2 System Configuration
This section describes the various system codes setup within the Administration module.
Department Setup
To post a charge/payment, a debit/credit department code for a credit card type is required and this is setup in Administration module, Financial Setup, Department setup.
Login to Administration module and select Financial Setup, Department setup from the drop-down list.
Click the New button located on the bottom right of the screen to create a Sub-Department code.
At the Main Department section, enter the credit/debit card information such as Payment type, department code and description.
At the Payment Type details section,
Enter the two digits of the first set of the credit card number in Credit Card digit.
Enter the Credit Card ID. For example MC — Mastercard, VI — Visa, etc.
The Credit Card ID has to map with OPI Issuer ID.Table 2-1 OPI Issuer ID
Issuer ID Card Type AB
AliPay
AL
Alliance
AX
American Express
CU
China UnionPay
CD
China UnionPay Debit
DD
Debit
DC
Diners Club
DS
Discover
GC
Gift Card
JC
JCB
ME
Maestro
MC
MasterCard
MD
MasterCard Debit
PC
PayPal
VA
Visa
VD
Visa Debit
VE
Visa Electron
VP
V Pay
WE
WeChat Pay
BC
Giro Card
Select the corresponding Credit Card Internal ID from the drop-down box.
Enter the Credit Card Merchant Number provided by Service Provider.
Select the Commission department from the drop-down list and update the commission rate in percentage.
Check the Debit Card No Commission charge if the commission is not applicable to debit card.
Under the Department Security access, select the relevant security level from the drop-down box.
Select the relevant Payment Type under Payment Department Type. Both Credit and Debit card, Credit card or debit card.
This field determines whether the payment type is a Credit Card or Debit Card. -
Click OK to save the form.
Receipt Setup
You can generate a receipt upon payment and this would require a report template to be set up. A Standard Credit Card receipt template is available in Administration module, System Setup, Report setup, _Receipts group.
Contact Oracle Support if you wish to have a customized receipt format configured.
