Preface
Oracle Hospitality Cruise Shipboard Property Management System (SPMS) solution offers the ship side users an access to the ship data. The Administration module is the backbone of the SPMS, where system codes are built according to the approved Ship’s Operational guidelines and requirements. As each of these codes may link to other fields or require other codes to be setup first, it is advisable to study and understand the relationship of each requirement before you start coding. The System Administrator, Chief Purser, Accounting Purser, Crew Purser, Cruise Director, Group Coordinator and Safety Officer are the key personnels responsible in configuring and maintaining these codes.
Audience
This document is for technical personnel, application specialist and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2020 |
Initial Publication |
November 2020 |
Added Export Photos, Update Photos and Export Documents |
January 2024 |
Updated Customer Portal URL Updated document to new format |
