Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements for the Advance Quick Check In module.
Prerequisites
Advance Quick Check In.exe
Administration.exe
Supported Operating System
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/.
Compatibility
SPMS version 20.2 or later. For customers operating on version 20.2 and below, upgrade your database to the recommended or latest version is required.
