A Appendix
System Parameters
Below are the system parameters available to Payroll Module. Consult Oracle Hospitality Cruise Customer Support prior to changing the Database Parameter to avoid any adverse implications.
Table A-1 System Parameters
| PAR Name | PAR Value | Description |
Allow Closing of Pay Period Prior To End of Period |
1 / 0 |
1= Allow program close pay period when pay period end date is greater than current PC date. 0= Do not allow to close pay period pay period end date is greater than current PC date. |
Auto Close Balanced Posting When Close Pay Period |
1 / 0 |
This is to avoid invoices from stacking up in Management module. 1= When close pay period, program automatically closes the posting for each crew member onboard invoice. 0= Do not close posting when close pay period. |
Auto Close Pay Period After x Number of Days |
Auto close pay period after x number of days system date change is run. |
Base Wage Pay code For Corporate Instruction |
Use by OHC DGS CMS. |
Date Type |
F / S |
Determines whether Oracle date or SPMS system date is used for payroll calculations. S= Oracle date. F= SPMS system date (default). |
Default Company Code |
Value of PCY.PCY_CODE. Default company if there have multiple companies’ setup. |
Default Payout |
Value of SED.SED_NO. Default Payout code to display in the payout combo box on a new contract. |
Default To 1 When Invalid Berth Number Is Entered |
1 / 0 |
Value to check when editing a record in Edit Person function. 1= Default to 1 when no berth number is entered. 0= Prompt berth number is required. |
Display UXP_C_EXTERNALID As Crew ID |
1 / 0 |
ID display in Payroll Summary section. 0= UXP_C_INTERNALID. 1= UXP_C_EXTERNALID. |
Early Period Open |
A / Y / N |
Determine whether to allow activation of pay period before current system date. A= Always allow. Y= Allow once. N= Do not allow. |
Edit Details Screen |
1 / 0 |
0= Classic Screen. 1 – Quick reference screen |
Folio Posting |
Y / N |
Y= Allow to post crew onboard expenses when payout. N= Disallow (default). |
GL Interface |
Y / N |
Y= Generate GL file after closing a pay period. N= Do not generate GL File after closing a pay period. |
Journal Id |
The text used to identify payroll GL journals |
OceanPay File Output Folder |
C:\temp |
Path of folder for saving output files during generate card ordering for Cashless Payroll. |
OceanPay MT Prefix Nbr |
54 |
Defaults prefix number for MT Card. Populated in Cashless Payroll setup. |
Exactly 30 |
Y / N |
Change the way the number of days are calculated when changing positions in linked contract. Y= If linked contract and contract is in middle of a month, then it will use 30 days instead of the number of days in the month to determine payment. For example: For 30 days in month: - Contract 1 from 01/06/2008 - 10/06/2008 = 10 days - Contract 2 from 11/06/2008 - 20/06/2008 = 10 days - Contract 3 from 21/06/2008 - 28/09/2008 = 10 days For 31 days in month: - Contract 1 from 01/07/2008 - 10/07/2008 = 10 days - Contract 2 from 11/07/2008 - 20/07/2008 = 10 days - Contract 3 from 21/07/2008 - 28/09/2008 = 10 days (calculate as 10 days even date from 21/07/2008 to 31/07/2008) N= Calculate based on number of day (31 days being paid since either contract end date or the contract start date fall in the pay period). For example: For 30 days in month: - Contract 1 from 01/06/2008 - 10/06/2008 = 10 days - Contract 2 from 11/06/2008 - 20/06/2008 = 10 days - Contract 3 from 21/06/2008 - 28/09/2008 = 10 days For 31 days in month: - Contract 1 from 01/07/2008 - 10/07/2008 = 10 days - Contract 2 from 11/07/2008 - 20/07/2008 = 10 days - Contract 3 from 21/07/2008 - 28/09/2008 = 11 days (calculate as 10 days from 21/07/2008 to 31/07/2008) |
Cash Advance To Disregard Onboard Expenses |
1 / 0 |
1 – Cash advance available balance is not included onboard expenses.0 – Cash advance available balance is after deduct the onboard expenses. |
Report ID For Onboard Expense |
Onboard Expenses Report ID |
Report ID For SOE |
Statement of Earnings Report ID |
Report ID For WRTS |
Work / Rest Time Statement Report ID |
Return Bonus Pay code For Corporate Instruction |
Use with DGS CMS |
Round Folio |
Y / N |
Y= Send only whole dollars for folio payoff until end of contract. N= Send pennies to folio |
Show Owner |
Y / N |
Y= Owner percent field will be displayed on the crew contract form (For ResidenSea user). N= Do not display (default) |
Stock Code For OceanPay MT |
Default Stock Code for MT Card. Populate in Cashless Payroll setup |
Tier 1 Percentage |
To specify % of Crew's First Tier Contribution. Used for Pension Plan to Employer Contribution |
Tier 2 Percentage |
To specify % of Crew's Second Tier Contribution. Used for Pension Plan to Employer Contribution |
To Disable Posting During Final Payout |
1 / 0 |
1= Set UXP_A_POSTING = 0 during final payout. 0 =Allow crew posting after final payout |
US Citizen TAX Pay code For Corporate Instruction |
Use with DGS CMS |
Vacation Pay code For Corporate Instruction |
Use with DGS CMS |
Cash Advance As Default Manual Payout |
1 / 0 |
This parameter is OBSOLETED Replace by pay code with calculation method – A-NBCP |
Ending Payroll Alert |
1 / 0 |
To prompt Ending Payroll Notification |
Update BTD Total Upon System Date Change |
1 / 0 |
1 – Enable ‘Update Total’ process when run system date change 0 – Disabled |
Cash Advance Disregards Onboard Expenses |
1 / 0 |
1 – Enable to exclude onboard expenses into cash advance available amount 0 – Disabled |
ByPass payout Settlement Integrity Check |
1 / 0 |
1 -Allow to go through payout even difference between balance of Pay Addition and Pay Deduction 0 – Do not allow payout if balance of Pay Addition and Pay Deduction is different |
Default Pay Sheet Printing During Payout |
1 / 0 |
1 - Default ‘Print Pay Sheet’ enabled in Payout screen0 - Default ‘Print Pay Sheet’ disabled in Payout screen |
Default Receipt Printing During Cash Advance |
1 / 0 |
1 - Default ‘Print Receipt’ enabled in Cash Advance screen 0 - Default ‘Print Receipt ’ disabled in Cash Advance screen |
Payout Crew member Even If Res Cancelled |
1 / 0 |
1 – Allow cancelled reservation to do payout 0 – Do not allow cancelled reservation to do payout |
The Month Where HSC-In-Excess Calculation Changes |
YYYY-MM-DD |
Specifies Any Day of The Month In Which HSC-In-Excess Calculation Changes |
Ignore Error Code In Fault Detection |
Records With This Error Code Will Not Come Up In DGS-CMS-Related Fault Detection Screen |
Check All Payroll Paid Before Creating File |
1 / 0 |
Check all payroll is being paid off before generate GL file. 1 – Enabled 0 – Disabled |
Contract End Date Change Handling |
1/2/3/4 |
Prompt Payroll Notification when change contract end date. 1=With Notification Removal, 2=Without Notification Removal, 3=User-Decide On Notification Removal, 4=Allow End Date Change Only On Date-Match |
User Security
The table below lists the user security access rights to user the Payroll module.
Table A-2 User Security
| Access right | Function |
640 Payroll |
Payroll module |
646 Reports |
Reports module |
643 Select Company |
Allow access to Select Company menu item |
647 Pay Periods |
Allow to access the Pay Periods |
648 Update Pay Units |
Update Pay Units |
649 Quick Posting |
Quick Posting |
650 Payout (Payout + Mark paid) |
Payout |
651 Activate Payroll |
Activate Payroll |
645 Generate GL File |
Generate GL File for payroll |
644 Update Contract End Dates |
Update to new Contract End Dates for crew on Payroll |
653 Edit Details |
Edit Details |
3251 Access Contract Type Details |
3252 Access Pay Group Details |
3253 Access Pay Position Details |
3239 Access General Details |
3240 Access Dependent Details |
3234 Access General Details |
3249 Edit Cost Center Details |
Edit Cost Center Detail |
3235 Access Pay Addition Details |
3236 Access Pay Deduction Details |
3237 Access Payout Details |
Access Pay Out Details |
3238 Access Benefit Details |
3232 Access Payroll Details |
3247 Perform Early Repatriation |
3222 Add Assignment |
Add Assignment |
3223 Edit Assignment |
Edit Assignment |
3224 Remove Assignment |
Remove Assignment |
3254 Edit Deduct Folio Setting |
Edit 'Deduct Folio' Setting |
3277 Edit Minimum Guarantee Amount |
3220 un-masking of salary info |
If Unchecked, Salary Amount Will Be Hidden |
3225 pay payroll |
Pay Payroll |
3226 un-pay payroll |
Un-Pay Payroll |
3243 un-pay payroll for checked out crew |
Un-Pay Payroll For Checked-Out Crew |
3241 undo acknowledge payout (do not allow to undo payroll if signature is captured) |
Un-Do Acknowledged Payout |
3229 cash advance |
Cash Advance |
659 Payroll companies |
Payroll Companies |
3221 Daily Currency exchange |
Daily Currency Exchange |
654 Pay codes |
Pay Codes |
655 Salary groups |
Allow to access Salary Groups |
656 Salary positions |
Allow to access Salary Positions |
658 contract templates |
Contract Templates |
4362 Scheduled contract changes |
Scheduled Contract Changes |
660 Tax types |
Allow access to setup of tax types |
4363 Add Pay code |
Add Pay code |
4364 Modify pay code |
Modify Pay code |
4365 Delete pay code |
Delete Pay code |
4407 Add pay code (admin) |
Add Pay code |
4408 Modify pay code (admin) |
Modify Pay code |
4673 Salary@Sea Transfer File Creation |
This right grant access to Transfer file creation tab Cashless Payroll Option = 1 (Salary@Sea) |
3244 General Maintenance |
Grant access to the Cashless Payroll General Setup tab. |
3246 Card ordering |
Grant access to Card Ordering tab for Cashless Payroll Option = 0 (Ocean Pay) |
3245 System Privilege |
Grant access to Cashless Payroll on menu bar |
Audit Trail
The Audit Trail handling tracks entries, modifications and removal of transactions performed by the user on specific tables and provides supporting entry histories when the data is purged.
Table A-3 Audit Trail
| Table | Action |
ADT |
Any payroll action such as Edit Contract, Remove Contract, Un-Pay Payroll |
ADU |
Any payroll update Example: Add Pay code, Change Contract Date |
ADP |
Pay Item deletion Example: Void Pay Item, Un-Pay Payroll |
ADC |
Contract deletion Example: Remove contract |
ADS |
Pay code deletion |
You may customize a Crystal Report to generate the audit trail log.Quick Posting Import File Format
The acceptable file format for import onto the SPMS Payroll System must be in Comma Separated Value (CSV).
Table A-4 Quick Posting File Format Fields
| Column | Name | Contents |
1 |
Record Type |
The literal “POST” |
2 |
ID Type |
The type of crew identification entered in Column 3. Currently supported identification types include: “A” –RES_ACC value “C” –Payroll Contract ID (CTR_ID) “S” –RES_SHOREID value “I” –UXP_INTERNALID value “E” – SPMS UXP_C_EXTERNALID value |
3 |
ID |
The crew identifier |
4 |
Pay Code |
The Pay code for this entry |
5 |
Units |
The number of units (Hours/Days) for this entry. Only used when Cal Method for the Pay Code is “PDAY” or “HOUR”. |
Rate |
The per unit rate for this entry. Only used when the Calculation Method for the Pay Code is “PDAY” or “HOUR”. |
7 |
Amount |
The extended pay amount. For Calc Method “PDAY” and “HOUR”, this amount must equal column 5 times column 6. |
8 |
Comment |
30 characters max |
9 |
Not Used |
10 |
Currency Sign |
6 characters max. Example: USD, EUR |
Below is the row separator format for the file
Table A-5 Quick Posting File Format Separator
| Column | Contents |
1 |
The literal “TOTAL” |
2 |
Not Used |
3 |
The total number of entries in this file |
4 |
Not Used |
5 |
Not Used |
6 |
Not Used |
7 |
The total of all payroll entries in this file |
8 |
Not Used |
The following validations are performed when importing the spreadsheet data:
The ID must point to a crew member currently checked-in with an active contract.
The Pay Code column must point to a valid and active Pay Code within the system.
The Amount must be numeric and less than 9 characters long, including the decimal.
If the calculation method of the Pay Code is “PDAY” or “HOUR” then
The Units must be numeric and less than 9 digits long.
The Rate must be numeric and less than 9 digits long including the decimal.
The multiplied Units of the Rate must equal to the Amount.
The number of entries and the sum of the Amounts must match the information in the “TOTAL” record.
