requirejs-text
Provider: jQuery Foundation and other contributors
Component(s): requirejs-text
Copyright: jQuery Foundation and other contributors
License: MIT
 ./LICENSE
Copyright jQuery Foundation and other contributors, https://jquery.org/
This software consists of voluntary contributions made by many
individuals. For exact contribution history, see the revision history
available at https://github.com/requirejs/text
The following license applies to all parts of this software except as
documented below:
Permission is hereby granted, free of charge, to any person obtaining
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
the following conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Copyright and related rights for sample code are waived via CC0. Sample
code is defined as all source code displayed within the prose of the
documentation.
CC0: http://creativecommons.org/publicdomain/zero/1.0/
Files located in the node_modules directory, and certain utilities used
to build or test the software in the test and dist directories, are
externally maintained libraries used by this software which have their own
licenses; we recommend you read them, as their terms may differ from the
terms above.
-------------- Separator --------------
