1 Administration
The Administration Menu comprises of configuration input fields required by the ship’s operations. Some of the codes depend on another set of code, and may result in some functions not working as desires if they are not properly set up. Consult Oracle Hospitality Cruise Support if you have any questions about configuring the codes.
