1 MICROS POS Discount Setup
Log in to MICROS EMC module and go to the Configurator menu.
Select Discounts from the System Information section.
Select a discount record that you want to a POS discount to apply automatically on a guest check.
Under the Option column, click the Ellipsis (...) button to open the Discount Type Definition window.
Select each checkbox as needed.
Figure 1-1 MICROS EMC Discount Record Setup
1 — ON = Open OFF (Selected)
2 — ON = Amount OFF (Selected)
3 — This is an Item Discount (Deselect)
Click OK to save.
Launch the Administration module.
Go to the Administration, POS Discount, POS Discount Rate (Advance) setup window.
Expand the Discount Rate, select a revenue center and a MICROS Discount Record (Only Open Amount Subtotal Discount) from the drop-down list to link a discount record.
Click Apply to save.
Setting Up POS Discount Key
Figure 1-2 MICROS EMC Payment SCN Window
From the Touchscreens and Keyboard section, select a Workstations Design.
Double-click the Payment SCN to open the Touchscreen Design window.
Enter a new key ‘POS Discount’ on the Payment window and enter all the required details.
The Key Type must be set to “21 — SIM 1 Inquiry”, and enter the respective inquiry type using the below INQ number.
INQ 22: Loyalty Discount — Net Off Manual Discount (Discount by itemizer)
INQ 23: Advance Loyalty Discount — Net Off Manual Discount
INQ 24: Loyalty Discount (Discount by itemizer)
INQ 25: Advance Loyalty Discount
You can create four discount keys and assign them to a different discount handling.
Click OK to save.
Discount Itemizer Setting (PCWS)
Log in to MICROS SERver
Go to
\\Micros\LES\POS\9700\etcfolder.Figure 1-3 SPMS ISL Setup Window
Run ISLSetup.exe.
Click the Discount icon on the ribbon bar to open the Discount Maintenance window.
Select a discount record that has POS Discount set up in the Administration module, POS Discount Rate/POS Discount Rate (Advance) setup.
Enter the Discount Itemizer number of the Revenue Center sub-department code (debit) in the Discount Itemizer Settings field.
Figure 1-4 ISL Discount Itemizer Setting
Select the applicable Itemizer checkebox and click Save.
Click Close to exit the ISL Setup.
