Preface
This document provides an explanation and description of each of the exposed functions in the Oracle Hospitality Cruise Shipboard Property Management System (SPMS) Web Service.
Audience
This document is intended for:
Third-party vendors who wish to integrate with SPMS.
This document should be used as a technical reference for external parties to develop applications which requires interfacing to SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Version | Date | Description of Change |
20.1 |
September 2020 |
Initial Publication |
August 2022 |
Updated two parameter fields in PurchasePackage function |
January 2024 |
Updated Customer Portal URL Updated document to new format |
