7 Parameters
This section describes the Parameters available to the AQCI and CIW. They are accessible from the Administration module under System Setup, Parameter.
Table 7-1 PAR Group — AQCI
| PAR Name | PAR Value | Description |
Wizard DocType Alien Resident Card |
Value from Document Types |
Internal mapping for document type Alien Resident Card in |
Wizard DocType Birth Abroad |
Internal mapping for document type Birth Abroad in |
Wizard DocType Birth Certificate |
Internal mapping for document type Birth Certificate in |
Wizard DocType Enhanced Drivers License CA |
Internal mapping for document type CA enhanced driver’s
license in |
Wizard DocType Enhanced Drivers License US |
Internal mapping for document type US enhanced driver’s
license in |
Wizard DocType Fast |
Internal mapping for document type Fast in |
Wizard DocType Naturalization Certificate |
Internal mapping for document type Naturalization Certificate
in |
Wizard DocType Nexus |
Internal mapping for document type Nexus in |
Wizard DocType Passport |
Internal mapping for document type Passport in |
Wizard DocType Passport Card |
Internal mapping for document type Passport Card in |
Wizard DocType Sentri |
Internal mapping for document type Sentri in |
Wizard DocType US Re-entry Card |
Internal mapping for document type US Re-entry card in |
Wizard DocType US Refuge Card |
Internal mapping for document type US Refuge card in |
Wizard - Show Upon Startup |
0,1 or 2 |
Define the main screen to launch upon start up. 0 = Main AQCI screen without Check-In Wizard function. 1 = Check In Wizard 2 = Main AQCI screen with Check-In Wizard function. |
Wizard - User Defined Text for Scan Barcode |
E.g.: Scan Barcode |
The user define button label for Scan Barcode |
Wizard - No. of seconds to buffer Next button |
User Define |
Define the number of seconds before the Next button appears. |
Wizard - Scan Barcode Field |
res_boardcc_ext |
Define the column name to search when a barcode is scanned. |
Wizard - Nationalities With Chinese Names |
E.g.: CN, TW |
Compulsory Chinese names for nationalities as specified
in |
Wizard Show Ship Email Address |
0 or 1 |
Define whether to show Ship Email on Wizard form 0 = Do not show in wizard form 1 = Show in wizard form |
Wizard Show Quick Billing Printing Option |
0 or 1 |
Define whether to show Quick Billing Printing Option on Wizard form 0 = Do not show in wizard form 1 = Show in wizard form |
Travel Documents Eligibility Setup |
0 or 1 |
Displays the list of eligible travel documents based on the Travel Rules Setup in AQCI. |
Passport Expiry Validation |
0, 1, 2, 3 or 4 |
Define whether passport expiry validation is required. 0 = Do not validate 1 = Validate with the par value specified in month 2 = Validate with the par value specified in day 3 = Validate against disembark date with the par value specified in month 4 = Validate against disembark date with the par value specified in day |
Passport Expiry Validation Disembark Date In Day |
0, >0 |
Define whether passport expiry validation is required. 0 = Do not validate passport expiry >0 = Validate passport expiry date against disembark date with the par value specified in day |
Passport Expiry Validation Disembark Date In Month |
0, >0 |
Define whether passport expiry validation is required. 0 = Do not validate passport expiry >0 = Validate passport expiry date against disembark date with the par value specified in month |
Passport Expiry Validation Hard Stop |
0 or1 |
Define whether passport expiry validation is required. 0= Disable Hard Stop Validation; 1 = Enable Hard Stop Validation |
Passport Expiry Validation In Day |
0, >0 |
Define whether passport expiry validation is required. 0 = Do not validate passport expiry; >0 = Validate passport expiry date with the par value specified in day |
Passport Expiry Validation In Month |
0, >0 |
Define whether passport expiry validation is required. 0 = Do not validate passport expiry; >0 =Validate passport expiry date with the par value specified in month |
Overwrite Passport Details |
0 or 1 |
Define if passport details can be overwritten. 0 = Do not allow overwrite passport details when guest name does not match with the passport guest name message prompted and 'No' answer is chosen. 1 = Allow to overwrite details |
Key Runner Remote Printing |
0 or 1 |
Define Key Runner Remote Printing 0 = Do not print Key Runner Remote Printing 1 = Print Key Runner Remote Printing |
Auto Print Key Runner Receipt |
0 or 1 |
Define Auto Print Key Runner Receipt 0 = Do Not Auto Print Key Runner Receipt 1 = Auto Print Key Runner Receipt |
Auto Print Key Runner Receipt when scan barcode Extend Search Criteria = RES_BOOKNR |
Define Auto Print Key Runner Receipt when scan barcode Extend
Search Criteria = |
Table 7-2 PAR Group — Quick Check In
Take Photo Before CheckIn |
0 or 1 |
Define whether photo is required before completing the check-in. 0 = Not required 1 = Required |
None Payment Department ID |
E.g.: 9910 |
Define the DEP_ID for None Payment type use Wizard Screen |
Gender Changed Msg If Swiped |
0 or 1 |
Define whether to display or not to display the message when gender value changed during passport swipe. |
Table 7-3 PAR Group - General
Check Credit Card Registration |
0 or 1 |
Define whether to check if same credit card is registered twice. 0 = Do not check 1 = Check card registration. |
Enable Credit Card DCC |
0 or 1 |
Option to use Dynamic Currency Conversion 0 = Disable 1 = Enable |
DCC Base Country |
Specify the Credit Card DCC (Dynamic Currency Conversion) Base Country, for example US. |
Adult Min Age |
E.g.: 18 |
Define the minimum age of an adult. |
