Preface
This document is to guide users attempting to configure Oracle Payment Interfaces (OPI) on Shipboard Property Management System (SPMS).
Audience
This document is intended for application specialists and users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2020 |
Initial publication |
November 2020 |
Enhanced the Outstanding Process. Added Gift Card Registration in Management/Crew module Renamed Parameter “Enable Incremental Authorization” to “Enable Auto Incremental Authorization” |
January 2021 |
Added new schema CcCourtesy to configuration tab. Added Tokenization handling for existing card and Transactions Overview tab. |
January 2024 |
Updated Customer Portal URL Updated document to new format |
