Preface
This document describes the installation process of Fleet Management System, Components or Add-Ons.
Audience
This document is intended for the technical personnel involved in installation process of the Fleet Management Components or Add-Ons.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
| Date | Description of Change |
August 2023 |
Initial publication |
January 2025 |
Remove deprecated Gangway Activity module from guide |
