Preface
Oracle Hospitality Cruise Property Management Border Control is an application that generates passenger manifests from the Oracle Hospitality Cruise Shipboard Property Management System. The generated passenger manifests can be uploaded/transferred to the relevant authorities for verification.
Oracle Hospitality Cruise Property Management Border Control version 23.1.0 introduces Entry/Exit System (EES), developed in accordance with EU-LISA authority requirements.
Purpose
This document provides instructions on how to install, and configure the Cruise Property Management Border Control and the use of EES application.
Audience
This document is intended for project managers, application specialists and users of Oracle Hospitality Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/.
Revision History
Table -1 Revision History
| Date | Description of Change |
July 2024 |
Initial publication. |
October 2024 |
Updated the Installation requirements and steps Added new topic Applying Patch and Updates |
