2 Contract
The Contract configuration page affects the set up and management of contract template information.
Contract Category
The Contract category enables you to assign a category to a contract. You can either use the pre-defined category when setting up a contract or create them during contract creation.
Figure 2-1 Contract Category
Creating a Contract Category
From the Administration menu, select Enterprise, and then select Contract.
At the Contract Category tab, press Create Category.
Go to the Add Contract Category page.
Enter the Category Name.
Press Save to save the category.
Modifying Contract Category
At the Contract Category tab, press Edit on the selected category record.
Go to the Edit Contract Category page and update the category name.
Press Update to save.
Deleting a Contract Category
To delete a category, select the record and press Delete.
Contract Template
The Contract Template enables you to create different types of contracts, for example, general terms and conditions. If the contract is not ready for use or no longer required in the future, you can slide the status button to deactivate the contract or delete the contract if it is not in use.
Figure 2-2 Contract Template
Figure 2-3 Contract Template New Category
