4 Assigning Discount Level in Quick Check-In Module
The assignment of discounts in the Quick Check-in module varies, depending on the layout.
To set the Disc Template drop-down list as visible in ONE TAB, TWO TABS, or FOUR TABS format, make sure the field column UXP_A_LOYALTY is set to Visible, Editable in AQCI Setup, Field Definition, Additional Details tab.
Figure 4-1 AQCI Discount Template Field
Importing Reservation with POS Discount Level using Data Import
Figure 4-2 Data Import
Open the Data Import application.
In the Setup menu, select Reservation Related from the drop-down list.
In the Master Reservation window, select a line and click Insert Next to add a new field.
Figure 4-3 Edit Data Import Fields
Enter the required information.
Check the PAX checkbox, and in the PAX Table Reference drop-down list, select PAX_LOYALTY.
Click Save and click Close to exit.
The reservation manifest should contain the POS Discount code, for example, FIRST, ONE, TWO, THREE, FOUR, and FIVE for reservation with POS Discount status.
