14 Security Display Setup
In Security Display Setup, you can customize additional information for displayed in Security WPF module. To use these customized fields, you must insert the precise data field names.
Figure 14-1 Security Display Setup Window
Select the Security Display Setup from the Administration menu.
Right-click the space on the left panel and select Add New.
In the Account Type field, enter a code and description.
In the User Defined field, insert the name field, followed by the data field name using the square bracket [ ]. Use a comma(,) to separate the field.
Click Apply to save.
