Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements for Quick Check In Synchronization application.
Prerequisites
QCI Shore Database Server
Oracle Database Server 12c and Oracle Data Access Components (ODAC) Installation
OHC Web Service Installation
OHC SPMS Version 20.1 Installation
Latest version of OHC Advanced Quick Check In
PC running QCI Sync Interface
Oracle 12c Full Client and ODAC Installation
Latest version of QCI Sync Interface
PC running OHC Advanced Quick Check In at shore-side
Supported Operating System
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Compatibility
SPMS version 20.1 or later. For customers operating on version 20.1 and below, database upgrade to the recommended or latest version is required
