netty-codec-http2
Provider: The Netty Project
Component(s): netty-codec-http2
Netty/Codec/HTTP (io.netty:netty-codec-http2)
Copyright 2014,2025 The Netty Project
Copyright 2014 Twitter, Inc.
The Netty Project
Please visit the Netty web site for more information:
* https://netty.io/
Copyright 2014 The Netty Project
The Netty Project licenses this file to you under the Apache License,
version 2.0 (the "License"); you may not use this file except in compliance
with the License. You may obtain a copy of the License at:
https://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
License for the specific language governing permissions and limitations
under the License.
Also, please refer to each LICENSE.<component>.txt file, which is located in
the 'license' directory of the distribution file, for the license terms of the
components that this product depends on.
This product contains the extensions to Java Collections Framework which has
been derived from the works by JSR-166 EG, Doug Lea, and Jason T. Greene:
* LICENSE:
* license/LICENSE.jsr166y.txt (Public Domain)
The person or persons who have associated work with this document (the
"Dedicator" or "Certifier") hereby either (a) certifies that, to the best of
his knowledge, the work of authorship identified is in the public domain of
the country from which the work is published, or (b) hereby dedicates whatever
copyright the dedicators holds in the work of authorship identified below (the
"Work") to the public domain. A certifier, moreover, dedicates any copyright
interest he may have in the associated work, and for these purposes, is
described as a "dedicator" below.
A certifier has taken reasonable steps to verify the copyright status of this
work. Certifier recognizes that his good faith efforts may not shield him from
liability if in fact the work certified is not in the public domain.
Dedicator makes this dedication for the benefit of the public at large and to
the detriment of the Dedicator's heirs and successors. Dedicator intends this
dedication to be an overt act of relinquishment in perpetuity of all present
and future rights under copyright law, whether vested or contingent, in the
Work. Dedicator understands that such relinquishment of all rights includes
the relinquishment of all rights to enforce (by lawsuit or otherwise) those
copyrights in the Work.
Dedicator recognizes that, once placed in the public domain, the Work may be
freely reproduced, distributed, transmitted, used, modified, built upon, or
otherwise exploited by anyone for any purpose, commercial or non-commercial,
and in any way, including by methods that have not yet been invented or
conceived.
* HOMEPAGE:
* http://gee.cs.oswego.edu/cgi-bin/viewcvs.cgi/jsr166/
* http://viewvc.jboss.org/cgi-bin/viewvc.cgi/jbosscache/experimental/jsr166/
This product contains a modified version of Robert Harder's Public Domain
Base64 Encoder and Decoder, which can be obtained at:
* LICENSE:
* license/LICENSE.base64.txt (Public Domain)
dedication to be an overt act of relinquishment in perpetuate of all present
conceived.
* HOMEPAGE:
* http://iharder.sourceforge.net/current/java/base64/
This product contains a modified portion of 'Webbit', an event based
WebSocket and HTTP server, which can be obtained at:
* LICENSE:
* license/LICENSE.webbit.txt (BSD License)
(BSD License: https://www.opensource.org/licenses/bsd-license)
Copyright (c) 2011, Joe Walnes, Aslak Hellesøy and contributors
All rights reserved.
Redistribution and use in source and binary forms, with or
without modification, are permitted provided that the
following conditions are met:
* Redistributions of source code must retain the above
copyright notice, this list of conditions and the
following disclaimer.
* Redistributions in binary form must reproduce the above
following disclaimer in the documentation and/or other
materials provided with the distribution.
* Neither the name of the Webbit nor the names of
its contributors may be used to endorse or promote products
derived from this software without specific prior written
permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
* HOMEPAGE:
* https://github.com/joewalnes/webbit
This product contains a modified portion of 'SLF4J', a simple logging
facade for Java, which can be obtained at:
* LICENSE:
* license/LICENSE.slf4j.txt (MIT License)
* Copyright (c) 2004-2007 QOS.ch
* All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining
* a copy of this software and associated documentation files (the
* "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish,
* distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to
* the following conditions:
* The above copyright notice and this permission notice shall be
* included in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
* LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
* OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
* WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* HOMEPAGE:
* https://www.slf4j.org/
This product contains a modified portion of 'Apache Harmony', an open source
Java SE, which can be obtained at:
* NOTICE:
* license/NOTICE.harmony.txt
Apache Harmony
Copyright 2006, 2010 The Apache Software Foundation.
This product includes software developed at
The Apache Software Foundation (https://www.apache.org/).
* LICENSE:
* license/LICENSE.harmony.txt (Apache License 2.0)
* HOMEPAGE:
* https://archive.apache.org/dist/harmony/
This product contains a modified portion of 'jbzip2', a Java bzip2 compression
and decompression library written by Matthew J. Francis. It can be obtained at:
* LICENSE:
* license/LICENSE.jbzip2.txt (MIT License)
Copyright (c) 2010-2011 Matthew J. Francis and Contributors of the jbzip2 Project
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
* HOMEPAGE:
* https://code.google.com/p/jbzip2/
This product contains a modified portion of 'libdivsufsort', a C API library to construct
the suffix array and the Burrows-Wheeler transformed string for any input string of
a constant-size alphabet written by Yuta Mori. It can be obtained at:
* LICENSE:
* license/LICENSE.libdivsufsort.txt (MIT License)
Copyright (c) 2003-2008 Yuta Mori All Rights Reserved.
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
Software is furnished to do so, subject to the following
conditions:
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
* HOMEPAGE:
* https://github.com/y-256/libdivsufsort
This product contains a modified portion of Nitsan Wakart's 'JCTools', Java Concurrency Tools for the JVM,
* LICENSE:
* license/LICENSE.jctools.txt (ASL2 License)
* HOMEPAGE:
* https://github.com/JCTools/JCTools
This product optionally depends on 'JZlib', a re-implementation of zlib in
pure Java, which can be obtained at:
* LICENSE:
* license/LICENSE.jzlib.txt (BSD style License)
Copyright (c) 2000,2001,2002,2003,2004 ymnk, JCraft,Inc. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in
the documentation and/or other materials provided with the distribution.
3. The names of the authors may not be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND
FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL JCRAFT,
INC. OR ANY CONTRIBUTORS TO THIS SOFTWARE BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* HOMEPAGE:
* http://www.jcraft.com/jzlib/
This product optionally depends on 'Compress-LZF', a Java library for encoding and
decoding data in LZF format, written by Tatu Saloranta. It can be obtained at:
* LICENSE:
* license/LICENSE.compress-lzf.txt (Apache License 2.0)
Copyright 2009-2010 Ning, Inc.
Licensed under the Apache License, Version 2.0 (the "License"); you may not
use this file except in compliance with the License. You may obtain a copy of
the License at https://www.apache.org/licenses/LICENSE-2.0
distributed under the License is distributed on an "AS IS" BASIS,WITHOUT
License for the specific language governing permissions and limitations under
the License.
* HOMEPAGE:
* https://github.com/ning/compress
This product optionally depends on 'lz4', a LZ4 Java compression
and decompression library written by Adrien Grand. It can be obtained at:
* LICENSE:
* license/LICENSE.lz4.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jpountz/lz4-java
This product optionally depends on 'lzma-java', a LZMA Java compression
and decompression library, which can be obtained at:
* LICENSE:
* license/LICENSE.lzma-java.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jponge/lzma-java
This product optionally depends on 'zstd-jni', a zstd-jni Java compression
* LICENSE:
* license/LICENSE.zstd-jni.txt (BSD)
Zstd-jni: JNI bindings to Zstd Library
Copyright (c) 2015-present, Luben Karavelov/ All rights reserved.
BSD License
Redistribution and use in source and binary forms, with or without modification,
* Redistributions of source code must retain the above copyright notice, this
* Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* HOMEPAGE:
* https://github.com/luben/zstd-jni
This product contains a modified portion of 'jfastlz', a Java port of FastLZ compression
and decompression library written by William Kinney. It can be obtained at:
* LICENSE:
* license/LICENSE.jfastlz.txt (MIT License)
The MIT License
Copyright (c) 2009 William Kinney
conditions:
* HOMEPAGE:
* https://code.google.com/p/jfastlz/
This product contains a modified portion of and optionally depends on 'Protocol Buffers', Google's data
interchange format, which can be obtained at:
* LICENSE:
* license/LICENSE.protobuf.txt (New BSD License)
Protocol Buffers - Google's data interchange format
Copyright 2013 Google Inc. All rights reserved.
https://developers.google.com/protocol-buffers/
met:
notice, this list of conditions and the following disclaimer.
copyright notice, this list of conditions and the following disclaimer
in the documentation and/or other materials provided with the
distribution.
* Neither the name of Google Inc. nor the names of its
contributors may be used to endorse or promote products derived from
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Code generated by the Protocol Buffer compiler is owned by the owner
of the input file used when generating it. This code is not
standalone and requires a support library to be linked with it. This
support library is itself covered by the above license.
* HOMEPAGE:
* https://github.com/google/protobuf
This product optionally depends on 'Bouncy Castle Crypto APIs' to generate
a temporary self-signed X.509 certificate when the JVM does not provide the
equivalent functionality. It can be obtained at:
* LICENSE:
* license/LICENSE.bouncycastle.txt (MIT License)
The MIT License (MIT)
Copyright (c) 2000 - 2013 The Legion of the Bouncy Castle Inc.
(https://www.bouncycastle.org)
THE SOFTWARE.
* HOMEPAGE:
* https://www.bouncycastle.org/
This product optionally depends on 'Snappy', a compression library produced
by Google Inc, which can be obtained at:
* LICENSE:
* license/LICENSE.snappy.txt (New BSD License)
Copyright 2011, Google Inc.
met:
distribution.
* HOMEPAGE:
* https://github.com/google/snappy
This product optionally depends on 'JBoss Marshalling', an alternative Java
serialization API, which can be obtained at:
* LICENSE:
* license/LICENSE.jboss-marshalling.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jboss-remoting/jboss-marshalling
This product optionally depends on 'Caliper', Google's micro-
benchmarking framework, which can be obtained at:
* LICENSE:
* license/LICENSE.caliper.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/google/caliper
This product optionally depends on 'Apache Commons Logging', a logging
* LICENSE:
* license/LICENSE.commons-logging.txt (Apache License 2.0)
* HOMEPAGE:
* https://commons.apache.org/logging/
This product optionally depends on 'Apache Log4J', a logging framework, which
can be obtained at:
* LICENSE:
* license/LICENSE.log4j.txt (Apache License 2.0)
* HOMEPAGE:
* https://logging.apache.org/log4j/
This product optionally depends on 'Aalto XML', an ultra-high performance
non-blocking XML processor, which can be obtained at:
* LICENSE:
* license/LICENSE.aalto-xml.txt (Apache License 2.0)
This copy of Aalto XML processor is licensed under the
Apache (Software) License, version 2.0 ("the License").
See the License for details about distribution rights, and the
specific rights regarding derivate works.
A copy is also included with both the downloadable source code package
and jar that contains class bytecodes, as file "ASL 2.0". In both cases,
that file should be located next to this file: in source distribution
the location should be "release-notes/asl"; and in jar "META-INF/"
* HOMEPAGE:
* https://wiki.fasterxml.com/AaltoHome
This product contains a modified version of 'HPACK', a Java implementation of
the HTTP/2 HPACK algorithm written by Twitter. It can be obtained at:
* LICENSE:
* license/LICENSE.hpack.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/twitter/hpack
the HTTP/2 HPACK algorithm written by Cory Benfield. It can be obtained at:
* LICENSE:
* license/LICENSE.hyper-hpack.txt (MIT License)
Copyright (c) 2014 Cory Benfield
THE SOFTWARE.
* HOMEPAGE:
* https://github.com/python-hyper/hpack/
the HTTP/2 HPACK algorithm written by Tatsuhiro Tsujikawa. It can be obtained at:
* LICENSE:
* license/LICENSE.nghttp2-hpack.txt (MIT License)
The MIT License
Copyright (c) 2012, 2014, 2015, 2016 Tatsuhiro Tsujikawa
Copyright (c) 2012, 2014, 2015, 2016 nghttp2 contributors
* HOMEPAGE:
* https://github.com/nghttp2/nghttp2/
This product contains a modified portion of 'Apache Commons Lang', a Java library
provides utilities for the java.lang API, which can be obtained at:
* LICENSE:
* license/LICENSE.commons-lang.txt (Apache License 2.0)
* HOMEPAGE:
* https://commons.apache.org/proper/commons-lang/
This product contains the Maven wrapper scripts from 'Maven Wrapper', that provides an easy way to ensure a user has everything necessary to run the Maven build.
* LICENSE:
* license/LICENSE.mvn-wrapper.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/takari/maven-wrapper
This product contains the dnsinfo.h header file, that provides a way to retrieve the system DNS configuration on MacOS.
This private header is also used by Apple's open source
mDNSResponder (https://opensource.apple.com/tarballs/mDNSResponder/).
* LICENSE:
* license/LICENSE.dnsinfo.txt (Apple Public Source License 2.0)
* Copyright (c) 2004-2006, 2008, 2009, 2011 Apple Inc. All rights reserved.
* @APPLE_LICENSE_HEADER_START@
* This file contains Original Code and/or Modifications of Original Code
* as defined in and that are subject to the Apple Public Source License
* Version 2.0 (the 'License'). You may not use this file except in
* compliance with the License. Please obtain a copy of the License at
* https://www.opensource.apple.com/apsl/ and read it before using this
* file.
* The Original Code and all software distributed under the License are
* distributed on an 'AS IS' basis, WITHOUT WARRANTY OF ANY KIND, EITHER
* EXPRESS OR IMPLIED, AND APPLE HEREBY DISCLAIMS ALL SUCH WARRANTIES,
* INCLUDING WITHOUT LIMITATION, ANY WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT OR NON-INFRINGEMENT.
* Please see the License for the specific language governing rights and
* limitations under the License.
* @APPLE_LICENSE_HEADER_END@
* HOMEPAGE:
* https://www.opensource.apple.com/source/configd/configd-453.19/dnsinfo/dnsinfo.h
This product optionally depends on 'Brotli4j', Brotli compression and
decompression for Java., which can be obtained at:
* LICENSE:
* license/LICENSE.brotli4j.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/hyperxpro/Brotli4j
Apache License
Version 2.0, January 2004
http://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
(a) You must give any other recipients of the Work or
Derivative Works a copy of this License; and
(b) You must cause any modified files to carry prominent notices
stating that You changed the files; and
(c) You must retain, in the Source form of any Derivative Works
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
excluding those notices that do not pertain to any part of
the Derivative Works; and
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
include a readable copy of the attribution notices contained
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
of the following places: within a NOTICE text file distributed
as part of the Derivative Works; within the Source form or
documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and
wherever such third-party notices normally appear. The contents
of the NOTICE file are for informational purposes only and
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
or as an addendum to the NOTICE text from the Work, provided
that such additional attribution notices cannot be construed
as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!) The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
you may not use this file except in compliance with the License.
http://www.apache.org/licenses/LICENSE-2.0
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
Fourth Party Dependencies
"Netty/Common" (io.netty:netty-common)
Copyright 2012,2025 The Netty Project
Copyright (c) 2004-2011 QOS.ch
Apache License Version 2.0
"Netty/Resolver" (io.netty:netty-resolver)
Copyright 2014,2021 The Netty Project
"Netty/Buffer" (io.netty:netty-buffer)
Copyright 2012,2024 The Netty Project
"Netty/Transport" (io.netty:netty-transport)
"Netty/Transport/Native/Unix/Common" (io.netty:netty-transport-native-unix-common)
Copyright 2014,2022 The Netty Project
"Netty/Codec" (io.netty:netty-codec)
"Netty/Handler" (io.netty:netty-handler)
Copyright 2011,2025 The Netty Project
"Netty/Codec/HTTP" (io.netty:netty-codec-http)
Copyright (c) 2011, Joe Walnes and contributors
Copyright (c) 2008-2009 Bjoern Hoehrmann <bjoern@hoehrmann.de>
