JavaScript Extension Toolkit (JET)
Provider: Oracle
Component(s): JavaScript Extension Toolkit (JET)
# Oracle JET 19.0.1
You may not use the identified files except in compliance with the Universal Permissive License (UPL), Version 1.0 (the "License.")
You may obtain a copy of the License at https://opensource.org/licenses/UPL. A copy of the license is also reproduced below.
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and limitations under the License.
Copyright (c) 2014, 2025 Oracle and/or its affiliates
The Universal Permissive License (UPL), Version 1.0
Subject to the condition set forth below, permission is hereby granted to any person obtaining
a copy of this software, associated documentation and/or data (collectively the "Software"),
free of charge and under any and all copyright rights in the Software, and any and all patent
rights owned or freely licensable by each licensor hereunder covering either (i) the unmodified
Software as contributed to or provided by such licensor, or (ii) the Larger Works (as defined below),
to deal in both
(a) the Software, and (b) any piece of software and/or hardware listed in the lrgrwrks.txt file if
one is included with the Software (each a Larger Work to which the Software is contributed by such licensors),
without restriction, including without limitation the rights to copy, create derivative works of,
display, perform, and distribute the Software and make, use, sell, offer for sale, import, export,
have made, and have sold the Software and the Larger Work(s), and to sublicense the foregoing rights
on either these or other terms.
This license is subject to the following condition:
The above copyright notice and either this complete permission notice or at a minimum a reference
to the UPL must be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH
THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
DO NOT TRANSLATE OR LOCALIZE.
Oracle elects to use only the GNU Lesser General Public License version 2.1
(LGPL) for any software where a choice of LGPL/GPL license versions are made
available with the language indicating that LGPLv2.1/GPLv2 or any later version
may be used, or where a choice of which version of the LGPL/GPL is applied is
unspecified.
THIRD-PARTY COMPONENT FILE LICENSE
(path in the installation) (see license text reproduced below)
js/libs/chai/chai.js MIT
js/libs/hammer/hammer.js MIT
js/libs/js-signals/signals.js MIT
js/libs/jquery/jquery.js MIT
js/libs/jquery/jquery-ui-.custom.js MIT
js/libs/jquery/jqueryui-amd/core.js MIT
js/libs/jquery/jqueryui-amd/draggable.js MIT
js/libs/jquery/jqueryui-amd/mouse.js MIT
js/libs/jquery/jqueryui-amd/position.js MIT
js/libs/jquery/jqueryui-amd/sortable.js MIT
js/libs/jquery/jqueryui-amd/widget.js MIT
js/libs/jquery/jqueryui-amd/disable-selection.js MIT
js/libs/jquery/jqueryui-amd/jquery-var-for-color.js MIT
js/libs/jquery/jqueryui-amd/ie.js MIT
js/libs/jquery/jqueryui-amd/keycode.js MIT
js/libs/jquery/jqueryui-amd/jquery-patch.js MIT
js/libs/jquery/jqueryui-amd/labels.js MIT
js/libs/jquery/jqueryui-amd/form-reset-mixin.js MIT
js/libs/jquery/jqueryui-amd/unique-id.js MIT
js/libs/jquery/jqueryui-amd/scroll-parent.js MIT
js/libs/jquery/jqueryui-amd/tabbable.js MIT
js/libs/jquery/jqueryui-amd/version.js MIT
js/libs/jquery/jqueryui-amd/focusable.js MIT
js/libs/jquery/jqueryui-amd/data.js MIT
js/libs/jquery/jqueryui-amd/effect.js MIT
js/libs/jquery/jqueryui-amd/safe-blur.js MIT
js/libs/jquery/jqueryui-amd/form.js MIT
js/libs/jquery/jqueryui-amd/safe-active-element.js MIT
js/libs/jquery/jqueryui-amd/plugin.js MIT
js/libs/jquery/jqueryui-amd/widgets/sortable.js MIT
js/libs/jquery/jqueryui-amd/widgets/draggable.js MIT
js/libs/jquery/jqueryui-amd/widgets/mouse.js MIT
js/libs/jquery/jqueryui-amd/vendor/jquery-color/jquery.color.js MIT
js/libs/knockout/knockout.js MIT
js/libs/oj/v19.0.1/min/ojcspexpressionevaluator.js (cspexpressionevaluator.js) MIT
js/libs/oj/v19.0.1/min/ojexpparser.js (expparser.js) MIT
js/libs/oj/v19.0.1/min/ojknockout.js (knockout-fast-foreach.js) MIT
js/libs/oj/v19.0.1/min/ojmessagebanner.js (Ramda) MIT
js/libs/oj/v19.0.1/min/ojselectcombobox.js (Select2.js) Apache 2.0
js/libs/oj/v19.0.1/min/ojtree.js (jsTree.js) MIT
js/libs/oj/v19.0.1/ojL10n.js (requireJS i18n) MIT
js/libs/proj4js/dist/proj4.js MIT
js/libs/require/require.js MIT
js/libs/require/text.js MIT
js/libs/require-css/css.min.js (require-css) MIT
scss/oj/v19.0.1/3rdparty/normalize/normalize.scss MIT
js/libs/touchr/touchr.js MIT
js/libs/preact/dist/preact.umd.js MIT
Chai
https://github.com/chaijs/chai
Copyright (c) 2017 Chai.js Assertion Library
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
expression-eval
https://github.com/donmccurdy/expression-eval
Copyright (c) 2017 Don McCurdy
SOFTWARE.
jsep
https://github.com/soney/jsep
Copyright (c) 2013 Stephen Oney, https://ericsmekens.github.io/jsep/
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Knockout Fast Foreach v0.6.0 (2016-07-28T11:02:54.197Z)
By: Brian M Hunt (C) 2015 | License: MIT
proj4js
http://proj4js.org/
Copyright (C) 2014 Mike Adair, Richard Greenwood, Didier Richard, Stephen Irons, Olivier Terral and Calvin Metcalf;
Licensed under the MIT license
require-css
https://github.com/guybedford/require-css
Copyright (C) 2013 Guy Bedford
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Hammer.JS
http://hammerjs.github.io/
Copyright (C) 2011-2017 by Jorik Tangelder (Eight Media)
Foundation Responsive Library
http://foundation.zurb.com
Copyright 2014, ZURB
THE SOFTWARE.
Normalize.scss
Copyright © Nicolas Gallagher and Jonathan Neal
RequireJS i18n
http://github.com/requirejs/i18n for details
Copyright (c) 2010-2011, The Dojo Foundation
THE SOFTWARE.
jsTree http://jstree.com/
Copyright (c) 2012 Ivan Bozhanov (http://vakata.com)
THE SOFTWARE.
select2.js
https://github.com/select2/select2
Copyright 2012 Igor Vaynberg
This software is licensed under the Apache License, Version 2.0 (the "Apache License") or the GNU
General Public License version 2 (the "GPL License"). You may choose either license to govern your use of this software only upon the condition that you accept all of the terms of either the Apache License or the GPL License.
You may obtain a copy of the Apache License and the GPL License at:
http://www.apache.org/licenses/LICENSE-2.0
http://www.gnu.org/licenses/gpl-2.0.html
Apache License or the GPL Licesnse is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied. See the Apache License and the GPL License for
the specific language governing permissions and limitations under the Apache License and the GPL License.
jQuery UI
http://jqueryui.com
Includes: core.js, widget.js, mouse.js, position.js, draggable.js, sortable.js
jQuery JavaScript Library
http://jquery.com/
Copyright OpenJS Foundation and other contributors, https://openjsf.org/
JS Signals <http://millermedeiros.github.com/js-signals/>
Author: Miller Medeiros
RequireJS text
http://github.com/requirejs/text
Copyright jQuery Foundation and other contributors, https://jquery.org/
RequireJS
http://github.com/jrburke/requirejs
Knockout JavaScript library
Copyright (c) 2010 Steven Sanderson, the Knockout.js team, and other contributors
http://knockoutjs.com/
THE SOFTWARE.
Preact
The MIT License (MIT)
Copyright (c) 2015-present Jason Miller
SOFTWARE.
Ramda
https://github.com/ramda/ramda
Copyright (c) 2013-2020 Scott Sauyet and Michael Hurley
THE SOFTWARE.
========================= Apache-2.0 =========================
The following applies to all products licensed under the Apache 2.0 License:
You may not use the identified files except in compliance with the Apache
License, Version 2.0 (the "License.")
You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0.
under the License.
Apache License
Version 2.0, January 2004
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
(a) You must give any other recipients of the Work or
Derivative Works a copy of this License; and
(b) You must cause any modified files to carry prominent notices
stating that You changed the files; and
(c) You must retain, in the Source form of any Derivative Works
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
excluding those notices that do not pertain to any part of
the Derivative Works; and
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
include a readable copy of the attribution notices contained
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
of the following places: within a NOTICE text file distributed
as part of the Derivative Works; within the Source form or
documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and
wherever such third-party notices normally appear. The contents
of the NOTICE file are for informational purposes only and
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
or as an addendum to the NOTICE text from the Work, provided
that such additional attribution notices cannot be construed
as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!) The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
========================= Proj4js =========================
Mike Adair madairATdmsolutions.ca
Richard Greenwood richATgreenwoodmap.com
Didier Richard didier.richardATign.fr
Stephen Irons stephen.ironsATclear.net.nz
Olivier Terral oterralATgmail.com
Calvin Metcalf cmetcalfATappgeo.com
Copyright (c) 2014, Mike Adair, Richard Greenwood, Didier Richard, Stephen Irons, Olivier Terral and Calvin Metcalf
