hapi-fhir-caching-caffeine
Provider: University Health Network
Component(s): hapi-fhir-caching-caffeine
Copyright: University Health Network
License: Apache 2.0
./LICENSE.txt
Apache License
Version 2.0, January 2004
https://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
(a) You must give any other recipients of the Work or
Derivative Works a copy of this License; and
(b) You must cause any modified files to carry prominent notices
stating that You changed the files; and
(c) You must retain, in the Source form of any Derivative Works
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
excluding those notices that do not pertain to any part of
the Derivative Works; and
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
include a readable copy of the attribution notices contained
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
of the following places: within a NOTICE text file distributed
as part of the Derivative Works; within the Source form or
documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and
wherever such third-party notices normally appear. The contents
of the NOTICE file are for informational purposes only and
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
or as an addendum to the NOTICE text from the Work, provided
that such additional attribution notices cannot be construed
as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!) The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
-------------- Separator --------------
./NOTICE.txt
Copyright 2015, University Health Network
you may not use this work except in compliance with the License.
Dependency: ca.uhn.hapi.fhir:hapi-fhir-base
Copyright: HL7, Inc
License: Apache 2.0
./LICENSE.txt
Apache 2.0 ( same as ca.uhn.hapi.fhir:hapi-fhir-caching-caffeine)
./NOTICE.txt
(Notice same as ca.uhn.hapi.fhir:hapi-fhir-caching-caffeine)
Dependency: ca.uhn.hapi.fhir:hapi-fhir-caching-api
License: Apache 2.0
./LICENSE.txt
./NOTICE.txt
Dependency: ch.randelshofer:fastdoubleparser
Copyright: Werner Randelshofer
License: MIT
./LICENSE
MIT License
Copyright (c) 2023 Werner Randelshofer, Switzerland.
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
MIT License
Copyright (c) 2021 The fast_float authors
person obtaining a copy of this software and associated
documentation files (the "Software"), to deal in the
limitation the rights to use, copy, modify, merge,
publish, distribute, sublicense, and/or sell copies of
is furnished to do so, subject to the following
conditions:
shall be included in all copies or substantial portions
of the Software.
ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED
TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR
DEALINGS IN THE SOFTWARE.
Copyright (c) Daniel Lemire
Boost Software License - Version 1.0 - August 17th, 2003
Permission is hereby granted, free of charge, to any person or organization
obtaining a copy of the software and accompanying documentation covered by
this license (the "Software") to use, reproduce, display, distribute,
execute, and transmit the Software, and to prepare derivative works of the
Software, and to permit third-parties to whom the Software is furnished to
do so, all subject to the following:
The copyright notices in the Software and this entire statement, including
the above license grant, this restriction and the following disclaimer,
must be included in all copies of the Software, in whole or in part, and
all derivative works of the Software, unless such copies or derivative
works are solely in the form of machine-executable object code generated by
a source language processor.
FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT
SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE
FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE,
ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
Copyright 2022 Tim Buktu
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS “AS IS” AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
MIT ( same as ch.randelshofer:fastdoubleparser)
./NOTICE
# FastDoubleParser
This is a Java port of Daniel Lemire's fast_float project.
This project provides parsers for double, float, BigDecimal and BigInteger values.
## Copyright
Copyright © 2023 Werner Randelshofer, Switzerland.
## Licensing
This code is licensed under MIT License.
https://github.com/wrandelshofer/FastDoubleParser/blob/522be16e145f43308c43b23094e31d5efcaa580e/LICENSE
(The file 'LICENSE' is included in the sources and classes Jar files that are released by this project
- as is required by that license.)
Some portions of the code have been derived from other projects.
All these projects require that we include a copyright notice, and some require that we also include some text of their
license file.
fast_double_parser, Copyright (c) 2022 Daniel Lemire. BSL License.
https://github.com/lemire/fast_double_parser
https://github.com/lemire/fast_double_parser/blob/07d9189a8fb815fe800cb15ca022e7a07093236e/LICENSE.BSL
(The file 'thirdparty-LICENSE' is included in the sources and classes Jar files that are released by this project
fast_float, Copyright (c) 2021 The fast_float authors. MIT License.
https://github.com/fastfloat/fast_float
https://github.com/fastfloat/fast_float/blob/cc1e01e9eee74128e48d51488a6b1df4a767a810/LICENSE-MIT
bigint, Copyright 2020 Tim Buktu. 2-clause BSD License.
https://github.com/tbuktu/bigint/tree/floatfft
https://github.com/tbuktu/bigint/blob/617c8cd8a7c5e4fb4d919c6a4d11e2586107f029/LICENSE
https://github.com/wrandelshofer/FastDoubleParser/blob/39e123b15b71f29a38a087d16a0bc620fc879aa6/bigint-LICENSE
(We only use those portions of the bigint project that can be licensed under 2-clause BSD License.)
Dependency: com.fasterxml.jackson.core:jackson-annotations
Copyright: FasterXML,LLC
License: Apache 2.0
./LICENSE
./src/main/resources/META-INF/NOTICE
# Jackson JSON processor
Jackson is a high-performance, Free/Open Source JSON processing library.
It was originally written by Tatu Saloranta (tatu.saloranta@iki.fi), and has
been in development since 2007.
It is currently developed by a community of developers.
## Copyright
Copyright 2007-, Tatu Saloranta (tatu.saloranta@iki.fi)
## Licensing
Jackson 2.x core and extension components are licensed under Apache License 2.0
To find the details that apply to this artifact see the accompanying LICENSE file.
## Credits
A list of contributors may be found from CREDITS(-2.x) file, which is included
in some artifacts (usually source distributions); but is always available
from the source code management (SCM) system project uses.
Dependency: com.fasterxml.jackson.core:jackson-core
License: Apache 2.0
./LICENSE
./src/main/resources/META-INF/jackson-core-NOTICE
## Copyright
## Licensing
## Credits
## FastDoubleParser
jackson-core bundles a shaded copy of FastDoubleParser <https://github.com/wrandelshofer/FastDoubleParser>.
That code is available under an MIT license <https://github.com/wrandelshofer/FastDoubleParser/blob/main/LICENSE>
under the following copyright.
Copyright © 2023 Werner Randelshofer, Switzerland. MIT License.
See FastDoubleParser-NOTICE for details of other source code included in FastDoubleParser
and the licenses and copyrights that apply to that code.
Dependency: com.fasterxml.jackson.core:jackson-databind
License: Apache 2.0
./LICENSE
(Notice same as com.fasterxml.jackson.core:jackson-annotations)
Dependency: com.fasterxml.jackson.datatype:jackson-datatype-jsr310
License: Apache 2.0
./src/main/resources/META-INF/LICENSE
This copy of Jackson JSON processor Java 8 Date/Time module is licensed under the
Apache (Software) License, version 2.0 ("the License").
See the License for details about distribution rights, and the
specific rights regarding derivative works.
You may obtain a copy of the License at:
https://www.apache.org/licenses/LICENSE-2.0
## Licensing
Jackson components are licensed under Apache (Software) License, version 2.0,
as per accompanying LICENSE file.
## Credits
A list of contributors may be found from CREDITS file, which is included
Dependency: com.github.ben-manes.caffeine:caffeine
Copyright: Ben Manes
License: Apache 2.0
./LICENSE
Dependency: com.google.code.findbugs:jsr305
Copyright: JSR305 expert group
License: BSD 3-Clause
Copyright (c) 2007-2009, JSR305 expert group
All rights reserved.
modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice,
* Neither the name of the JSR305 expert group nor the names of its
contributors may be used to endorse or promote products derived from
this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Other copyright notices in this distribution:
== jcip-annotations (RELICENSED to Oracle under BSD 3-clause)
Copyright (c) 2005, Brian Goetz and Tim Peierls
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Dependency: com.google.errorprone:error_prone_annotations
Copyright: The Error Prone Authors
License: Apache 2.0
./COPYING
Dependency: com.google.guava:failureaccess
Copyright: Google
License: Apache 2.0
./LICENSE
Dependency: com.google.guava:guava
Copyright: Google Inc.
License: Apache 2.0
./LICENSE
Dependency: com.google.guava:listenablefuture
License: Apache 2.0
./COPYING
Dependency: com.google.j2objc:j2objc-annotations
License: Apache 2.0
./LICENSE
Dependency: commons-codec:commons-codec
Copyright: The Apache Software Foundation
License: Apache 2.0
./LICENSE-header.txt
* Licensed to the Apache Software Foundation (ASF) under one or more
* contributor license agreements. See the NOTICE file distributed with
* this work for additional information regarding copyright ownership.
* The ASF licenses this file to You under the Apache License, Version 2.0
* (the "License"); you may not use this file except in compliance with
* the License. You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
./LICENSE.txt
./NOTICE.txt
Apache Commons Codec
Copyright 2002-2020 The Apache Software Foundation
This product includes software developed at
The Apache Software Foundation (https://www.apache.org/).
src/test/org/apache/commons/codec/language/DoubleMetaphoneTest.java
contains test data from http://aspell.net/test/orig/batch0.tab.
Copyright (C) 2002 Kevin Atkinson (kevina@gnu.org)
The content of package org.apache.commons.codec.language.bm has been translated
from the original php source code available at http://stevemorse.org/phoneticinfo.htm
with permission from the original authors.
Original source copyright:
Copyright (c) 2008 Alexander Beider & Stephen P. Morse.
Dependency: commons-io:commons-io
License: Apache 2.0
./LICENSE.txt
./NOTICE.txt
Apache Commons IO
Copyright 2002-2024 The Apache Software Foundation
Dependency: io.opentelemetry:opentelemetry-api
Copyright: The OpenTelemetry Authors
License: Apache 2.0
./LICENSE
Dependency: io.opentelemetry:opentelemetry-context
License: Apache 2.0
./LICENSE
Dependency: io.opentelemetry.instrumentation:opentelemetry-instrumentation-annotations
License: Apache 2.0
./LICENSE
./licenses/byte-buddy-dep-1.15.10.jar/META-INF/LICENSE
Apache License
1. Definitions.
./licenses/jackson-annotations-2.18.1.jar/META-INF/LICENSE
./licenses/jackson-core-2.18.1.jar/META-INF/LICENSE
./licenses/jackson-databind-2.18.1.jar/META-INF/LICENSE
./licenses/jackson-dataformat-yaml-2.18.1.jar/META-INF/LICENSE
This copy of Jackson JSON processor YAML module is licensed under the
./licenses/licenses.md
# javaagent
## Dependency License Report
## Apache License, Version 2.0
**1** **Group:** `com.blogspot.mydailyjava` **Name:** `weak-lock-free` **Version:** `0.18`
> - **Manifest License**: Apache License, Version 2.0 (Not Packaged)
> - **POM Project URL**: [https://github.com/raphw/weak-lock-free](https://github.com/raphw/weak-lock-free)
> - **POM License**: Apache License, Version 2.0 - [http://www.apache.org/licenses/LICENSE-2.0](http://www.apache.org/licenses/LICENSE-2.0)
**2** **Group:** `com.fasterxml.jackson.core` **Name:** `jackson-annotations` **Version:** `2.18.1`
> - **Project URL**: [https://github.com/FasterXML/jackson](https://github.com/FasterXML/jackson)
> - **POM License**: Apache License, Version 2.0 - [https://www.apache.org/licenses/LICENSE-2.0](https://www.apache.org/licenses/LICENSE-2.0)
> - **Embedded license files**: [jackson-annotations-2.18.1.jar/META-INF/LICENSE](jackson-annotations-2.18.1.jar/META-INF/LICENSE)
- [jackson-annotations-2.18.1.jar/META-INF/NOTICE](jackson-annotations-2.18.1.jar/META-INF/NOTICE)
**3** **Group:** `com.fasterxml.jackson.core` **Name:** `jackson-core` **Version:** `2.18.1`
> - **Project URL**: [https://github.com/FasterXML/jackson-core](https://github.com/FasterXML/jackson-core)
> - **Embedded license files**: [jackson-core-2.18.1.jar/META-INF/LICENSE](jackson-core-2.18.1.jar/META-INF/LICENSE)
- [jackson-core-2.18.1.jar/META-INF/NOTICE](jackson-core-2.18.1.jar/META-INF/NOTICE)
**4** **Group:** `com.fasterxml.jackson.core` **Name:** `jackson-databind` **Version:** `2.18.1`
> - **Embedded license files**: [jackson-databind-2.18.1.jar/META-INF/LICENSE](jackson-databind-2.18.1.jar/META-INF/LICENSE)
- [jackson-databind-2.18.1.jar/META-INF/NOTICE](jackson-databind-2.18.1.jar/META-INF/NOTICE)
**5** **Group:** `com.fasterxml.jackson.dataformat` **Name:** `jackson-dataformat-yaml` **Version:** `2.18.1`
> - **Project URL**: [https://github.com/FasterXML/jackson-dataformats-text](https://github.com/FasterXML/jackson-dataformats-text)
> - **Embedded license files**: [jackson-dataformat-yaml-2.18.1.jar/META-INF/LICENSE](jackson-dataformat-yaml-2.18.1.jar/META-INF/LICENSE)
- [jackson-dataformat-yaml-2.18.1.jar/META-INF/NOTICE](jackson-dataformat-yaml-2.18.1.jar/META-INF/NOTICE)
**6** **Group:** `com.google.cloud.opentelemetry` **Name:** `detector-resources-support` **Version:** `0.33.0`
> - **POM Project URL**: [https://github.com/GoogleCloudPlatform/opentelemetry-operations-java](https://github.com/GoogleCloudPlatform/opentelemetry-operations-java)
**7** **Group:** `com.googlecode.concurrentlinkedhashmap` **Name:** `concurrentlinkedhashmap-lru` **Version:** `1.4.2`
> - **POM Project URL**: [http://code.google.com/p/concurrentlinkedhashmap](http://code.google.com/p/concurrentlinkedhashmap)
**8** **Group:** `com.squareup.okhttp3` **Name:** `okhttp` **Version:** `4.12.0`
> - **POM Project URL**: [https://square.github.io/okhttp/](https://square.github.io/okhttp/)
> - **Embedded license files**: [okhttp-4.12.0.jar/okhttp3/internal/publicsuffix/NOTICE](okhttp-4.12.0.jar/okhttp3/internal/publicsuffix/NOTICE)
**9** **Group:** `com.squareup.okio` **Name:** `okio` **Version:** `3.9.1`
> - **POM Project URL**: [https://github.com/square/okio/](https://github.com/square/okio/)
**10** **Group:** `com.squareup.okio` **Name:** `okio-jvm` **Version:** `3.9.1`
**11** **Group:** `io.opentelemetry` **Name:** `opentelemetry-api` **Version:** `1.44.1`
> - **POM Project URL**: [https://github.com/open-telemetry/opentelemetry-java](https://github.com/open-telemetry/opentelemetry-java)
**12** **Group:** `io.opentelemetry` **Name:** `opentelemetry-api-incubator` **Version:** `1.44.1-alpha`
**13** **Group:** `io.opentelemetry` **Name:** `opentelemetry-context` **Version:** `1.44.1`
**14** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-common` **Version:** `1.44.1`
**15** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-logging` **Version:** `1.44.1`
**16** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-logging-otlp` **Version:** `1.44.1`
**17** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-otlp` **Version:** `1.44.1`
**18** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-otlp-common` **Version:** `1.44.1`
**19** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-prometheus` **Version:** `1.44.1-alpha`
**20** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-sender-okhttp` **Version:** `1.44.1`
**21** **Group:** `io.opentelemetry` **Name:** `opentelemetry-exporter-zipkin` **Version:** `1.44.1`
**22** **Group:** `io.opentelemetry` **Name:** `opentelemetry-extension-kotlin` **Version:** `1.44.1`
**23** **Group:** `io.opentelemetry` **Name:** `opentelemetry-extension-trace-propagators` **Version:** `1.44.1`
**24** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk` **Version:** `1.44.1`
**25** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-common` **Version:** `1.44.1`
**26** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-extension-autoconfigure` **Version:** `1.44.1`
**27** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-extension-autoconfigure-spi` **Version:** `1.44.1`
**28** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-extension-incubator` **Version:** `1.44.1-alpha`
**29** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-extension-jaeger-remote-sampler` **Version:** `1.44.1`
**30** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-logs` **Version:** `1.44.1`
**31** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-metrics` **Version:** `1.44.1`
**32** **Group:** `io.opentelemetry` **Name:** `opentelemetry-sdk-trace` **Version:** `1.44.1`
**33** **Group:** `io.opentelemetry.contrib` **Name:** `opentelemetry-aws-resources` **Version:** `1.40.0-alpha`
> - **POM Project URL**: [https://github.com/open-telemetry/opentelemetry-java-contrib](https://github.com/open-telemetry/opentelemetry-java-contrib)
**34** **Group:** `io.opentelemetry.contrib` **Name:** `opentelemetry-aws-xray-propagator` **Version:** `1.40.0-alpha`
**35** **Group:** `io.opentelemetry.contrib` **Name:** `opentelemetry-baggage-processor` **Version:** `1.40.0-alpha`
**36** **Group:** `io.opentelemetry.contrib` **Name:** `opentelemetry-gcp-resources` **Version:** `1.40.0-alpha`
**37** **Group:** `io.opentelemetry.semconv` **Name:** `opentelemetry-semconv` **Version:** `1.28.0-alpha`
> - **POM Project URL**: [https://github.com/open-telemetry/semantic-conventions-java](https://github.com/open-telemetry/semantic-conventions-java)
**38** **Group:** `io.opentelemetry.semconv` **Name:** `opentelemetry-semconv-incubating` **Version:** `1.28.0-alpha`
**39** **Group:** `io.prometheus` **Name:** `prometheus-metrics-config` **Version:** `1.3.3`
**40** **Group:** `io.prometheus` **Name:** `prometheus-metrics-exporter-common` **Version:** `1.3.3`
**41** **Group:** `io.prometheus` **Name:** `prometheus-metrics-exporter-httpserver` **Version:** `1.3.3`
**42** **Group:** `io.prometheus` **Name:** `prometheus-metrics-exposition-formats` **Version:** `1.3.3`
**43** **Group:** `io.prometheus` **Name:** `prometheus-metrics-model` **Version:** `1.3.3`
**44** **Group:** `io.zipkin.reporter2` **Name:** `zipkin-reporter` **Version:** `3.4.2`
> - **Manifest Project URL**: [https://zipkin.io/](https://zipkin.io/)
> - **Embedded license files**: [zipkin-reporter-3.4.2.jar/META-INF/LICENSE](zipkin-reporter-3.4.2.jar/META-INF/LICENSE)
**45** **Group:** `io.zipkin.reporter2` **Name:** `zipkin-sender-okhttp3` **Version:** `3.4.2`
> - **Embedded license files**: [zipkin-sender-okhttp3-3.4.2.jar/META-INF/LICENSE](zipkin-sender-okhttp3-3.4.2.jar/META-INF/LICENSE)
**46** **Group:** `io.zipkin.zipkin2` **Name:** `zipkin` **Version:** `2.27.1`
> - **Manifest Project URL**: [http://zipkin.io/](http://zipkin.io/)
> - **Embedded license files**: [zipkin-2.27.1.jar/META-INF/LICENSE](zipkin-2.27.1.jar/META-INF/LICENSE)
**47** **Group:** `net.bytebuddy` **Name:** `byte-buddy-dep` **Version:** `1.15.10`
> - **Embedded license files**: [byte-buddy-dep-1.15.10.jar/META-INF/LICENSE](byte-buddy-dep-1.15.10.jar/META-INF/LICENSE)
- [byte-buddy-dep-1.15.10.jar/META-INF/NOTICE](byte-buddy-dep-1.15.10.jar/META-INF/NOTICE)
**48** **Group:** `org.jetbrains` **Name:** `annotations` **Version:** `13.0`
> - **POM Project URL**: [http://www.jetbrains.org](http://www.jetbrains.org)
**49** **Group:** `org.jetbrains.kotlin` **Name:** `kotlin-stdlib` **Version:** `2.0.21`
> - **POM Project URL**: [https://kotlinlang.org/](https://kotlinlang.org/)
**50** **Group:** `org.jetbrains.kotlin` **Name:** `kotlin-stdlib-jdk7` **Version:** `2.0.21`
**51** **Group:** `org.jetbrains.kotlin` **Name:** `kotlin-stdlib-jdk8` **Version:** `2.0.21`
**52** **Group:** `org.ow2.asm` **Name:** `asm` **Version:** `9.7.1`
> - **Manifest Project URL**: [http://asm.ow2.org](http://asm.ow2.org)
> - **Manifest License**: The 3-Clause BSD License (Not Packaged)
> - **POM Project URL**: [http://asm.ow2.io/](http://asm.ow2.io/)
> - **POM License**: The 3-Clause BSD License - [https://opensource.org/licenses/BSD-3-Clause](https://opensource.org/licenses/BSD-3-Clause)
**53** **Group:** `org.ow2.asm` **Name:** `asm-analysis` **Version:** `9.7.1`
**54** **Group:** `org.ow2.asm` **Name:** `asm-commons` **Version:** `9.7.1`
**55** **Group:** `org.ow2.asm` **Name:** `asm-tree` **Version:** `9.7.1`
**56** **Group:** `org.ow2.asm` **Name:** `asm-util` **Version:** `9.7.1`
**57** **Group:** `org.snakeyaml` **Name:** `snakeyaml-engine` **Version:** `2.8`
> - **POM Project URL**: [https://bitbucket.org/snakeyaml/snakeyaml-engine](https://bitbucket.org/snakeyaml/snakeyaml-engine)
**58** **Group:** `org.yaml` **Name:** `snakeyaml` **Version:** `2.3`
> - **POM Project URL**: [https://bitbucket.org/snakeyaml/snakeyaml](https://bitbucket.org/snakeyaml/snakeyaml)
## MIT License
**59** **Group:** `org.slf4j` **Name:** `slf4j-api` **Version:** `2.0.16`
> - **Project URL**: [http://www.slf4j.org](http://www.slf4j.org)
> - **POM License**: MIT License - [https://opensource.org/licenses/MIT](https://opensource.org/licenses/MIT)
> - **Embedded license files**: [slf4j-api-2.0.16.jar/META-INF/LICENSE.txt](slf4j-api-2.0.16.jar/META-INF/LICENSE.txt)
**60** **Group:** `org.slf4j` **Name:** `slf4j-simple` **Version:** `2.0.16`
> - **Embedded license files**: [slf4j-simple-2.0.16.jar/META-INF/LICENSE.txt](slf4j-simple-2.0.16.jar/META-INF/LICENSE.txt)
## The 3-Clause BSD License
**61** **Group:** `org.ow2.asm` **Name:** `asm` **Version:** `9.7.1`
**62** **Group:** `org.ow2.asm` **Name:** `asm-analysis` **Version:** `9.7.1`
**63** **Group:** `org.ow2.asm` **Name:** `asm-commons` **Version:** `9.7.1`
**64** **Group:** `org.ow2.asm` **Name:** `asm-tree` **Version:** `9.7.1`
**65** **Group:** `org.ow2.asm` **Name:** `asm-util` **Version:** `9.7.1`
./licenses/slf4j-api-2.0.16.jar/META-INF/LICENSE.txt
Copyright (c) 2004-2022 QOS.ch Sarl (Switzerland)
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
included in all copies or substantial portions of the Software.
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
./licenses/slf4j-simple-2.0.16.jar/META-INF/LICENSE.txt
MIT ( same as io.opentelemetry.instrumentation:opentelemetry-instrumentation-annotations)
./licenses/zipkin-2.27.1.jar/META-INF/LICENSE
Apache License
1. Definitions.
boilerplate notice, with the fields enclosed by brackets "{}"
Copyright {yyyy} {name of copyright owner}
This product contains a modified part of Gson, distributed by Google:
* License: Apache License v2.0
* Homepage: https://github.com/google/gson
This product contains a modified part of Guava, distributed by Google:
* Homepage: https://github.com/google/guava
This product contains a modified part of Okio, distributed by Square:
* Homepage: https://github.com/square/okio
./licenses/zipkin-reporter-3.4.2.jar/META-INF/LICENSE
Apache License
1. Definitions.
./licenses/zipkin-sender-okhttp3-3.4.2.jar/META-INF/LICENSE
Apache 2.0 ( same as io.opentelemetry.instrumentation:opentelemetry-instrumentation-annotations)
./instrumentation/jdbc/library/NOTICE.txt
This product contains a modified part of OpenTracing JDBC Instrumentation:
* License:
Copyright 2017-2021 The OpenTracing Authors
* Homepage: https://github.com/opentracing-contrib/java-jdbc
./instrumentation/spring/spring-webflux/spring-webflux-5.3/library/NOTICE.txt
This product contains a modified part of Spring Cloud Sleuth:
* License:
Copyright 2013-2020 the original author or authors.
* Homepage: https://github.com/spring-cloud/spring-cloud-sleuth
./licenses/byte-buddy-dep-1.15.10.jar/META-INF/NOTICE
Copyright 2014 - Present Rafael Winterhalter
./licenses/jackson-annotations-2.18.1.jar/META-INF/NOTICE
./licenses/jackson-core-2.18.1.jar/META-INF/NOTICE
(Notice same as com.fasterxml.jackson.core:jackson-core)
./licenses/jackson-databind-2.18.1.jar/META-INF/NOTICE
./licenses/jackson-dataformat-yaml-2.18.1.jar/META-INF/NOTICE
## Copyright
## Licensing
## Credits
./licenses/okhttp-4.12.0.jar/okhttp3/internal/publicsuffix/NOTICE
Note that publicsuffixes.gz is compiled from The Public Suffix List:
https://publicsuffix.org/list/public_suffix_list.dat
It is subject to the terms of the Mozilla Public License, v. 2.0:
https://mozilla.org/MPL/2.0/
Dependency: jakarta.annotation:jakarta.annotation-api
Copyright: Eclipse Foundation
License: EPL 2.0 + GPL v.2 with CPE
./LICENSE.md
# Eclipse Public License - v 2.0
THE ACCOMPANYING PROGRAM IS PROVIDED UNDER THE TERMS OF THIS ECLIPSE
PUBLIC LICENSE ("AGREEMENT"). ANY USE, REPRODUCTION OR DISTRIBUTION
OF THE PROGRAM CONSTITUTES RECIPIENT'S ACCEPTANCE OF THIS AGREEMENT.
1. DEFINITIONS
"Contribution" means:
a) in the case of the initial Contributor, the initial content
Distributed under this Agreement, and
b) in the case of each subsequent Contributor:
i) changes to the Program, and
ii) additions to the Program;
where such changes and/or additions to the Program originate from
and are Distributed by that particular Contributor. A Contribution
"originates" from a Contributor if it was added to the Program by
such Contributor itself or anyone acting on such Contributor's behalf.
Contributions do not include changes or additions to the Program that
are not Modified Works.
"Contributor" means any person or entity that Distributes the Program.
"Licensed Patents" mean patent claims licensable by a Contributor which
are necessarily infringed by the use or sale of its Contribution alone
or when combined with the Program.
"Program" means the Contributions Distributed in accordance with this
Agreement.
"Recipient" means anyone who receives the Program under this Agreement
or any Secondary License (as applicable), including Contributors.
"Derivative Works" shall mean any work, whether in Source Code or other
form, that is based on (or derived from) the Program and for which the
"Modified Works" shall mean any work in Source Code or other form that
results from an addition to, deletion from, or modification of the
contents of the Program, including, for purposes of clarity any new file
in Source Code form that contains any contents of the Program. Modified
Works shall not include works that contain only declarations,
interfaces, types, classes, structures, or files of the Program solely
in each case in order to link to, bind by name, or subclass the Program
or Modified Works thereof.
"Distribute" means the acts of a) distributing or b) making available
in any manner that enables the transfer of a copy.
"Source Code" means the form of a Program preferred for making
modifications, including but not limited to software source code,
documentation source, and configuration files.
"Secondary License" means either the GNU General Public License,
Version 2.0, or any later versions of that license, including any
exceptions or additional permissions as identified by the initial
Contributor.
2. GRANT OF RIGHTS
a) Subject to the terms of this Agreement, each Contributor hereby
grants Recipient a non-exclusive, worldwide, royalty-free copyright
license to reproduce, prepare Derivative Works of, publicly display,
publicly perform, Distribute and sublicense the Contribution of such
Contributor, if any, and such Derivative Works.
b) Subject to the terms of this Agreement, each Contributor hereby
grants Recipient a non-exclusive, worldwide, royalty-free patent
license under Licensed Patents to make, use, sell, offer to sell,
import and otherwise transfer the Contribution of such Contributor,
if any, in Source Code or other form. This patent license shall
apply to the combination of the Contribution and the Program if, at
the time the Contribution is added by the Contributor, such addition
of the Contribution causes such combination to be covered by the
Licensed Patents. The patent license shall not apply to any other
combinations which include the Contribution. No hardware per se is
licensed hereunder.
c) Recipient understands that although each Contributor grants the
licenses to its Contributions set forth herein, no assurances are
provided by any Contributor that the Program does not infringe the
patent or other intellectual property rights of any other entity.
Each Contributor disclaims any liability to Recipient for claims
brought by any other entity based on infringement of intellectual
property rights or otherwise. As a condition to exercising the
rights and licenses granted hereunder, each Recipient hereby
assumes sole responsibility to secure any other intellectual
property rights needed, if any. For example, if a third party
patent license is required to allow Recipient to Distribute the
Program, it is Recipient's responsibility to acquire that license
before distributing the Program.
d) Each Contributor represents that to its knowledge it has
sufficient copyright rights in its Contribution, if any, to grant
the copyright license set forth in this Agreement.
e) Notwithstanding the terms of any Secondary License, no
Contributor makes additional grants to any Recipient (other than
those set forth in this Agreement) as a result of such Recipient's
receipt of the Program under the terms of a Secondary License
(if permitted under the terms of Section 3).
3. REQUIREMENTS
3.1 If a Contributor Distributes the Program in any form, then:
a) the Program must also be made available as Source Code, in
accordance with section 3.2, and the Contributor must accompany
the Program with a statement that the Source Code for the Program
is available under this Agreement, and informs Recipients how to
obtain it in a reasonable manner on or through a medium customarily
used for software exchange; and
b) the Contributor may Distribute the Program under a license
different than this Agreement, provided that such license:
i) effectively disclaims on behalf of all other Contributors all
warranties and conditions, express and implied, including
warranties or conditions of title and non-infringement, and
implied warranties or conditions of merchantability and fitness
for a particular purpose;
ii) effectively excludes on behalf of all other Contributors all
liability for damages, including direct, indirect, special,
incidental and consequential damages, such as lost profits;
iii) does not attempt to limit or alter the recipients' rights
in the Source Code under section 3.2; and
iv) requires any subsequent distribution of the Program by any
party to be under a license that satisfies the requirements
of this section 3.
3.2 When the Program is Distributed as Source Code:
a) it must be made available under this Agreement, or if the
Program (i) is combined with other material in a separate file or
files made available under a Secondary License, and (ii) the initial
Contributor attached to the Source Code the notice described in
Exhibit A of this Agreement, then the Program may be made available
under the terms of such Secondary Licenses, and
b) a copy of this Agreement must be included with each copy of
the Program.
3.3 Contributors may not remove or alter any copyright, patent,
trademark, attribution notices, disclaimers of warranty, or limitations
of liability ("notices") contained within the Program from any copy of
the Program which they Distribute, provided that Contributors may add
their own appropriate notices.
4. COMMERCIAL DISTRIBUTION
Commercial distributors of software may accept certain responsibilities
with respect to end users, business partners and the like. While this
license is intended to facilitate the commercial use of the Program,
the Contributor who includes the Program in a commercial product
offering should do so in a manner which does not create potential
liability for other Contributors. Therefore, if a Contributor includes
the Program in a commercial product offering, such Contributor
("Commercial Contributor") hereby agrees to defend and indemnify every
other Contributor ("Indemnified Contributor") against any losses,
damages and costs (collectively "Losses") arising from claims, lawsuits
and other legal actions brought by a third party against the Indemnified
Contributor to the extent caused by the acts or omissions of such
Commercial Contributor in connection with its distribution of the Program
in a commercial product offering. The obligations in this section do not
apply to any claims or Losses relating to any actual or alleged
intellectual property infringement. In order to qualify, an Indemnified
Contributor must: a) promptly notify the Commercial Contributor in
writing of such claim, and b) allow the Commercial Contributor to control,
and cooperate with the Commercial Contributor in, the defense and any
related settlement negotiations. The Indemnified Contributor may
participate in any such claim at its own expense.
For example, a Contributor might include the Program in a commercial
product offering, Product X. That Contributor is then a Commercial
Contributor. If that Commercial Contributor then makes performance
claims, or offers warranties related to Product X, those performance
claims and warranties are such Commercial Contributor's responsibility
alone. Under this section, the Commercial Contributor would have to
defend claims against the other Contributors related to those performance
claims and warranties, and if a court requires any other Contributor to
pay any damages as a result, the Commercial Contributor must pay
those damages.
5. NO WARRANTY
EXCEPT AS EXPRESSLY SET FORTH IN THIS AGREEMENT, AND TO THE EXTENT
PERMITTED BY APPLICABLE LAW, THE PROGRAM IS PROVIDED ON AN "AS IS"
BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, EITHER EXPRESS OR
IMPLIED INCLUDING, WITHOUT LIMITATION, ANY WARRANTIES OR CONDITIONS OF
TITLE, NON-INFRINGEMENT, MERCHANTABILITY OR FITNESS FOR A PARTICULAR
PURPOSE. Each Recipient is solely responsible for determining the
appropriateness of using and distributing the Program and assumes all
risks associated with its exercise of rights under this Agreement,
including but not limited to the risks and costs of program errors,
compliance with applicable laws, damage to or loss of data, programs
or equipment, and unavailability or interruption of operations.
6. DISCLAIMER OF LIABILITY
PERMITTED BY APPLICABLE LAW, NEITHER RECIPIENT NOR ANY CONTRIBUTORS
SHALL HAVE ANY LIABILITY FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING WITHOUT LIMITATION LOST
PROFITS), HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
ARISING IN ANY WAY OUT OF THE USE OR DISTRIBUTION OF THE PROGRAM OR THE
EXERCISE OF ANY RIGHTS GRANTED HEREUNDER, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES.
7. GENERAL
If any provision of this Agreement is invalid or unenforceable under
applicable law, it shall not affect the validity or enforceability of
the remainder of the terms of this Agreement, and without further
action by the parties hereto, such provision shall be reformed to the
minimum extent necessary to make such provision valid and enforceable.
If Recipient institutes patent litigation against any entity
(including a cross-claim or counterclaim in a lawsuit) alleging that the
Program itself (excluding combinations of the Program with other software
or hardware) infringes such Recipient's patent(s), then such Recipient's
rights granted under Section 2(b) shall terminate as of the date such
All Recipient's rights under this Agreement shall terminate if it
fails to comply with any of the material terms or conditions of this
Agreement and does not cure such failure in a reasonable period of
time after becoming aware of such noncompliance. If all Recipient's
rights under this Agreement terminate, Recipient agrees to cease use
and distribution of the Program as soon as reasonably practicable.
However, Recipient's obligations under this Agreement and any licenses
granted by Recipient relating to the Program shall continue and survive.
Everyone is permitted to copy and distribute copies of this Agreement,
but in order to avoid inconsistency the Agreement is copyrighted and
may only be modified in the following manner. The Agreement Steward
reserves the right to publish new versions (including revisions) of
this Agreement from time to time. No one other than the Agreement
Steward has the right to modify this Agreement. The Eclipse Foundation
is the initial Agreement Steward. The Eclipse Foundation may assign the
responsibility to serve as the Agreement Steward to a suitable separate
entity. Each new version of the Agreement will be given a distinguishing
version number. The Program (including Contributions) may always be
Distributed subject to the version of the Agreement under which it was
received. In addition, after a new version of the Agreement is published,
Contributor may elect to Distribute the Program (including its
Contributions) under the new version.
Except as expressly stated in Sections 2(a) and 2(b) above, Recipient
receives no rights or licenses to the intellectual property of any
Contributor under this Agreement, whether expressly, by implication,
estoppel or otherwise. All rights in the Program not expressly granted
under this Agreement are reserved. Nothing in this Agreement is intended
to be enforceable by any entity that is not a Contributor or Recipient.
No third-party beneficiary rights are created under this Agreement.
Exhibit A - Form of Secondary Licenses Notice
"This Source Code may also be made available under the following
Secondary Licenses when the conditions for such availability set forth
in the Eclipse Public License, v. 2.0 are satisfied: {name license(s),
version(s), and exceptions or additional permissions here}."
Simply including a copy of this Agreement, including this Exhibit A
is not sufficient to license the Source Code under Secondary Licenses.
If it is not possible or desirable to put the notice in a particular
file, then You may include the notice in a location (such as a LICENSE
file in a relevant directory) where a recipient would be likely to
look for such a notice.
You may add additional accurate notices of copyright ownership.
## The GNU General Public License (GPL) Version 2, June 1991
Copyright (C) 1989, 1991 Free Software Foundation, Inc.
51 Franklin Street, Fifth Floor
Boston, MA 02110-1335
USA
Everyone is permitted to copy and distribute verbatim copies
of this license document, but changing it is not allowed.
Preamble
The licenses for most software are designed to take away your freedom to
share and change it. By contrast, the GNU General Public License is
intended to guarantee your freedom to share and change free software--to
make sure the software is free for all its users. This General Public
License applies to most of the Free Software Foundation's software and
to any other program whose authors commit to using it. (Some other Free
Software Foundation software is covered by the GNU Library General
Public License instead.) You can apply it to your programs, too.
When we speak of free software, we are referring to freedom, not price.
Our General Public Licenses are designed to make sure that you have the
freedom to distribute copies of free software (and charge for this
service if you wish), that you receive source code or can get it if you
want it, that you can change the software or use pieces of it in new
free programs; and that you know you can do these things.
To protect your rights, we need to make restrictions that forbid anyone
to deny you these rights or to ask you to surrender the rights. These
restrictions translate to certain responsibilities for you if you
distribute copies of the software, or if you modify it.
For example, if you distribute copies of such a program, whether gratis
or for a fee, you must give the recipients all the rights that you have.
You must make sure that they, too, receive or can get the source code.
And you must show them these terms so they know their rights.
We protect your rights with two steps: (1) copyright the software, and
(2) offer you this license which gives you legal permission to copy,
distribute and/or modify the software.
Also, for each author's protection and ours, we want to make certain
that everyone understands that there is no warranty for this free
software. If the software is modified by someone else and passed on, we
want its recipients to know that what they have is not the original, so
that any problems introduced by others will not reflect on the original
authors' reputations.
Finally, any free program is threatened constantly by software patents.
We wish to avoid the danger that redistributors of a free program will
individually obtain patent licenses, in effect making the program
proprietary. To prevent this, we have made it clear that any patent must
be licensed for everyone's free use or not licensed at all.
The precise terms and conditions for copying, distribution and
modification follow.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
0. This License applies to any program or other work which contains a
notice placed by the copyright holder saying it may be distributed under
the terms of this General Public License. The "Program", below, refers
to any such program or work, and a "work based on the Program" means
either the Program or any derivative work under copyright law: that is
to say, a work containing the Program or a portion of it, either
verbatim or with modifications and/or translated into another language.
(Hereinafter, translation is included without limitation in the term
"modification".) Each licensee is addressed as "you".
Activities other than copying, distribution and modification are not
covered by this License; they are outside its scope. The act of running
the Program is not restricted, and the output from the Program is
covered only if its contents constitute a work based on the Program
(independent of having been made by running the Program). Whether that
is true depends on what the Program does.
1. You may copy and distribute verbatim copies of the Program's source
code as you receive it, in any medium, provided that you conspicuously
and appropriately publish on each copy an appropriate copyright notice
and disclaimer of warranty; keep intact all the notices that refer to
this License and to the absence of any warranty; and give any other
recipients of the Program a copy of this License along with the Program.
You may charge a fee for the physical act of transferring a copy, and
you may at your option offer warranty protection in exchange for a fee.
2. You may modify your copy or copies of the Program or any portion of
it, thus forming a work based on the Program, and copy and distribute
such modifications or work under the terms of Section 1 above, provided
that you also meet all of these conditions:
a) You must cause the modified files to carry prominent notices
stating that you changed the files and the date of any change.
b) You must cause any work that you distribute or publish, that in
whole or in part contains or is derived from the Program or any part
thereof, to be licensed as a whole at no charge to all third parties
under the terms of this License.
c) If the modified program normally reads commands interactively
when run, you must cause it, when started running for such
interactive use in the most ordinary way, to print or display an
announcement including an appropriate copyright notice and a notice
that there is no warranty (or else, saying that you provide a
warranty) and that users may redistribute the program under these
conditions, and telling the user how to view a copy of this License.
(Exception: if the Program itself is interactive but does not
normally print such an announcement, your work based on the Program
is not required to print an announcement.)
These requirements apply to the modified work as a whole. If
identifiable sections of that work are not derived from the Program, and
can be reasonably considered independent and separate works in
themselves, then this License, and its terms, do not apply to those
sections when you distribute them as separate works. But when you
distribute the same sections as part of a whole which is a work based on
the Program, the distribution of the whole must be on the terms of this
License, whose permissions for other licensees extend to the entire
whole, and thus to each and every part regardless of who wrote it.
Thus, it is not the intent of this section to claim rights or contest
your rights to work written entirely by you; rather, the intent is to
exercise the right to control the distribution of derivative or
collective works based on the Program.
In addition, mere aggregation of another work not based on the Program
with the Program (or with a work based on the Program) on a volume of a
storage or distribution medium does not bring the other work under the
scope of this License.
3. You may copy and distribute the Program (or a work based on it,
under Section 2) in object code or executable form under the terms of
Sections 1 and 2 above provided that you also do one of the following:
a) Accompany it with the complete corresponding machine-readable
source code, which must be distributed under the terms of Sections 1
and 2 above on a medium customarily used for software interchange; or,
b) Accompany it with a written offer, valid for at least three
years, to give any third party, for a charge no more than your cost
of physically performing source distribution, a complete
machine-readable copy of the corresponding source code, to be
distributed under the terms of Sections 1 and 2 above on a medium
c) Accompany it with the information you received as to the offer to
distribute corresponding source code. (This alternative is allowed
only for noncommercial distribution and only if you received the
program in object code or executable form with such an offer, in
accord with Subsection b above.)
The source code for a work means the preferred form of the work for
making modifications to it. For an executable work, complete source code
means all the source code for all modules it contains, plus any
associated interface definition files, plus the scripts used to control
compilation and installation of the executable. However, as a special
exception, the source code distributed need not include anything that is
normally distributed (in either source or binary form) with the major
components (compiler, kernel, and so on) of the operating system on
which the executable runs, unless that component itself accompanies the
executable.
If distribution of executable or object code is made by offering access
to copy from a designated place, then offering equivalent access to copy
the source code from the same place counts as distribution of the source
code, even though third parties are not compelled to copy the source
along with the object code.
4. You may not copy, modify, sublicense, or distribute the Program
except as expressly provided under this License. Any attempt otherwise
to copy, modify, sublicense or distribute the Program is void, and will
automatically terminate your rights under this License. However, parties
who have received copies, or rights, from you under this License will
not have their licenses terminated so long as such parties remain in
full compliance.
5. You are not required to accept this License, since you have not
signed it. However, nothing else grants you permission to modify or
distribute the Program or its derivative works. These actions are
prohibited by law if you do not accept this License. Therefore, by
modifying or distributing the Program (or any work based on the
Program), you indicate your acceptance of this License to do so, and all
its terms and conditions for copying, distributing or modifying the
Program or works based on it.
6. Each time you redistribute the Program (or any work based on the
Program), the recipient automatically receives a license from the
original licensor to copy, distribute or modify the Program subject to
these terms and conditions. You may not impose any further restrictions
on the recipients' exercise of the rights granted herein. You are not
responsible for enforcing compliance by third parties to this License.
7. If, as a consequence of a court judgment or allegation of patent
infringement or for any other reason (not limited to patent issues),
conditions are imposed on you (whether by court order, agreement or
otherwise) that contradict the conditions of this License, they do not
excuse you from the conditions of this License. If you cannot distribute
so as to satisfy simultaneously your obligations under this License and
any other pertinent obligations, then as a consequence you may not
distribute the Program at all. For example, if a patent license would
not permit royalty-free redistribution of the Program by all those who
receive copies directly or indirectly through you, then the only way you
could satisfy both it and this License would be to refrain entirely from
distribution of the Program.
If any portion of this section is held invalid or unenforceable under
any particular circumstance, the balance of the section is intended to
apply and the section as a whole is intended to apply in other
circumstances.
It is not the purpose of this section to induce you to infringe any
patents or other property right claims or to contest validity of any
such claims; this section has the sole purpose of protecting the
integrity of the free software distribution system, which is implemented
by public license practices. Many people have made generous
contributions to the wide range of software distributed through that
system in reliance on consistent application of that system; it is up to
the author/donor to decide if he or she is willing to distribute
software through any other system and a licensee cannot impose that choice.
This section is intended to make thoroughly clear what is believed to be
a consequence of the rest of this License.
8. If the distribution and/or use of the Program is restricted in
certain countries either by patents or by copyrighted interfaces, the
original copyright holder who places the Program under this License may
add an explicit geographical distribution limitation excluding those
countries, so that distribution is permitted only in or among countries
not thus excluded. In such case, this License incorporates the
limitation as if written in the body of this License.
9. The Free Software Foundation may publish revised and/or new
versions of the General Public License from time to time. Such new
versions will be similar in spirit to the present version, but may
differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the Program
specifies a version number of this License which applies to it and "any
later version", you have the option of following the terms and
conditions either of that version or of any later version published by
the Free Software Foundation. If the Program does not specify a version
number of this License, you may choose any version ever published by the
10. If you wish to incorporate parts of the Program into other free
programs whose distribution conditions are different, write to the
author to ask for permission. For software which is copyrighted by the
Free Software Foundation, write to the Free Software Foundation; we
sometimes make exceptions for this. Our decision will be guided by the
two goals of preserving the free status of all derivatives of our free
software and of promoting the sharing and reuse of software generally.
NO WARRANTY
11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO
WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND,
EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE
ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH
YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL
NECESSARY SERVICING, REPAIR OR CORRECTION.
12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
AND/OR REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR
DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL
DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PROGRAM
(INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED
INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF
THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR
OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
How to Apply These Terms to Your New Programs
If you develop a new program, and you want it to be of the greatest
possible use to the public, the best way to achieve this is to make it
free software which everyone can redistribute and change under these terms.
To do so, attach the following notices to the program. It is safest to
attach them to the start of each source file to most effectively convey
the exclusion of warranty; and each file should have at least the
"copyright" line and a pointer to where the full notice is found.
One line to give the program's name and a brief idea of what it does.
Copyright (C) <year> <name of author>
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1335 USA
Also add information on how to contact you by electronic and paper mail.
If the program is interactive, make it output a short notice like this
when it starts in an interactive mode:
Gnomovision version 69, Copyright (C) year name of author
Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type
`show w'. This is free software, and you are welcome to redistribute
it under certain conditions; type `show c' for details.
The hypothetical commands `show w' and `show c' should show the
appropriate parts of the General Public License. Of course, the commands
you use may be called something other than `show w' and `show c'; they
could even be mouse-clicks or menu items--whatever suits your program.
You should also get your employer (if you work as a programmer) or your
school, if any, to sign a "copyright disclaimer" for the program, if
necessary. Here is a sample; alter the names:
Yoyodyne, Inc., hereby disclaims all copyright interest in the
program `Gnomovision' (which makes passes at compilers) written by
James Hacker.
signature of Ty Coon, 1 April 1989
Ty Coon, President of Vice
This General Public License does not permit incorporating your program
into proprietary programs. If your program is a subroutine library, you
may consider it more useful to permit linking proprietary applications
with the library. If this is what you want to do, use the GNU Library
General Public License instead of this License.
## CLASSPATH EXCEPTION
Linking this library statically or dynamically with other modules is
making a combined work based on this library. Thus, the terms and
conditions of the GNU General Public License version 2 cover the whole
combination.
As a special exception, the copyright holders of this library give you
permission to link this library with independent modules to produce an
executable, regardless of the license terms of these independent
modules, and to copy and distribute the resulting executable under
terms of your choice, provided that you also meet, for each linked
independent module, the terms and conditions of the license of that
module. An independent module is a module which is not derived from or
based on this library. If you modify this library, you may extend this
exception to your version of the library, but you are not obligated to
do so. If you do not wish to do so, delete this exception statement
from your version.
-------------- Separator --------------
./NOTICE.md
# Notices for Jakarta Annotations
This content is produced and maintained by the Jakarta Annotations project.
* Project home: https://projects.eclipse.org/projects/ee4j.ca
## Trademarks
Jakarta Annotations is a trademark of the Eclipse Foundation.
## Declared Project Licenses
This program and the accompanying materials are made available under the terms
of the Eclipse Public License v. 2.0 which is available at
http://www.eclipse.org/legal/epl-2.0. This Source Code may also be made
available under the following Secondary Licenses when the conditions for such
availability set forth in the Eclipse Public License v. 2.0 are satisfied: GNU
General Public License, version 2 with the GNU Classpath Exception which is
available at https://www.gnu.org/software/classpath/license.html.
SPDX-License-Identifier: EPL-2.0 OR GPL-2.0 WITH Classpath-exception-2.0
## Source Code
The project maintains the following source code repositories:
* https://github.com/eclipse-ee4j/common-annotations-api
## Third-party Content
## Cryptography
Content may contain encryption software. The country in which you are currently
may have restrictions on the import, possession, and use, and/or re-export to
another country, of encryption software. BEFORE using any encryption software,
please check the country's laws, regulations and policies concerning the import,
possession, or use, and re-export of encryption software, to see if this is
permitted.
Dependency: org.apache.commons:commons-lang3
License: Apache 2.0
./LICENSE.txt
Apache 2.0 ( same as ca.uhn.hapi.fhir:hapi-fhir-caching-caffeine)
./NOTICE.txt
Apache Commons Lang
Copyright 2001-2024 The Apache Software Foundation
Dependency: org.apache.commons:commons-text
License: Apache 2.0
./LICENSE.txt
./NOTICE.txt
Apache Commons Text
Copyright 2014-2022 The Apache Software Foundation
Dependency: org.checkerframework:checker-qual
Copyright: Checker Framework developers
License: MIT
./LICENSE.txt
Checker Framework qualifiers
Copyright 2004-present by the Checker Framework developers
MIT License:
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
Dependency: org.slf4j:jcl-over-slf4j
Copyright: QOS.ch
License: Apache 2.0
./LICENSE.txt
Dependency: org.slf4j:slf4j-api
Copyright: QOS.ch
License: MIT
./LICENSE.txt
Copyright (c) 2004-2023 QOS.ch
