7 Label Setup
You can use a Customized labels to further identify a transaction
or as added comments to an entry.
Figure 7-1 Customizing Labels for Cashbook Pay-In & Pay-Out
Log in toAdministration module.
Select System Setup, Labels Setup from the Administration option.
At the All Labels Listing, select PAYINW Pay Invoice and change the Label’s Description field to your description, and then click OK.
You can also customize the Pay-in, Additional Comment, Further Detail and CSB Custom Field labels using the above same steps.
Figure 7-2 Labels Setup for Pay Invoice and Pay-In
