9 Verifying SPMS Setup
After installing all necessary SPMS components, verify the SPMS set up to ensure every component is working as intended.
Verifying SPMS Secure Server
On one of the SPMS Application Client machines, navigate to its SPMS Public Document folder
C:\Users\Public\Documents\Oracle Hospitality Cruise. -
Backup and remove the OHCSecurity.par on the SPMS Application Client machine.
Important:
Do not remove the OHCSecurity.par file from the SPMS Secure Server.
Navigate to the SPMS Installed Folder
C:\Program Files (x86)\Oracle Hospitality Cruise. -
Locate the file SecureLogin.txt.
Set the IP address or machine name of the SPMS Secure Server as the content of the SecureLogin.txt.
Attempt to login to the OHC Launch Panel from the same SPMS Application Client machine. If the SPMS Secure Server is working as intended, you will see a new local OHCSecurity.par file on the same SPMS Application Client machine and also the login to the OHC Launch Panel will be successful.
Verifying SPMS WebServices
From the SPMS Web Server, navigate to
C:\inetpub\wwwroot\OHCWebServicesfolder. -
Check the web.config file to ensure that the SecureLogin point to the correct SPMS Secure Server.
<appSettings> <add key="Server" value = "<DB_TNS_NAME>" /> <add key = "SecureLogin" value = "<SECURE_SERVER_NAME>" /> </appSettings> -
Test an SPMS login command by using POST method with JSON structure.
Figure 9-1 POST Method with JSON Structure
If you are able to log in successfully, this means SPMS web services is hosted correctly and able to connect to SPMS Database.
