9 Appendix A. Parameters
This section describes the Parameters available to Crew module, and they are accessible from Administration module under System Setup, Parameter.
Table 9-1 PAR Group Safety
| PAR Name | PAR Value | Description |
Advance Safety Drill |
0 or 1 |
0 - Standard Safety Drill Handling; 1 - Advance Safety Drill Handling |
Course Code for Boat Commander |
XXX |
Qualifying course for Boat Commander. (XXX=COU_CODE) |
Allow Multiple Safety Number Assignment |
0 or 1 |
0 - Do Not Allowed Multiple Safety Number Assignment 1 - Allow |
Allow to use special In Port Manning handling |
0 or 1 |
0 - Disallow, 1 - Allow |
Auto Set Ashore Denial During Drill Scheduling |
Specify duration before a Drill starts that going ashore is denied. Duration in minutes. |
Display Valid Courses On Muster List Assignment |
Display list of important courses on Muster List Assignment window. PAR_VALUE should contain COU_CODE separated by commas (eg. 331,321) |
Operational Position that Receive Message |
Crew of certain operational position to receive warning message in Active Muster List when there is expected crew in the muster list |
Allow SafetyNo Assignment to Onboard And Expected |
0 = both onboard and expected crew per safety number 1 = one crew per safety number at any one time |
InPortManning Enable One Crew Assignment per Group |
0 or 1 |
0 = Crew is allowed to be assign to multiple IPM Group 1 = Crew is not allowed to be assigned to multiple IPM Group. |
Table 9-2 PAR Group General
Duplicate Safety Number |
0, 1, 2 or 3 |
0 = Prompt for further action 1 = Keep both safety numbers assigned for checked-in crew and embarking crew. 2 – Assign Safety Number to newly embark crew and un-assign checked-in crew. 3 = Remove the safety number from expected crew and maintain safety number for checked-in crew. This option is perform in silent mode |
