agreement, PSF hereby
grants Licensee a nonexclusive, royalty-free, world-wide license to reproduce,
analyze, test, perform and/or display publicly, prepare derivative works,
distribute, and otherwise use Python alone or in any derivative version,
provided, however, that PSF's License Agreement and PSF's notice of copyright,
i.e., "Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023 Python Software Foundation;
All Rights Reserved" are retained in Python alone or in any derivative version
prepared by Licensee.
3. In the event Licensee prepares a derivative work that is based on
or incorporates Python or any part thereof, and wants to make
the derivative work available to others as provided herein, then
Licensee hereby agrees to include in any such work a brief summary of
the changes made to Python.
4. PSF is making Python available to Licensee on an "AS IS"
basis.  PSF MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR
IMPLIED.  BY WAY OF EXAMPLE, BUT NOT LIMITATION, PSF MAKES NO AND
DISCLAIMS ANY REPRESENTATION OR WARRANTY OF MERCHANTABILITY OR FITNESS
FOR ANY PARTICULAR PURPOSE OR THAT THE USE OF PYTHON WILL NOT
INFRINGE ANY THIRD PARTY RIGHTS.
5. PSF SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF PYTHON
FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS AS
A RESULT OF MODIFYING, DISTRIBUTING, OR OTHERWISE USING PYTHON,
OR ANY DERIVATIVE THEREOF, EVEN IF ADVISED OF THE POSSIBILITY THEREOF.
6. This License Agreement will automatically terminate upon a material
breach of its terms and conditions.
7. Nothing in this License Agreement shall be deemed to create any
relationship of agency, partnership, or joint venture between PSF and
Licensee.  This License Agreement does not grant permission to use PSF
trademarks or trade name in a trademark sense to endorse or promote
products or services of Licensee, or any third party.
8. By copying, installing or otherwise using Python, Licensee
agrees to be bound by the terms and conditions of this License
Agreement.
BEOPEN.COM LICENSE AGREEMENT FOR PYTHON 2.0
BEOPEN PYTHON OPEN SOURCE LICENSE AGREEMENT VERSION 1
1. This LICENSE AGREEMENT is between BeOpen.com ("BeOpen"), having an
office at 160 Saratoga Avenue, Santa Clara, CA 95051, and the
Individual or Organization ("Licensee") accessing and otherwise using
this software in source or binary form and its associated
documentation ("the Software").
2. Subject to the terms and conditions of this BeOpen Python License
Agreement, BeOpen hereby grants Licensee a non-exclusive,
royalty-free, world-wide license to reproduce, analyze, test, perform
and/or display publicly, prepare derivative works, distribute, and
otherwise use the Software alone or in any derivative version,
provided, however, that the BeOpen Python License is retained in the
Software, alone or in any derivative version prepared by Licensee.
3. BeOpen is making the Software available to Licensee on an "AS IS"
basis.  BEOPEN MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR
IMPLIED.  BY WAY OF EXAMPLE, BUT NOT LIMITATION, BEOPEN MAKES NO AND
FOR ANY PARTICULAR PURPOSE OR THAT THE USE OF THE SOFTWARE WILL NOT
4. BEOPEN SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF THE
SOFTWARE FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS
AS A RESULT OF USING, MODIFYING OR DISTRIBUTING THE SOFTWARE, OR ANY
5. This License Agreement will automatically terminate upon a material
6. This License Agreement shall be governed by and interpreted in all
respects by the law of the State of California, excluding conflict of
law provisions.  Nothing in this License Agreement shall be deemed to
create any relationship of agency, partnership, or joint venture
between BeOpen and Licensee.  This License Agreement does not grant
permission to use BeOpen trademarks or trade names in a trademark
sense to endorse or promote products or services of Licensee, or any
third party.  As an exception, the "BeOpen Python" logos available at
http://www.pythonlabs.com/logos.html may be used according to the
permissions granted on that web page.
7. By copying, installing or otherwise using the software, Licensee
Agreement.
CNRI LICENSE AGREEMENT FOR PYTHON 1.6.1
1. This LICENSE AGREEMENT is between the Corporation for National
Research Initiatives, having an office at 1895 Preston White Drive,
Reston, VA 20191 ("CNRI"), and the Individual or Organization
("Licensee") accessing and otherwise using Python 1.6.1 software in
source or binary form and its associated documentation.
2. Subject to the terms and conditions of this License Agreement, CNRI
hereby grants Licensee a nonexclusive, royalty-free, world-wide
license to reproduce, analyze, test, perform and/or display publicly,
prepare derivative works, distribute, and otherwise use Python 1.6.1
alone or in any derivative version, provided, however, that CNRI's
License Agreement and CNRI's notice of copyright, i.e., "Copyright (c)
1995-2001 Corporation for National Research Initiatives; All Rights
Reserved" are retained in Python 1.6.1 alone or in any derivative
version prepared by Licensee.  Alternately, in lieu of CNRI's License
Agreement, Licensee may substitute the following text (omitting the
quotes): "Python 1.6.1 is made available subject to the terms and
conditions in CNRI's License Agreement.  This Agreement together with
Python 1.6.1 may be located on the internet using the following
unique, persistent identifier (known as a handle): 1895.22/1013.  This
Agreement may also be obtained from a proxy server on the internet
using the following URL: http://hdl.handle.net/1895.22/1013".
or incorporates Python 1.6.1 or any part thereof, and wants to make
the changes made to Python 1.6.1.
4. CNRI is making Python 1.6.1 available to Licensee on an "AS IS"
basis.  CNRI MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR
IMPLIED.  BY WAY OF EXAMPLE, BUT NOT LIMITATION, CNRI MAKES NO AND
FOR ANY PARTICULAR PURPOSE OR THAT THE USE OF PYTHON 1.6.1 WILL NOT
5. CNRI SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF PYTHON
1.6.1 FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS AS
A RESULT OF MODIFYING, DISTRIBUTING, OR OTHERWISE USING PYTHON 1.6.1,
7. This License Agreement shall be governed by the federal
intellectual property law of the United States, including without
limitation the federal copyright law, and, to the extent such
U.S. federal law does not apply, by the law of the Commonwealth of
Virginia, excluding Virginia's conflict of law provisions.
Notwithstanding the foregoing, with regard to derivative works based
on Python 1.6.1 that incorporate non-separable material that was
previously distributed under the GNU General Public License (GPL), the
law of the Commonwealth of Virginia shall govern this License
Agreement only as to issues arising under or with respect to
Paragraphs 4, 5, and 7 of this License Agreement.  Nothing in this
License Agreement shall be deemed to create any relationship of
agency, partnership, or joint venture between CNRI and Licensee.  This
License Agreement does not grant permission to use CNRI trademarks or
trade name in a trademark sense to endorse or promote products or
8. By clicking on the "ACCEPT" button where indicated, or by copying,
installing or otherwise using Python 1.6.1, Licensee agrees to be
bound by the terms and conditions of this License Agreement.
        ACCEPT
CWI LICENSE AGREEMENT FOR PYTHON 0.9.0 THROUGH 1.2
Copyright (c) 1991 - 1995, Stichting Mathematisch Centrum Amsterdam,
The Netherlands.  All rights reserved.
Permission to use, copy, modify, and distribute this software and its
documentation for any purpose and without fee is hereby granted,
provided that the above copyright notice appear in all copies and that
both that copyright notice and this permission notice appear in
supporting documentation, and that the name of Stichting Mathematisch
Centrum or CWI not be used in advertising or publicity pertaining to
distribution of the software without specific, written prior
permission.
STICHTING MATHEMATISCH CENTRUM DISCLAIMS ALL WARRANTIES WITH REGARD TO
THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND
FITNESS, IN NO EVENT SHALL STICHTING MATHEMATISCH CENTRUM BE LIABLE
FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT
OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
ZERO-CLAUSE BSD LICENSE FOR CODE IN THE PYTHON DOCUMENTATION
Permission to use, copy, modify, and/or distribute this software for any
purpose with or without fee is hereby granted.
THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES WITH
REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY SPECIAL, DIRECT,
INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM
LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR
OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
 ./setuptools/_vendor/wheel-0.45.1.dist-info/LICENSE.txt
MIT License
Copyright (c) 2012 Daniel Holth <dholth@fastmail.fm> and contributors
copy of this software and associated documentation files (the "Software"),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
in all copies or substantial portions of the Software.
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
OTHER DEALINGS IN THE SOFTWARE.
 ./setuptools/_vendor/wheel/vendored/packaging/LICENSE
Apache 2.0, BSD 2-Clause ( same as top-level )
 ./setuptools/_vendor/wheel/vendored/packaging/LICENSE.APACHE
Apache 2.0 ( same as top-level )
 ./setuptools/_vendor/wheel/vendored/packaging/LICENSE.BSD
 ./setuptools/_vendor/zipp-3.19.2.dist-info/LICENSE
 ./setuptools/config/NOTICE
The following files include code from opensource projects
(either as direct copies or modified versions):
- `setuptools.schema.json`, `distutils.schema.json`:
    - project: `validate-pyproject` - licensed under MPL-2.0
      (https://github.com/abravalheri/validate-pyproject):
      This Source Code Form is subject to the terms of the Mozilla Public
      License, v. 2.0. If a copy of the MPL was not distributed with this file,
      You can obtain one at https://mozilla.org/MPL/2.0/.
 ./setuptools/config/_validate_pyproject/NOTICE
The code contained in this directory was automatically generated using the
following command:
    python -m validate_pyproject.pre_compile --output-dir=setuptools/config/_validate_pyproject --enable-plugins setuptools distutils --very-verbose -t setuptools=setuptools/config/setuptools.schema.json -t distutils=setuptools/config/distutils.schema.json
Please avoid changing it manually.
You can report issues or suggest changes directly to `validate-pyproject`
(or to the relevant plugin repository)
- https://github.com/abravalheri/validate-pyproject/issues
- `fastjsonschema_exceptions.py`:
    - project: `fastjsonschema` - licensed under BSD-3-Clause
      (https://github.com/horejsek/python-fastjsonschema)
- `extra_validations.py` and `format.py`, `error_reporting.py`:
Additionally the following files are automatically generated by tools provided
by the same projects:
- `__init__.py`
- `fastjsonschema_validations.py`
The relevant copyright notes and licenses are included below.
`fastjsonschema`
Copyright (c) 2018, Michal Horejsek
Redistribution and use in source and binary forms, with or without modification,
  Redistributions of source code must retain the above copyright notice, this
  Redistributions in binary form must reproduce the above copyright notice, this
  list of conditions and the following disclaimer in the documentation and/or
  Neither the name of the {organization} nor the names of its
  contributors may be used to endorse or promote products derived from
  this software without specific prior written permission.
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
Mozilla Public License, version 2.0
1. Definitions
1.1. "Contributor"
     means each individual or legal entity that creates, contributes to the
     creation of, or owns Covered Software.
1.2. "Contributor Version"
     means the combination of the Contributions of others (if any) used by a
     Contributor and that particular Contributor's Contribution.
1.3. "Contribution"
     means Covered Software of a particular Contributor.
1.4. "Covered Software"
     means Source Code Form to which the initial Contributor has attached the
     notice in Exhibit A, the Executable Form of such Source Code Form, and
     Modifications of such Source Code Form, in each case including portions
     thereof.
1.5. "Incompatible With Secondary Licenses"
     means
     a. that the initial Contributor has attached the notice described in
        Exhibit B to the Covered Software; or
     b. that the Covered Software was made available under the terms of
        version 1.1 or earlier of the License, but not also under the terms of
        a Secondary License.
1.6. "Executable Form"
     means any form of the work other than Source Code Form.
1.7. "Larger Work"
     means a work that combines Covered Software with other material, in a
     separate file or files, that is not Covered Software.
1.8. "License"
     means this document.
1.9. "Licensable"
     means having the right to grant, to the maximum extent possible, whether
     at the time of the initial grant or subsequently, any and all of the
     rights conveyed by this License.
1.10. "Modifications"
     means any of the following:
     a. any file in Source Code Form that results from an addition to,
        deletion from, or modification of the contents of Covered Software; or
     b. any new file in Source Code Form that contains any Covered Software.
1.11. "Patent Claims" of a Contributor
      means any patent claim(s), including without limitation, method,
      process, and apparatus claims, in any patent Licensable by such
      Contributor that would be infringed, but for the grant of the License,
      by the making, using, selling, offering for sale, having made, import,
      or transfer of either its Contributions or its Contributor Version.
1.12. "Secondary License"
      means either the GNU General Public License, Version 2.0, the GNU Lesser
      General Public License, Version 2.1, the GNU Affero General Public
      License, Version 3.0, or any later versions of those licenses.
1.13. "Source Code Form"
      means the form of the work preferred for making modifications.
1.14. "You" (or "Your")
      means an individual or a legal entity exercising rights under this
      License. For legal entities, "You" includes any entity that controls, is
      controlled by, or is under common control with You. For purposes of this
      definition, "control" means (a) the power, direct or indirect, to cause
      the direction or management of such entity, whether by contract or
      otherwise, or (b) ownership of more than fifty percent (50%) of the
      outstanding shares or beneficial ownership of such entity.
2. License Grants and Conditions
2.1. Grants
     Each Contributor hereby grants You a world-wide, royalty-free,
     non-exclusive license:
     a. under intellectual property rights (other than patent or trademark)
        Licensable by such Contributor to use, reproduce, make available,
        modify, display, perform, distribute, and otherwise exploit its
        Contributions, either on an unmodified basis, with Modifications, or
        as part of a Larger Work; and
     b. under Patent Claims of such Contributor to make, use, sell, offer for
        sale, have made, import, and otherwise transfer either its
2.2. Effective Date
     The licenses granted in Section 2.1 with respect to any Contribution
     become effective for each Contribution on the date the Contributor first
     distributes such Contribution.
2.3. Limitations on Grant Scope
     The licenses granted in this Section 2 are the only rights granted under
     this License. No additional rights or licenses will be implied from the
     distribution or licensing of Covered Software under this License.
     Notwithstanding Section 2.1(b) above, no patent license is granted by a
     Contributor:
     a. for any code that a Contributor has removed from Covered Software; or
     b. for infringements caused by: (i) Your and any other third party's
        modifications of Covered Software, or (ii) the combination of its
        Contributions with other software (except as part of its Contributor
        Version); or
     c. under Patent Claims infringed by Covered Software in the absence of
        its Contributions.
     This License does not grant any rights in the trademarks, service marks,
     or logos of any Contributor (except as may be necessary to comply with
     the notice requirements in Section 3.4).
2.4. Subsequent Licenses
     No Contributor makes additional grants as a result of Your choice to
     distribute the Covered Software under a subsequent version of this
     License (see Section 10.2) or under the terms of a Secondary License (if
     permitted under the terms of Section 3.3).
2.5. Representation
     Each Contributor represents that the Contributor believes its
     Contributions are its original creation(s) or it has sufficient rights to
     grant the rights to its Contributions conveyed by this License.
2.6. Fair Use
     This License is not intended to limit any rights You have under
     applicable copyright doctrines of fair use, fair dealing, or other
     equivalents.
2.7. Conditions
     Sections 3.1, 3.2, 3.3, and 3.4 are conditions of the licenses granted in
     Section 2.1.
3. Responsibilities
3.1. Distribution of Source Form
     All distribution of Covered Software in Source Code Form, including any
     Modifications that You create or to which You contribute, must be under
     the terms of this License. You must inform recipients that the Source
     Code Form of the Covered Software is governed by the terms of this
     License, and how they can obtain a copy of this License. You may not
     attempt to alter or restrict the recipients' rights in the Source Code
     Form.
3.2. Distribution of Executable Form
     If You distribute Covered Software in Executable Form then:
     a. such Covered Software must also be made available in Source Code Form,
        as described in Section 3.1, and You must inform recipients of the
        Executable Form how they can obtain a copy of such Source Code Form by
        reasonable means in a timely manner, at a charge no more than the cost
        of distribution to the recipient; and
     b. You may distribute such Executable Form under the terms of this
        License, or sublicense it under different terms, provided that the
        license for the Executable Form does not attempt to limit or alter the
        recipients' rights in the Source Code Form under this License.
3.3. Distribution of a Larger Work
     You may create and distribute a Larger Work under terms of Your choice,
     provided that You also comply with the requirements of this License for
     the Covered Software. If the Larger Work is a combination of Covered
     Software with a work governed by one or more Secondary Licenses, and the
     Covered Software is not Incompatible With Secondary Licenses, this
     License permits You to additionally distribute such Covered Software
     under the terms of such Secondary License(s), so that the recipient of
     the Larger Work may, at their option, further distribute the Covered
     Software under the terms of either this License or such Secondary
     License(s).
3.4. Notices
     You may not remove or alter the substance of any license notices
     (including copyright notices, patent notices, disclaimers of warranty, or
     limitations of liability) contained within the Source Code Form of the
     Covered Software, except that You may alter any license notices to the
     extent required to remedy known factual inaccuracies.
3.5. Application of Additional Terms
     You may choose to offer, and to charge a fee for, warranty, support,
     indemnity or liability obligations to one or more recipients of Covered
     Software. However, You may do so only on Your own behalf, and not on
     behalf of any Contributor. You must make it absolutely clear that any
     such warranty, support, indemnity, or liability obligation is offered by
     You alone, and You hereby agree to indemnify every Contributor for any
     liability incurred by such Contributor as a result of warranty, support,
     indemnity or liability terms You offer. You may include additional
     disclaimers of warranty and limitations of liability specific to any
     jurisdiction.
4. Inability to Comply Due to Statute or Regulation
   If it is impossible for You to comply with any of the terms of this License
   with respect to some or all of the Covered Software due to statute,
   judicial order, or regulation then You must: (a) comply with the terms of
   this License to the maximum extent possible; and (b) describe the
   limitations and the code they affect. Such description must be placed in a
   text file included with all distributions of the Covered Software under
   this License. Except to the extent prohibited by statute or regulation,
   such description must be sufficiently detailed for a recipient of ordinary
   skill to be able to understand it.
5. Termination
5.1. The rights granted under this License will terminate automatically if You
     fail to comply with any of its terms. However, if You become compliant,
     then the rights granted under this License from a particular Contributor
     are reinstated (a) provisionally, unless and until such Contributor
     explicitly and finally terminates Your grants, and (b) on an ongoing
     basis, if such Contributor fails to notify You of the non-compliance by
     some reasonable means prior to 60 days after You have come back into
     compliance. Moreover, Your grants from a particular Contributor are
     reinstated on an ongoing basis if such Contributor notifies You of the
     non-compliance by some reasonable means, this is the first time You have
     received notice of non-compliance with this License from such
     Contributor, and You become compliant prior to 30 days after Your receipt
     of the notice.
5.2. If You initiate litigation against any entity by asserting a patent
     infringement claim (excluding declaratory judgment actions,
     counter-claims, and cross-claims) alleging that a Contributor Version
     directly or indirectly infringes any patent, then the rights granted to
     You by any and all Contributors for the Covered Software under Section
     2.1 of this License shall terminate.
5.3. In the event of termination under Sections 5.1 or 5.2 above, all end user
     license agreements (excluding distributors and resellers) which have been
     validly granted by You or Your distributors under this License prior to
     termination shall survive termination.
6. Disclaimer of Warranty
   Covered Software is provided under this License on an "as is" basis,
   without warranty of any kind, either expressed, implied, or statutory,
   including, without limitation, warranties that the Covered Software is free
   of defects, merchantable, fit for a particular purpose or non-infringing.
   The entire risk as to the quality and performance of the Covered Software
   is with You. Should any Covered Software prove defective in any respect,
   You (not any Contributor) assume the cost of any necessary servicing,
   repair, or correction. This disclaimer of warranty constitutes an essential
   part of this License. No use of  any Covered Software is authorized under
   this License except under this disclaimer.
7. Limitation of Liability
   Under no circumstances and under no legal theory, whether tort (including
   negligence), contract, or otherwise, shall any Contributor, or anyone who
   distributes Covered Software as permitted above, be liable to You for any
   direct, indirect, special, incidental, or consequential damages of any
   character including, without limitation, damages for lost profits, loss of
   goodwill, work stoppage, computer failure or malfunction, or any and all
   other commercial damages or losses, even if such party shall have been
   informed of the possibility of such damages. This limitation of liability
   shall not apply to liability for death or personal injury resulting from
   such party's negligence to the extent applicable law prohibits such
   limitation. Some jurisdictions do not allow the exclusion or limitation of
   incidental or consequential damages, so this exclusion and limitation may
   not apply to You.
8. Litigation
   Any litigation relating to this License may be brought only in the courts
   of a jurisdiction where the defendant maintains its principal place of
   business and such litigation shall be governed by laws of that
   jurisdiction, without reference to its conflict-of-law provisions. Nothing
   in this Section shall prevent a party's ability to bring cross-claims or
   counter-claims.
9. Miscellaneous
   This License represents the complete agreement concerning the subject
   matter hereof. If any provision of this License is held to be
   unenforceable, such provision shall be reformed only to the extent
   necessary to make it enforceable. Any law or regulation which provides that
   the language of a contract shall be construed against the drafter shall not
   be used to construe this License against a Contributor.
10. Versions of the License
10.1. New Versions
      Mozilla Foundation is the license steward. Except as provided in Section
      10.3, no one other than the license steward has the right to modify or
      publish new versions of this License. Each version will be given a
10.2. Effect of New Versions
      You may distribute the Covered Software under the terms of the version
      of the License under which You originally received the Covered Software,
      or under the terms of any subsequent version published by the license
      steward.
10.3. Modified Versions
      If you create software not governed by this License, and you want to
      create a new license for such software, you may create and use a
      modified version of this License if you rename the license and remove
      any references to the name of the license steward (except to note that
      such modified license differs from this License).
10.4. Distributing Source Code Form that is Incompatible With Secondary
      Licenses If You choose to distribute Source Code Form that is
      Incompatible With Secondary Licenses under the terms of this version of
      the License, the notice described in Exhibit B of this License must be
      attached.
Exhibit A - Source Code Form License Notice
      terms of the Mozilla Public License, v.
      distributed with this file, You can
      obtain one at
If it is not possible or desirable to put the notice in a particular file,
then You may include the notice in a location (such as a LICENSE file in a
relevant directory) where a recipient would be likely to look for such a
notice.
You may add additional accurate notices of copyright ownership.
Exhibit B - "Incompatible With Secondary Licenses" Notice
      This Source Code Form is "Incompatible
      With Secondary Licenses", as defined by
      the Mozilla Public License, v. 2.0.
