Preface
The ENOAD is a program that manages the electronic Notice of Arrival/Departure of vessel movement to the National Vessel Movement Centre (NVMC) outlined by The United States Coast Guard (USCG).
Audience
This document is intended for Ship’s System Administrator and/or Application Specialists of Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2021 |
Initial publication. |
March 2022 |
Made minor grammatical changes. |
April 2023 |
Enhanced to support ENOAD schema version 3.8 Updated the APIS File List content. |
December 2023 |
Updated new customer portal. |
February 2025 |
Corrected the program executable name and table captions |
