Preface
This document provides instructions on how to install the Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Audience
This document is for technical personnel, programmers, installers, application specialist and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2020 |
Initial Publication |
January 2021 |
Added Database Configuration, Setting Up SPMS QCI Offline Operation and Applying SPMS Platform Patch 20.1 section |
November 2022 |
Removed references to SPMS v19.1 |
January 2024 |
Updated Customer Portal URL Updated document to new format |
