16 Multimedia File Maintenance
The system supports use of multimedia file such as .AVI or MP3 for promotion presentation, alert or as standard template use on signature device. You can also link a web page for ease of access.
Figure 16-1 Multimedia File Setup
Select the Multimedia File Maintenance from the Administration menu.
Navigate to the tab you wish to add the multimedia file or image.
Click Select and choose the file from the window explorer.
Click OK to save.
Click Play or Preview to view the file .
