6 Unregister Mode
The Unregister Mode allows you to deregister a passenger from the current muster station. You must change the Registration mode in Settings before you deregister a person and this function requires an Administrative login. Once changed, the mode is shown on the upper status bar
The system does not allow you to unregister when,
A person that is already registered at another muster station
The person to deregister is from Search all results.
The person is yet registered.
Unregister from Search Function (Passenger View)
From the Settings, set the mode to Unregister mode.
Search for the passenger to unregister.
Tap the passenger profile and then the Unregister button.
Alternatively, swipe passenger board card to unregister.
