Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements for the Safety Drill module.
Prerequisites
Safety Drill.exe
Crew.exe
Complete set up of Safety Drill Codes in Administration module
Supported Operating System
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Compatibility
SPMS version 20.1 or later. For customers operating on version 20.1 and below, database upgrade to the recommended or latest version is required
