15 Options
The Options Menu is an area where supported hardware’s and devices are setup, and is accessible from the Main Menu. Please check with your system administrator before making any changes.
General Tab
In the General Tab, you can check mark the checkboxes for options applicable to your operation. By default, the checkboxes are deselected.
Figure 15-1 Options Menu — General Tab
This figure shows the Options Menu — General Tab
Colors
The Colors tab allows you to define a standard color scheme suitable for the operations. These colors can be easily change by clicking the color bar and then choose the color from the color chart.
Figure 15-2 Options Menu, Colors Tab
This figure shows the Options Menu, Colors Tab
Hardware
In the Hardware tab, supported peripherals, printers and devices are configured. The window varies depending on the type of report printers you select. Please contact Customer Support for assistance.
Figure 15-3 Options Menu, Hardware
This figure shows the Options Menu, Hardware
Video Parameters
This section defines the video format, source and type of compression to store in the database.
Figure 15-4 Options Menu, Video Parameters
This figure shows the Options Menu, Video Parameters
Document Scanner
This section link the type of scanner use for specific forms, for example, driving license, passport, and others.
Figure 15-5 Options Menu, Document Scanner
This figure shows the Options Menu, Document Scanner
