7 Options
The Options Menu is an area where you set up the hardware and devices supported by SPMS, and is accessible from the Crew Main Menu.
General Tab
In the General Tab, the options to switch on/off is determined by checking the respective checkboxes. By default, the checkboxes are un-checked.
Figure 7-1 Options Menu — General Tab
This figure shows the Options Menu — General Tab
Colors
The Colors tab allows you to define a standard color scheme suitable for your operations. These colors can be easily change by clicking the color bar and then choose the color from the color chart.
Hardware
In the Hardware tab, supported peripherals, printers and devices are configured. The window varies depending on the type of report printer’s you select. Please contact Oracle Hospitality Cruise Customer Support for compatible hardware list.
Video Parameters
This section defines the video format, source and type of compression to store in the database.
Document Scanner
You can link a scanner for scanning specific forms in this tab. Contact Oracle Hospitality Cruise Customer Support for compatible hardware list.
Field Definition
This section allow you to customize the crew reservation window labels in Crew’s personal/additional/visa details tab.
Figure 7-2 Field Definition Tab
This figure shows the Field Definition Tab
